Staro 24.10.2009., 20:33   #1
marijan95
marijan95's Avatar
Postovi: 90
AMD Athlon 4200+ & Abit KN8
Pozdrav!
Danas sam kupio vec koristeni procesor AMD Athlon64 4200+ X2 2.2 GHz procesor. No ne osjecam nikakvu promjenu. Sta da radim?
marijan95 je offline   Reply With Quote
Staro 24.10.2009., 20:47   #2
Facelessone
Facelessone's Avatar
Postovi: 4,203
hm, pogledaj u task manager dali ti rade 2 jezgre?
Ako ne, mislim da ti slijedi reinstalacija windowsa.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 24.10.2009., 20:58   #3
marijan95
marijan95's Avatar
Postovi: 90
Gdje tocno da pogledam?
Trazim na applications, processes, performance i networking ali nemogu nac to za dvije jezgre...
Staro 24.10.2009., 20:59   #4
Facelessone
Postovi: 4,203
pod performance pogledaj dal imaš 1 ili 2 grafa za cpu
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 24.10.2009., 21:00   #5
Gx25
RiSeN FrOm tHe BaNNeD
Lokacija: cro
Postovi: 662
Pod performance vidi koiko ima prozorčića s zauzećem.
Ne osjecas razliku u windowsima ili igrama?
Gx25 je offline   Reply With Quote
Staro 24.10.2009., 21:03   #6
marijan95
marijan95's Avatar
Postovi: 90
CPU Usage i CPU Usage History i PF Usage i Page File Usage History su samo pod performance?
Znaci, re-instalacija windows?
Staro 24.10.2009., 21:11   #7
Pegasus8
Pegasus8's Avatar
Postovi: 480
stisni ctrl+alt+delete i otvorit ce ti se task manager pa provjeri...
ovako nesto
Pegasus8 je offline   Reply With Quote
Staro 24.10.2009., 21:56   #8
marijan95
marijan95's Avatar
Postovi: 90
Re-instalirao sam Windowse, instalirao sve drivere i evo slika:
Staro 24.10.2009., 21:59   #9
Pegasus8
Pegasus8's Avatar
Postovi: 480
Da ti nije u biosu isključena opcija za multi jezgre, neznam kak se zove.
provjeri u biosu.
Staro 24.10.2009., 22:02   #10
Facelessone
Postovi: 4,203
Imaš moddanu instalaciju windowsa ili neku xhackbla verziju?
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 24.10.2009., 22:02   #11
Postovi: 7,568
Još bude i ispalo da opće nije složil da mu Task Manager prikazuje po jedan graf za svaku jezgru.
Zadnje izmijenjeno od: McG. 24.10.2009. u 22:13.
Staro 24.10.2009., 22:04   #12
marijan95
marijan95's Avatar
Postovi: 90
Khm... Nemam leegalnu verziju Windowsa... Ali svejedno bi trebalo raditi koliko znam :S
BTW. Idem provjerit bios...
EDIT: Nisam nastao nista za multi jezgre u BIOS-u, znas li mozda tocno ime toga tako da to enablam?
Staro 24.10.2009., 22:12   #13
Postovi: 7,568
Autor marijan95 Pregled postova
Jedino kaj budeš našel je opcija za uključiti ili isključiti SSE i SSE2 instrukcije. Nema ništ vezano za jezgre. Moreš jedino ući u BIOS i odma F10, da spremi postavke i to je to.
Nakon bootanja provjeriš dal Task Manager dobro prikazuje dvije jezgre, jer kolko se da videti po tvojim screenshotima procesor je vredu prepoznat kao dvojezgreni.
Sam lepo rekel da nema ništ za jezgre, kad je to fora s novim AM2+ i AM3 procesorima i pločama.
Tebi je procesor normalno prepoznat kao dvojezgreni, samo provjeri u Task Manageru, pod View >CPU History dal imaš opciju za One Graph Per CPU i to je to.
Naravno, ako imaš tu opciju fino ju aktiviraj i videl budeš dvije jezgre.
Zadnje izmijenjeno od: McG. 24.10.2009. u 22:28.
Staro 24.10.2009., 22:22   #14
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
Pozdrav!
ovo me podsjetilo na ona glupava pitanja iz Teen-a, tipa; poljubila sam se deckom onako francuski, kasni mi jedan dan, jesam li trudna?
uplasena
ne vidi se razlika u cemu? u bootanju, u radu samog os-a, u nekim video programima, u igrama, u brlj zdrlj? i s kojim procesorom se ovaj 4200+ x2 uopce usporeduje, jer ja ne znam?
i ovo je jako pametno sto napises da nemas legalne vindovse, a inace je to vrlo bitna stvar.
Staro 24.10.2009., 22:25   #15
Postovi: 7,568
Imal je prije jednojezgreni 3000+, a razliku u igrama ne vidi jer nema instaliran Dual-Core Optimizer, pa mu je isti vrag (u većini igara) ko da ima jednojezgreni i FPS mu šara kak ga volja. Dok u programima ne vidi razliku, jer ili ne koristi one koji imaju sposobnost iskoristiti sve raspoložive jezgre ili jednostavno opće nije ni imal potrebu za dvojezgrenim procesorom, pa mu je sad totalno svejedno kaj radi po pitanju "uključivanja" jezgri kad razliku tak i tak ne bude osjetil.
Staro 24.10.2009., 22:26   #16
Facelessone
Postovi: 4,203
za slučaj da nije i to sa grafom, pogledaj ovo http://forums.amd.com/forum/messagev...threadid=93728
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 24.10.2009., 22:28   #17
marijan95
marijan95's Avatar
Postovi: 90
Autor McG Pregled postova
Neda mi da enablam to:
Staro 24.10.2009., 22:32   #18
Postovi: 7,568
Odi (ako već nisi) u BIOS i promijeni recimo datum i stisni F10, pa sačuvaj postavke. Onda opet provjeri situaciju s grafovima.
U slučaju da i dalje nemaš dvije jezgre, Facelessone ti je linkal ono kaj ti je sljedeće na dnevnom planu.
Ako ni to ne upali, počni tražiti BIOS s kojim tvoja ploča podržava X2 procesore.
Staro 24.10.2009., 22:37   #19
marijan95
marijan95's Avatar
Postovi: 90
OK, slozit cu datum u BIOS-u i onda probat. Trenutno skidam drivere za sound, tako da vam javim za kojih 5-10 minuta.
Staro 24.10.2009., 22:42   #20
Burko
Burko's Avatar
Postovi: 2,317
pogledaj svakako koja je verzija biosa. sluzbena stranica kaze da mora biti verzija 19 za 4200+ x2. vrlo lako da je u ovome problem ako nisi nikad update-ao bios .
btw, evo odmah i linka da ne trazis - klik 1, klik 2.
Staro 24.10.2009., 22:57   #21
marijan95
marijan95's Avatar
Postovi: 90
Da li moram onaj jumper micat nakon update-a?
Staro 24.10.2009., 23:11   #22
Postovi: 7,568
Koji jumper, onaj za Clear CMOS ili neki deseti? Si opće probal kaj od rečenog ili odma ideš flashati novi BIOS, mada možda nema potrebe za tim? Ako i kad budeš flashal, ne trebaš nužno raditi Clear CMOS, dosta je da i u BIOS-u loadaš Deafult postavke. Mada ako baš hoćeš posezati za Clear CMOS opcijom, nakon kaj to napraviš, jumper za Clear CMOS, prebaciš iz (najčešće) pinova 1-2 u 2-3, a nakon toga opet vratiš u 1-2, tj. kak je bilo. Da ne bi bilo zabune ne ostavljaš taj jumper u 2-3 pa onda ideš flashati, nego samo prebaciš na pinove 2-3 i "za sekundu" opet vratiš u "početan položaj", tj. na pinove 1-2. Uostalom sve to ti lepo piše u priručniku od ploče, pa pregledaj prije nego kreneš kaj flashati.
Staro 24.10.2009., 23:20   #23
marijan95
marijan95's Avatar
Postovi: 90
Ma nisam još mislio krenuti flashati...
Probo sam ove stvarcice sta su decki postali ali za sada nikakvih promjena... :S
Staro 25.10.2009., 09:58   #24
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Na KN8 bi trebalo radit kako treba sve, ako BIOS ne prepoznaje proc neće ga htjet niti bootat, ako boota - prepoznala ga je...
Što se grafa tiče ja imam drugu mašinu sa 3800+ x2 i fakat se ne sjećam sad dal imam odvojene prozorčiće za CPU usage na njemu u XPima ili nemam ali mislim čak da nemam u svakom slučaju uzmi everest i pogledaj u Operating System - Kernel Type mora pisat multiprocessor i u motherboard -> CPU tabu vidiš na dnu pod utilisation po jezgrama ispis...
E da instaliraj si i onaj AMD optimiser za svaki slučaj, btw ne osjeti se u SVAKOJ stvari i progiju više jezgara...
Have a nice day...
Staro 25.10.2009., 10:55   #25
marijan95
marijan95's Avatar
Postovi: 90
Evo rezultata:
EDIT: Da li da instaliram Vistu ili Xp 64 bitni sustav?
Staro 25.10.2009., 11:00   #26
yedwy
yedwy's Avatar
Postovi: 6,956
Eto ti odgovora instaliran ti je single core kernel, zato ti ne radi kako treba, ako si reinstalirao windowse na čisto (s formatiranjem) probaj s drugim medijem opet, ako si instalirao preko postojećih možda ti neće zato, u svakom slučaju probaj prvo deinstalirat u device manageru sve kaj možeš deinstalirat od ploče (u Safe modu) pa nek izvrti opet detekciju uređaja i poinstalira si drivere...
E da i daj sshot od BIOS taba...
Have a nice day...
Staro 25.10.2009., 16:11   #27
marijan95
marijan95's Avatar
Postovi: 90
Pogledao sam u BIOS-u i zadnja verzija je BIOS-a (19)... Hmm... probat cu ovo s driverima pa cemo vidjeti...
Staro 25.10.2009., 16:19   #28
yedwy
yedwy's Avatar
Postovi: 6,956
A čuj ako ne radi tako mora onda bit neka greška u tvom instalacijskom CDu, nabavi drugi pa probaj s njim, nek ima SP2 ili SP3 integriran na sebi...
Have a nice day...
Staro 25.10.2009., 16:30   #29
marijan95
marijan95's Avatar
Postovi: 90
Sad cu probat Windows XP 64 bitni sustav instalirat pa cemo vidjeti..
Staro 25.10.2009., 16:30   #30
Facelessone
Postovi: 4,203
Ima moddanu instalaciju gdje je već s nliteom odabrano da je uniprocessor
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
