Staro 01.09.2009., 16:41   #1
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
EVGA X58 Classified 4-Way SLI & EVGA GTX285 Classified
'EVGA is proud to announce the world’s first 4-way SLI capable setup, the EVGA GTX 285 Classified and X58 Classified 4-Way SLI, but the innovative features do not stop there. Everything on the GTX 285 Classified is designed for the extreme enthusiast, from the 8 Phase Digital PWM to the X-Cool Switch and Dedicated Voltage readpoints! These features and more allow you to do what matters; get the most from your hardware.
In addition to this innovative graphics card, EVGA is also announcing the EVGA X58 Classified 4-Way SLI Edition, this motherboard has an impressive 7 PCIe Expansion slots allowing you to combine up to 4 EVGA GTX 285 Graphics cards for extreme performance! Important note: a case with 9 or more expansion slots is required, 10 for 4-Way SLI.
* GeForce GTX 285 GPU
* 4-Way SLI Support
* 8 Phase Digital PWM
* Low ESR/ESL Film Capacitor
* X-Cool jumper for Extreme OC
* 3 PCIe 6 pin power connectors
* Dedicated Voltage Read Points
* EVGA EVbot support
* Intel® X58 Express Chipset with the ICH10R Southbridge
* 7 PCIe Slots for 2-Way, 3-Way, 4-Way SLI or CrossFireX Support
* 10 Phase Digital PWM with Switching Frequency of 1333KHz
* 100% Solid State Capacitors
* EVGA E-LEET Tuning Utility Software
* EVGA EVbot Support
* EVGA ECP V2 (EVGA Control Panel)'
Izvori:guru3d; evga.com
bluefluid je online   Reply With Quote
Staro 01.09.2009., 17:10   #2
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Bolesno.
timmy je offline   Reply With Quote
Staro 01.09.2009., 17:48   #3
maX
maX's Avatar
Postovi: 7,326
Prebolesno. Baš me zanima koliko će se trebati keširati za takvo nešto.
Staro 01.09.2009., 17:53   #4
Razer
Razer's Avatar
Postovi: 11,642
Piše ti ploča 450$ i kartica po 380$, pa baci računicu...2000$ samo ploča i 4 kartice...
Staro 01.09.2009., 17:54   #5
Nybelung
Znači, kod nas 2000 eura?
Staro 01.09.2009., 17:56   #6
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Nece tak sta biti kod nas...
Nemamo mi rvati za tak sta
Campeonato je offline   Reply With Quote
Staro 01.09.2009., 18:01   #7
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
jel crossfireX najvise ide do 4 gpu-a, jel?
Staro 01.09.2009., 18:02   #8
maX
maX's Avatar
Postovi: 7,326
Autor Razer Pregled postova
Mislio na to koliko će se kod nas trebati keširati za to
Staro 01.09.2009., 18:05   #9
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
a sigurno jedno 3-3,5k za mbo i cca 2800-3000 za karticu... ne bi se uopce cudio da budu takve cijene... samo da, nece to ni bit kod nas jer se nikome nece isplatiti to uvest pa drzat na lageru jer nece moc prodat
Staro 01.09.2009., 18:05   #10
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
A min 1000 ojera...
@bluefluid
mislim da jest..
Staro 01.09.2009., 18:07   #11
Nybelung
Ma sve su ovo igračke za djecu.. Kad ono izlazi HECTO-SLi?
Staro 01.09.2009., 21:23   #12
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Ovo je prebolesno. Mogao bih reći, pretjerivanje.
Flikoman je offline   Reply With Quote
Staro 01.09.2009., 21:29   #13
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
S.I.C.K.
Stvarno, više ide na pretjerivanje nego na korist.
blaa
Staro 01.09.2009., 21:36   #14
LUXX
Vodenjak :)
LUXX's Avatar
Lokacija: Križevci
Postovi: 667
Ma uvjek ce bit ljudi koji ce kupit plocu ili grafu te cijene.
Ili cak zajedno.
Samo plocu + 4 te grafe??
U Hrvatskoj?
Moj tata mi to nebu kupil
LUXX je offline   Reply With Quote
Staro 04.09.2009., 23:48   #15
T0X1C
n00b
T0X1C's Avatar
Postovi: 246
Ma ovo se jedino isplati ukrast u trgovini
T0X1C je offline   Reply With Quote
Staro 05.09.2009., 11:00   #16
stopalo9
stopalo9's Avatar
Postovi: 763
Di ovo ide..
stopalo9 je offline   Reply With Quote
Staro 05.09.2009., 12:01   #17
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Jedino sto mi na ovoj ploci izgleda "normalno" je to sto su svi slotovi 16x pa ti sebi nabodi sta u koji hoces.
Sve ostalo je...hmmm...visak?
