#31 |
Lokacija: VG
Postovi: 1,758
TactiX Keyboard & Mouse review 'Alienware TactX Keyboard The Alienware TactX keyboard is a solid gaming keyboard. It has the features and performance available, minus an advanced polling rate feature, to raise the level of any gamer using a standard keyboard to new levels of confidence – great for the task of input and extending control flexibility to new levels during gaming sessions, in addition to performing standard work.' 'Alienware TactX Mouse The Alienware TactX Mouse is a superb gaming mouse in the top class of mice available today. In every aspect – movement and control, ergonomics, design and style, configuration flexibility, and technology – it hits the high mark. In use during games, web browsing, and during document writing and editing the mouse performed with outstanding smoothness, responsiveness, speed, and consistency.' ![]() ![]() Izvor:driverheaven |
#32 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,260
A cuj, 1. ima 41 macro tipku (nevidim da ostale imaju toliko ??)) 2. sve je programibilno + display i po meni dobar design 3. Ima nas Layout tvornicki pa nece biti ljepljenja ČĆŽĐŠ tipki i slicno (http://www.roccat.org/img/ROCCAT/f2b...c18e64edbf.jpg) 4. Veliki Return (mrzim onaj mali takni na nekim tipkovnicama) 5. Tipka "<>" odmah do shifta dolje lijevo koja je meni dosta potrebna bas tu (raidm puno sa shortcutima). 6. Zadovoljan sam sa Roccat driverom za mish pa vjerujem da je i za keyboard dobar a i ako nije decki iz Roccata su spremni na suradnju/prijedloge i uvijek odgovore na mail i zahvale za prijedlog ![]() ...
RS1 - MB: WS X299 Asus Sage, CPU: i7 9800X, RAM:128GB, GPUs: 3*RTX 3090 24GB RS2 - MB:Asus X99-E WS, CPU: i7 6850K, RAM:128GB, GPUs: 2*RTX 4090 24GB Zadnje izmijenjeno od: Lewis. 09.09.2009. u 13:53. |
#33 | |
Leteći medvjedić
Postovi: 1,204
#34 |
Postovi: 397
Neki dan sam malo tipko na toj valo , mogu rec da mi ti tipkovnica odvratna kao da je napravljena od jeftine plastike ali stvarno jeftine , tipke plesu uokolo kao da je silovana bila a nova je , neznam jako sam razocaran s njom ,
Prodajem BEŽIČNI KABEL na metre!!! |
