Staro 25.10.2008., 12:51   #1
frootek
Postovi: 4
Windows 7 - problemi, troubleshooting
evo ovako, na novi hp-ov laptop, freedos, krenem instaliram xp, bootam cd, i prije setupa mi se pojavi ovo
Sliku u thumb!
moze itko pomoci?
Zadnje izmijenjeno od: Jelc. 25.10.2008. u 15:13.
frootek je offline   Reply With Quote
Staro 25.10.2008., 13:50   #2
dario_os
dario_os's Avatar
Postovi: 11
Idi prvo u BIOS i iskljuci ACHI mode na HDD,trebalo bi radit
dario_os je offline   Reply With Quote
Staro 25.10.2008., 14:36   #3
nino
nino's Avatar
Postovi: 12,613
10000000000000x puta postavljeno pitanje.
Staro 15.09.2009., 22:21   #4
Dario29011985
Dario29011985's Avatar
Datum registracije: Apr 2009
Postovi: 8
Svi problemi sa Windows 7
NA RAČUNALU VEĆ IMAM INSTALIRAN WINDOWS 7 OS I HTIO BI DA IMAM 2 OPERATIVNA SUSTAVA,TJ DA MI WIN 7 OSTANE A DA NPR KAKO SAD IMAM NA C: PARTICIJI WIN 7 DA NA E: PARTICIJU STAVIM XP. PROBLEM JE U TOME ŠTA MI RAČUNALO NE DOPUŠTA INSTALIRANJE XP-A JER JE TO STARIJI OS OD WIN 7....
Dario29011985 je offline   Reply With Quote
Staro 15.09.2009., 22:29   #5
The Comedian
It's all a joke
The Comedian's Avatar
Lokacija: unknown
Postovi: 445
Autor Dario29011985 Pregled postova
kao prvo nemoj vikati
a kao drugo, probaj s ovim
Once you realize what a joke everything is, being the Comedian is the only thing that makes sense.
The Comedian je offline   Reply With Quote
Staro 15.09.2009., 22:34   #6
Wolverine
Wolverine's Avatar
Postovi: 12,425
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 16.09.2009., 10:08   #7
Dario29011985
Postovi: 8
Autor The Comedian Pregled postova
probao sam kako kažu na tom linku,ali opet nemogu ništa... opet sam išao u BIOS da vidim ako mi je 1 device cd-rom i tako i je... samo kad dođe pri podizanju računala do boot-anja jednostavno preskoći to,a cd je normalno u cd-rom-u i podiže se win 7.... ne razumijem šta bi sljedeće napravio... čak sam i formatirao e: disk u managementu jer sam htio da mi na toj particiji bude xp
Staro 16.09.2009., 16:51   #8
The Comedian
It's all a joke
Lokacija: unknown
Postovi: 445
kazes da si namjestio u bios-u da ti je cd na prvom mjestu za boot, i da ti preskoci, jel?
zar nema nikakve poruke, Press any key to boot from cd... il nest? (tu treba udarit bilo koju tipku, jer se inace nece bootat i nastavit ce se podizat sedmica)
provjeri jos jednom da li ti je: first boot device tvoj cd uredaj, i provjeri da li ti je uopce taj cd ispravan
ugl kad ti se cd od winXp-a boota, odes na opciju da zelis instalirat windoze i kad ti se ponude particije, ti izaberes onu koju su namjenio za windoze xp
pazi samo da ne odaberes onu di ti je sedmica
Staro 16.09.2009., 20:11   #9
CyCl0p$
win 7 errori
u zadnjih nekoliko dana mi se neobjasnjivo smrzava komp tijekom igranja, bacim pogled na event log i ovo je cest error:
event id 33
Activation context generation failed for "C:\Windows\WinSxS\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.762_none_0c178a139ee2a7ed\MFC80.DLL". Dependent Assembly Microsoft.VC80.MFCLOC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50608.0" could not be found. Please use sxstrace.exe for detailed diagnosis.
a pod critical:
event id 41, task category 63
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
ako moze ko pojasnit.
radi se o 64 bitnim windowsima build 7600.
driveri su ok mislim, zadnji sve. nema razloga da se rusi, temperature su i vise nego ok.
hvala.
Staro 19.09.2009., 10:09   #10
thezero
thezero's Avatar
Postovi: 238
nemogu instalirati win7 rtm
nedavno sam kupio maticnu dfi blood iron p35-t2l i proc e6300 te bih sad trebao napraviti reinstall win 7 koju imam na kompu... kad je stavim u dvd-rom restart kompa napravim,postavim da boota s dvd-a,dode do onog boot from cd i samo stoji... i tako satima ak treba... dali netko zna u cem je problem?
maticna je kao sto rekoh dfi blood iron p35-t2l,proc e6300,4gb ram-a a data gaming series,pioneer brener....
Zadnje izmijenjeno od: Hamm. 19.09.2009. u 12:01.
thezero je offline   Reply With Quote
Staro 19.09.2009., 18:01   #11
robi64
Lokacija: ZAGREB-DUBRAVA
Postovi: 1,075
SVI problemi sa Windows 7
evo ovako da još jednom pitam dakle DA LI SE MOGU NA PRIJENOSNIK(HP 4170S)INSTALIRATI WINDOWSI 7 ja sam ih probao instalirati ali nema šanse da ih stavim,da li netko ima na prijenosniku dakle instaliranu win7-icu i da mu radi ako ima da mi na pm pošalje kao je to uradio ako hoće
robi64 je offline   Reply With Quote
Staro 19.09.2009., 18:14   #12
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,615
Ne ide - radi čega? Što je problem - gdje stane?
Staro 19.09.2009., 23:06   #13
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,249
imam jedan problem. naime, nemogu nikako pristupit shareanim folderima na xp masini sa win 7 masine.
sa xp-a mogu pristupit na win 7 , ali obrnuto neide.
jednostavno mi javi ovu poruku "logon failure:unknown username or bad password".
workgrupa je ista na oba dva pc-a, username i password su ispravni, isprobano sa trece masine (na njoj je xp), firewall i av je iskljucen na obje masine tako da nije ni do toga.
trazio sam po netu rjesenja al nisam nista pametno nasao da bi pomoglo. ako netko ima ideju slusam.
Staro 19.09.2009., 23:52   #14
domy_os
domy_os's Avatar
Postovi: 18,871
Uključi simple file sharing...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 20.09.2009., 10:24   #15
thezero
thezero's Avatar
Postovi: 238
ajmo ljudi koji znaju-dali je moguce da je do bios-a koji je na maticnoj da nemogu reinstall napraviti??? jucer sam probao i xp stavit i nece ni to-stoji na boot from cd kao i kod win 7... i primjetio sam u everestu da mi pise za bios da je beta... da nije to mozda razlog???!!??? da je posran ili nesto? nemam stick da probam stavit normalan bios da vidim oce pomoc...
Staro 20.09.2009., 15:11   #16
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Autor robi64 Pregled postova
OK...polako....u cemu je problem? Ne mozes ih instalirat radi cega? Nema podrske za drivere....neke odredene programe? Ne znas koju verziju stavit? Ne znas je aktivirat? Daj malo detaljniji opis "problema" jer 99% da nitko tu ne kuzi u cemu je problem na temelju ovoga sto si napisao.
LP
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 20.09.2009., 15:15   #17
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
DVD-rom fizicki ispravan ? Jesi probao umjesto njega neki drugi ?
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 20.09.2009., 15:40   #18
thezero
thezero's Avatar
Postovi: 238
trebao bi biti.... nisam ni razmisljao o tome da nebi valjao-makar je skoro novi pioneer...star pol godine i sa samo 20 przenja mozda... a citanja i manje...
budem probao posudit od nekog dvd rom pa cemo vidjet
Staro 20.09.2009., 23:40   #19
hardflat
hardflat's Avatar
Lokacija: Sisak
Postovi: 250
HP - ProBook 4170s dolazi sa vistom pa ne vidim razlog zašto ne bi išli windowsi 7!.
Problem je možda u winsima koje imaš, koju verziju W7 imaš?
Što se tiče instalacije možeš je pokrenuti sa diska ili sa dvd-a i vrlo je jednostavna.
Ako imaš RC zaboravi instalaciju, možeš instalirati samo RTM ili pričekaj GOLD izdanje!.
hardflat je offline   Reply With Quote
Staro 21.09.2009., 01:10   #20
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
Jel ima itko gigabajtovu matičnu i 5.1 slušalice i da je usmio namjestit da mu rade sva tri kanala? Meni nikako ne prihvaća treći kanal kao Headphone u ovom HD Audio menageru za win 7
bozzomfeeder je offline   Reply With Quote
Staro 21.09.2009., 11:54   #21
robi64
Postovi: 1,075
Autor MadBoY Pregled postova
Pa odnesi nekome tko zna instalirati Windoze i gotovo.
Ili hoces da ti netko nacrta kako se instalira Win7 na laptop koristeci kristalnu kuglu da bi saznao kakve probleme imas prilikom instalacije?
Taj laptop standardno dolazi sa Vistom, tako da Win7 mora ici gore bez problema.
E gle da se razumijemo već sam milion puta instalirao windowse na komp ,drugo ja sam laptop kupio sa free dos konfiguracijom znači bez ikakvog os-a i ok i tu si u pravu kad kažeš kakve probleme imam prilikom instalacije u idućem postu budem opisao problem prilikom instalacije win7
Staro 21.09.2009., 15:01   #22
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
preko dos-a sam jedino uspijevao stavljati linux i nakon linuxa staviti xp, vistu, w7 jedino sam tako uspijevao inace me je znao izbacivat u pola instalacije, na pocetku...probaj samo linux gore i treba raditi
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 21.09.2009., 15:28   #23
domy_os
domy_os's Avatar
Postovi: 18,871
Bootaj instalacijski CD s Windows XP-om, obriši sve particije, u BIOS-u uključi AHCI SATA mod i onda bootaj Windows 7.
Staro 21.09.2009., 15:52   #24
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,249
Autor domy_os Pregled postova
ne pomaze.
any other ideas? anybody?
Staro 21.09.2009., 16:01   #25
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
meni se dogadjalo dodje do dijela "setup windows" onaj zadnji plavi ekran prije nego moras s "F8" potvrditi i resetira se jednostavno izbaci nije nista pomogalo...jedino je linux proso bez beda instalaciju
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 21.09.2009., 16:19   #26
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
Na mom 4510s je AHCI def. ukljucen , hard je nije particioniran , tako da tu nema problema, a to su identicni laptopi sam ovaj ima 17 ekran.Sve ostalo je identicno.UGl stavio sam 7-icu bez problema.
@ robi44 "kupi" drugu sedmicu i sprzi ponovno.
Staro 21.09.2009., 16:59   #27
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
nije do sedmice cisto sumnjam u to boot je boot i on ga mora procitat siguran sam da je "kupio" zadnje
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 21.09.2009., 17:49   #28
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Autor fre@k Pregled postova
Jel bi te ubilo da staviš koji zarez? Mislim da nitko osim tebe ni ne kuži di je problem jer se ovo može protumačiti na 1001 način.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 21.09.2009., 18:17   #29
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
boot je boot Ne pricaj ako neznas.I meni se dogadjalo da mi izbaci da nemoze nac neki file prilikom instalacija, i da nece bootat, sa jednom 71xx verzijom, samo sam "kupio" drugu, sprzio ju i radilo je.Ne kosta ga nista probat, i da , dobro su ti rekli : daj pisi kako treba il nemoj nikako.
Staro 22.09.2009., 17:59   #30
nikola8
RiDe Or DiE-O.G.
nikola8's Avatar
Lokacija: cakovec
Postovi: 319
ja imam problema s 5.1 zvukom,logitech z 5500,realtek driveri,podesio sve i sviraju svi zvucnici,ali zadnji ne kako bi morali kao na xp-u,i cudno se cuje zvuk mada sam ugasio sve one stvari,living room itd..sta da probam jos?
nikola8 je offline   Reply With Quote
