Staro 14.10.2009., 22:27   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 9.11 (Beta)
Ako netko hoće probati Catalyst 9.11 Beta:
http://download2-developer.amd.com/a...vista-win7.zip
9.11 beta = 08/10/09 version 8.67
Liquid Snake je offline   Reply With Quote
Staro 17.10.2009., 21:11   #2
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Pa kaj nije 9.10 na redu, kaj budu preskoćili 9.10 ili?
ivand123 je offline   Reply With Quote
Staro 17.10.2009., 23:00   #3
Atrax
Atrax's Avatar
Postovi: 553
Autor ivand123 Pregled postova
Ne budu, ali 9.10 beta su loši otprilike koliko i 9.9, tako da su se odmah bacili na 9.11 očito
Betu neću ni probavat, final ću vidit, al čini mi se da ću ostat na 9.8 kak je krenulo, najbolji za sada. Sa 9.9 vidim samo neznatan pomak nabolje u Shiftu, ali je zato u svim drugim igrama koma, pogotovo red faction koji je praktički neigriv, sa 9.10 betom također.
Atrax je offline   Reply With Quote
Staro 18.10.2009., 00:44   #4
ivand123
ivand123's Avatar
Postovi: 373
A jel ga ko probo i ima li šta zanimljivo za priopćit o njima?
Staro 18.10.2009., 01:36   #5
jurbAs
jurbAs's Avatar
Postovi: 2,583
kako sam malo istrazivao po netu dosao sam do ovoga
ATI finally launches OpenCL driver
In Beta SDK
After months of promises, ATI just launched the “first complete OpenCL™ development platform” but again in beta version. This driver is the part of ATI Stream SDK V2.0 that is, as we said, in its Beta stage.
This release is fully compatible with OpenCL 1.10 specification and supports AMD GPUs as well as X86 multi core CPUs that are supporting SSE3 or higher.
Now the developer of AMD supported open source Bullet Physics can start developing it on ATI drivers instead on Nvidia drivers. Let’s hope that ATI can catch up with Nvidia which is highly unlikely, as Nvidia started investing a lot of time and engineering, not to mention money, in GPU computing some three years ago.
All Radeon 4x00 and 5x00 series are supported as well as some FirePRO and FireStream card, including some 4x00 series mobile Radeons.
The downside is that you need to use some beta drivers as this SDK won't work on your currently installed Catalyst.
www.clunk.org.uk
na jednom forumu su napisali da ce ovo ici sa ovim driverima ako sam ih dobro skuzio...
Staro 25.10.2009., 22:45   #6
renton77
Postovi: 68
isprobao driver...osjetno poboljšanje fps-a! Isprobati!
renton77 je offline   Reply With Quote
Staro 25.10.2009., 23:14   #7
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Autor renton77 Pregled postova
Konkretno u čemu, tj. u kojoj igri?
Staro 25.10.2009., 23:59   #8
renton77
Postovi: 68
cod5 MP..uglavnom to igram
Staro 26.10.2009., 00:17   #9
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Ja iskreno sumnjam da ću ja na svojoj dobit poboljašanja.
Staro 05.11.2009., 01:51   #10
krlja
krlja's Avatar
Lokacija: Ne znam
Postovi: 65
odlični driveri!!!! nfs shift i dalje ima problema ali ostale igre su se dosta popravile sve mi nekako fulidnije ide..
krlja je offline   Reply With Quote
Staro 05.11.2009., 10:32   #11
renton77
Postovi: 68
sa kojom to grafom!? Leadtek 8800gt?
Staro 05.11.2009., 11:37   #12
krlja
krlja's Avatar
Lokacija: Ne znam
Postovi: 65
zaboravio sam promijenit 4870 1gb
Staro 06.11.2009., 01:30   #13
Atrax
Atrax's Avatar
Postovi: 553
Ne znam je li to do "sedmice" ili do ovih drivera, al sve igre mi rade brže i uglađenije.
Doduše, prije bih rekao da je do winsa.
Ali u svakom slučaju, driveri su više nego solidni, sve stabilno i glatko, prvi pošteni driveri poslje 9.8 (u mom slučaju barem).
Staro 06.11.2009., 01:39   #14
vedran031
vedran031's Avatar
Postovi: 549
također na HD3850 nekako cod4mp, crysis i shift bolje idu
vedran031 je offline   Reply With Quote
Staro 06.11.2009., 16:03   #15
Shrek
Shrek's Avatar
Postovi: 359
Kad bi Official trebali izaći ako netko zna
Shrek je offline   Reply With Quote
Staro 06.11.2009., 20:27   #16
krlja
krlja's Avatar
Lokacija: Ne znam
Postovi: 65
ja imam poboljsanja u odnosu na 9.9 u cod4 sam imao najmanje 30 fpsa sad je najmanje 45 a cod 5 mi ide do 30 fps-a neznam zasto tako nisko da li je to svima tako ili samo meni ali opet je bolje nego na 9.9 pes 2010 radi savrseno kao i h.a.w.x. o nfs shiftu necu puno pricat jer je ostalo kao i prije u prijevodu jadno
Staro 06.11.2009., 20:30   #17
domis
Lokacija: Hrvatistan
Postovi: 4,165
i opet trubite o shiftu
ajde, budem sad šutel da ne dobim još jedan infraction
domis je online   Reply With Quote
Staro 07.11.2009., 02:39   #18
Atrax
Atrax's Avatar
Postovi: 553
Autor d'beast Pregled postova
Istina, baš čitam na nekoliko podforuma se spominju ti problemi sa shiftom i framerate-om, meni igra ide bez ikakvih trzaja
Izgleda da stvarno treba pogodit kombinaciju gfx postavki, drivera, os-a i tome slično. Meni se recimo igra ruši ako ugasim vsync a ostavim AA upaljen, i obrnuto.
Igram na 1440x900, 2AA, Vsync ON, 16xAF, shadows na medium, ostalo na high. FPS ne ide ispod 28, to je najmanje što sam uspio primjetit, a u pravilu je oko 40-45, što mi se čini više nego dobro obzirom na konfu i postavke.
Shebano baš, jer vidim da i ekipa sa 48xx/58xx grafama ima gadnih problema, koje su više nego sposobne zavrit to kak spada.
Bit će to garant riješeno nekakvim patchom/budućim driverom.
Zadnje izmijenjeno od: Atrax. 12.11.2009. u 01:50.
Staro 07.11.2009., 12:54   #19
krlja
krlja's Avatar
Lokacija: Ne znam
Postovi: 65
pa normalno da cemo trubit nitko nije dao pare za original igricu bezveze..nisam ju kupio da igram za godinu dana nego da ju igram sad..3 mjeseca im nije dovoljno da to poprave onda neka se ostave tog posla i jedni i drugi i neka zaposle druge ljude koji ce znat kako treba drivere napravit odnosno igricu naravno da je nvidia imala svoje prste u ovom ali umjesto da ratuju međusobno neka puste nas koji igramo i od cijih novaca oni zive da igramo kako treba a za rat neka nađu neku drugu zanimaciju...
Staro 08.11.2009., 07:09   #20
domis
Postovi: 4,165
Autor krlja Pregled postova
Staro 09.11.2009., 09:23   #21
Sk0rpi0n
Sk0rpi0n's Avatar
Lokacija: vpz
Postovi: 72
Cini se i meni da su ovo odlicni driveri, dobio sam na GTAIV oko 3-5 fps-a u nekim djelovima grada cak i vise, a za druge igrice neznam nisam jos probavo, uglavnom preporucam da probate i sami se uvjerite
Sk0rpi0n je offline   Reply With Quote
Staro 09.11.2009., 21:52   #22
cleary_555
Postovi: 29
Znaci bolji u odnosu na 9.8 na 7 x64?
cleary_555 je offline   Reply With Quote
