Staro 25.09.2009., 21:49   #1741
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor m&n Pregled postova
da.. to je tako i kod mene standard ako ih kloknem previse manji score..
btw.. meni na xpu nije htjelo zbog losih raid drivera i tamo mi disk troka a nisam se sjetio kupit jedan drugi da napravim backup kmee.. imo sam to u planu al jbga prekasno tj. ti si prebrzo reagiro heh
Jel te tvoje imaju onaj cooler od ati-a?
Meni se to shranje isto događalo, više clockam manji score ono WTF?
Kupio Scythe musashi i onda je sve sjelo na svoje mjesto, veći clock = veći score, a i max overclock se povećao.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 25.09.2009., 23:26   #1742
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
@DomagojX - koliko su se dale klokat s tim driverima? ja sam imao problema s njima, nisam smio pipnit nista odmah se rusilo, 9.8 su mi daleko stabilniji
Staro 25.09.2009., 23:53   #1743
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
solo grafa 822/1101
DomagojX je offline   Reply With Quote
Staro 26.09.2009., 01:02   #1744
C.J.B.
C.J.B.'s Avatar
Postovi: 179
evo jedan neuspjesan pokusaj probijanja 20k bodova s aemdejcem na gtx 275...
ali danas je novi dan, a stari izazov je jos tu
http://www.imagesforme.com/show.php/704308_19907.jpg
C.J.B. je online   Reply With Quote
Staro 26.09.2009., 01:13   #1745
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Da to cudo ne moze priko 4Ghz...? Vjerojatno bi isa sa boljim hladjenjem, ha?
U svakom slucaju jako si blizu 20k
Staro 26.09.2009., 01:17   #1746
C.J.B.
C.J.B.'s Avatar
Postovi: 179
ide preko 4 i sa zalmanom, ali nedovoljno stabilno za 3dmark. mozda bi s true ili necime i mogao...ma zapravo dok malo padnu temperature, da vidis...ali mislim da cu kao dugorocno rijesenje nabaviti neko kvalitetnije vodeno..
Staro 26.09.2009., 02:36   #1747
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Da, ili vodeno ili mozda neko zracno kvalitetnije poput true ili megahalems...
btw, dobar skor
Staro 26.09.2009., 04:04   #1748
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
CJB posudiš mi tvikera na jedan session?
Oderi NB frekvenciju i ništa drugo, iznenadio bi se koliko ćeš bolji rez dobit 20k+
Staro 26.09.2009., 21:18   #1749
DomagojX
Postovi: 1,307
26k još sad malo proc nategnut i grafe
Staro 26.09.2009., 22:41   #1750
blue#13
Postovi: 516
Ma super je
Svaka ćast
blue#13 je offline   Reply With Quote
Staro 26.09.2009., 23:02   #1751
DomagojX
Postovi: 1,307
hvala...eto sad opet odvrtio sve na istim postavkama kako i tu gore i onda dobim 25.5k...wtf?
edit:
mi može netko reć kako se radi validacija....ja sam fino kad je odvrtio 3dmark kliknuo submit your results i dobio sam ovaj link
http://service.futuremark.com/home.a...24E0C117E7AF88
i sad kad ga stisnem ne vidim nikakvu validaciju
Zadnje izmijenjeno od: DomagojX. 27.09.2009. u 13:01.
Staro 27.09.2009., 13:15   #1752
maX
maX's Avatar
Postovi: 7,326
Autor DomagojX Pregled postova
DomagojX - 26010, ORB| Dual HD4870 @ 790/2100MHz, zrak | i7 920 @ 4.10GHz
Slabo slabo, daj to tati da iscijedi 28+ k
Staro 27.09.2009., 13:22   #1753
DomagojX
Postovi: 1,307
a jbg...neam ja D0 ...a dođi si po grafe pa iscijedi
Autor bloodthorn Pregled postova
Bloodthorn & Sample - 19149 | HD4870 @ 820/1110, zrak | i5 750 @ 4.2 GHz
sad si me razljutio
Zadnje izmijenjeno od: DomagojX. 27.09.2009. u 23:59.
Staro 29.09.2009., 12:21   #1754
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Autor C.J.B. Pregled postova
C.J.B. - 20171 | GTX275 , AMD TWKR
za ovo def treba organizirati nekakvo skupljanje i poderat ga ispod ln2...
Staro 29.09.2009., 12:58   #1755
maX
maX's Avatar
Postovi: 7,326
Ima se u planu neka sesija
Staro 29.09.2009., 13:09   #1756
C.J.B.
C.J.B.'s Avatar
Postovi: 179
Autor maX Pregled postova
nadam se da ce nesto biti...ako sa zdravljem bude sve ok..
Staro 29.09.2009., 14:06   #1757
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
ajde sretno, ako trebate kakvu ddr3 memoriju javite
Staro 30.09.2009., 15:33   #1758
Teem55
Teem55's Avatar
Datum registracije: May 2009
Lokacija: Kutina
Postovi: 16
eto mojih rezultata
eto mojih rezultata
Teem55 je offline   Reply With Quote
Staro 30.09.2009., 15:48   #1759
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,763
Autor Teem55 Pregled postova
eto mojih rezultata
slabi su ti to rezultati
moglo bi se to malo bolje (vidjeti)
E-mil je offline   Reply With Quote
Staro 30.09.2009., 16:02   #1760
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Autor bluefluid Pregled postova
Sve dolazim u napast da puknem onaj naš "SS" (tj sliku sa fotoaparata) našeg scorea sa kojim smo u drugom pokušaju došli na drugo mjesto PCE @ 3D mark 06 (razer sa 100 bodova više sa 4 GPUa ). A noć je još bila mlada, šteta što je ploča otegla
Ali neću, neka još malo žive u neznanju , do druge sesije , šta bi tek bilo da smo stavili onu drugu grafu na čekanju i sa njom provrtili
pffffff
OC cookies FTW
blaa
Zadnje izmijenjeno od: hammer_of_thor. 30.09.2009. u 16:18.
Staro 30.09.2009., 21:22   #1761
maX
maX's Avatar
Postovi: 7,326
Wolverine - 25253 | ATI Radeon HD5870 @ 850/1200 MHz, zrak | Core i7 940 @ 4.0GHz
Pukni XP te malo još nakuri proc i grafiku i imaš 1. mjesto
Staro 30.09.2009., 21:28   #1762
Wolverine
Wolverine's Avatar
Postovi: 12,425
nemam XP na tom kompu, nema više ni Viste.... sad je samo Win7 x64
ionak je dovoljno za No1 ako gledamo da je to samo 1 GPU
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 30.09.2009., 21:32   #1763
maX
maX's Avatar
Postovi: 7,326
Ajd pa nije valjda da nemaš niti jedan neki manji hard i u 20 minuta instaliraš windows XP s driverima za chipset/gpu i 3DMark
Staro 30.09.2009., 23:38   #1764
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Wolv papak jedan, opet bi se izvlačio da nemaš vremena a?
Daj nakuri to čudo još malo ae.. nebudi lijen
XP rokni i malo taj uncore još natjeraj
Staro 01.10.2009., 00:16   #1765
Melani
Lokacija: doma
Postovi: 964
odličan oc za tu voltažu.
to bi trebalo ići daleko više.
Melani je offline   Reply With Quote
Staro 01.10.2009., 00:23   #1766
Teem55
Teem55's Avatar
Lokacija: Kutina
Postovi: 16
ma ovo je za pocetak... ne stignem nikako sjesti par sati u komadu za comp
Staro 01.10.2009., 00:42   #1767
Razer
Razer's Avatar
Postovi: 11,642
Pa nema nikakvog SS-a/thumbnaila ovdje, o čemu ti?
Staro 01.10.2009., 07:24   #1768
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
eto mojeg extremiste
Teem55 21123 Ati Radeon HD4890 @ 1020/1170 MHz / Core i7 975 4252 MHz Extreme vodeno
Pa daj nategni to još, ja imam veći score sa svojim Quadom i GTX260
C L O W N I N G A R O U N D
Staro 01.10.2009., 09:14   #1769
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Autor hammer_of_thor Pregled postova
pffffff
OC cookies FTW
Suti, ispast ce da smo papci jer smo skurili plocu takvog kalibra.
Ajde vise jel misle oni tebi vratit to, po procu se paucina uhvatila
Inace gledam malo ove zadnje skorove, svi se nesto raspistoljili sa 20k i debelo preko al sa fino oznojenim hardverajem, tako da mi se cini da ce nase 3 banke tesko skinit
OC cookies dude
Staro 01.10.2009., 09:28   #1770
hammer_of_thor
Postovi: 5,430
Ma yebeš ploču , nit smo nesposobni, nit papci, nit je voltaža bila velika (rekao bi da nije bila ni umjerena a kamoli velika), nit je BCLK prešao 210 u tom run-u... sreća jbg, ploča kihnula sama od sebe, bit će da je nešto do PCI-e utora... jbga
Čekam odgovor od reklamacije, kad su primili ploču javili su da mi ne mogu reći kad će biti riješena... dakle možda i 45 dana :/
a po 'ardveru se paučina hvata
Vozim GTX275 na 945i čipsetu , epic
Baš gledam po ibeju kakvu EVGA x58 3 SLI za 250$ uzet, svrbe me prsti, htjeli bi OC bench seš'n
Pa kad mi se vrati RIIE ovu prodam
blaa
Zadnje izmijenjeno od: hammer_of_thor. 01.10.2009. u 09:54.
