LateralusX
Postovi: 1,788
Unigine Heaven DirectX 11 benchmark
Unigine Heaven DirectX 11 benchmark Unigine Corp announced its release of the first DirectX 11 benchmark "Heaven" that is based on its proprietary Unigine engine. The company has already made a name among the overclockers and gaming enthusiasts for uncovering the realm of true GPU capabilities with previously released "Sanctuary" and "Tropics" demos. Their benchmarking capabilities are coupled with striking visual integrity of the refined graphic art. DOWNLOAD "Heaven" benchmark excels at providing the following key features: * Native support of OpenGL, DirectX 9, DirectX 10 and DirectX 11 * Comprehensive use of tessellation technology * Advanced SSAO (screen-space ambient occlusion) * Volumetric cumulonimbus clouds generated by a physically accurate algorithm * Dynamic simulation of changing environment with high physical fidelity * Interactive experience with fly/walk-through modes * ATI Eyefinity support VIDEO |
#2 | ||||||||||||||||||||||||||||||||
Lokacija: doma
Postovi: 964
ovo mi je izbacilo,a testirano na dx10 hardwareu. čudno |
#4 | ||||||||||||||||||||||||||||||||
Postovi: 5,992
Unigine Heaven Demo v1.0
Hardware
Settings
5870 na mukama.Dobar bench.Maleni dx11 možeš ukljućiti zbog win 7,pod vistom dx11 se ne može ukljucit iako ce se uskoro moći to,može se i sad neslužbeno. Zadnje izmijenjeno od: MAGARAC. 23.10.2009. u 23:58. |
#6 | ||||||||||||||||||||||||||||||||
Postovi: 1,011
Lokacija: doma
Postovi: 964
hihi ne vidi se al nije samo jedna nek sli,ali opet mora do toga što je to nvidia. Nego je glupo što vrti pod dx11 a kartica ne podržava dx11. Edit:max ne vrti ali tak piše,krivo sam se izrazio. bolje izvrti neke pa postaj,5 min posla dok to inst i postaš. |
#9 | ||||||||||||||||||||||||||||||||
Postovi: 5,992
Hardware
Settings
Evo Maleni kako to izgleda kad izvrtš dx10 na 5870 Razilka dx10 i dx11 je jako velika ,skoro kao da je namjerno napravljno da dx10 izgleda loše |
Postovi: 7,326
#11 | ||||||||||||||||||||||||||||||||
Postovi: 682
#12 | |||||||||||||||||||
Lokacija: doma
Postovi: 964
sad si me zainteresiral da i ja nabavim neki dx 11 hardver da vidim kak to izgleda jer mi se ovo jako sviđa s obzirom da se vrti na tak maloj rezi. mada mislim da bum počekal još i novi 3dčmark. tome se nemre odoliti ![]() |
#13 | ||||
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
full: http://www.imagesforme.com/show.php/749158_1.JPG To je test samo za vga, cpu ne dira ni 10%, a zna se da i cpu dosta pridonosi, jer ima ljudi na forumu koji su punu snagu svojih kartica osjetili tek kada su stavili brži proc pa je tako tu score isti neovisno jel clock 3.2 ili 3.6 u mom primjeru, a vjerojatno bi bio isti i da je single/dual core u igri tu se vidi usage jezgri, core 1 i 3 nešto sitno, sveukupno oko 10% 2 Bullet1: kakav template? pa svi se držimo copy/paste reze i to imamo svi isto. da se stavlja samo brojka?
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() Zadnje izmijenjeno od: TomRi. 24.10.2009. u 02:33. |
Lokacija: Zd
Postovi: 4,752
Unigine Heaven Demo v1.0 Score: 2708 HardwareBinary: Windows 32bit Visual C++ 1500 Release Oct 22 2009 Operating system: Windows 7 (build 7600) 64bit CPU model: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz CPU flags: 3330MHz MMX SSE SSE2 SSE3 SSSE3 HTT GPU model: ATI Radeon HD 4870 X2 8.660.0.0 1024Mb SettingsRender: direct3d11 Mode: 1024x768 fullscreen Shaders: high Textures: high Filter: trilinear Anisotropy: 4x Occlusion: enabled Refraction: enabled Volumetric: enabled Zadnje izmijenjeno od: Sn4k3. 24.10.2009. u 15:25. |
#16 | ||||||||||||||||||||||||||||||||
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,103
#18 | |
Postovi: 5,992
Kad se ukljući teselizacija cpu load pada s oko 70 na 30% Zadnje izmijenjeno od: MAGARAC. 24.10.2009. u 02:44. |
#19 |
Postovi: 7,326
FPS: 76.0 Scores: 1915 Operating system: Windows 7 (build 7600) 64bit CPU model: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz CPU flags: 4002MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT GPU model: NVIDIA GeForce GTX 280 8.16.11.9062 1024Mb Postavke sve na default. |
#23 |
Datum registracije: May 2009
Lokacija: Kutina
Postovi: 16
Unigine Heaven Demo v1.0FPS: 54.2 Scores: 1364 HardwareBinary: Windows 32bit Visual C++ 1500 Release Oct 22 2009 Operating system: Windows 7 (build 7100) 32bit CPU model: Intel(R) Core(TM) i7 CPU 975 @ 3.33GHz CPU flags: 3337MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT GPU model: ATI Radeon HD 5800 Series 8.661.0.0 1024Mb SettingsRender: direct3d11 Mode: 1024x768 fullscreen Shaders: high Textures: high Filter: trilinear Anisotropy: 4x Occlusion: enabled Refraction: enabled Volumetric: enabled sve default |
#24 |
Postovi: 2,073
razlika u scoru nije zbog cpu clocka(mozda par bodova svega), već takta grafe (kod mene je bio 840/1050)
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() |
#25 |
Hurr durr
Lokacija: Stančić
Postovi: 1,449
Unigine Heaven Demo v1.0 FPS: 43.4 Scores: 1092 Hardware Binary: Windows 32bit Visual C++ 1500 Release Oct 22 2009 Operating system: Windows XP (build 2600, Service Pack 3) 32bit CPU model: Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz CPU flags: 2653MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 HTT GPU model: ATI Radeon HD 4800 Series 6.14.10.6947 512Mb Settings Render: direct3d9 Mode: 1024x768 fullscreen Shaders: high Textures: high Filter: trilinear Anisotropy: 4x Occlusion: enabled Refraction: enabled Volumetric: enabled
Zadnje izmijenjeno od: Vejita. 24.10.2009. u 18:12. |
#26 |
Lokacija: doma
Postovi: 964
#29 |
Postovi: 3,783
Unigine Heaven Demo v1.0 FPS: 54.5 Scores: 1372 Hardware Binary: Windows 32bit Visual C++ 1500 Release Oct 22 2009 Operating system: Windows 7 (build 7600) 64bit CPU model: Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz CPU flags: 3800MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 HTT GPU model: NVIDIA GeForce 9800 GTX/9800 GTX+ 8.16.11.9107 512Mb Settings Render: direct3d11 Mode: 1024x768 fullscreen Shaders: high Textures: high Filter: Trilinear Anisotropy: 4x Occlusion: enabled Refraction: enabled Volumetric: enabled |
#30 | |
Oppa Gangbang Style
Postovi: 1,763
meni neće ![]() ![]() ![]() |
