Staro 31.08.2009., 22:38   #1
LynkS
LynkS's Avatar
Postovi: 49
Problem sa spajanjem rutera (pptp)
Router je micronet sp888bp, kabelski modem scientific atlanta 2100.
Ne mogu natjerati router da radi preko pptp protokola. Sve je uredno radilo preko ppoe.
U uputama za spajanje na bnetovim stranicama (http://www.bnet.hr/cro/content/downl...203DCARNet.pdf), za router Canyon CN-WF514, sučelje za postavke routera identično je ovome mome i po tim sam uputama namještao, no bez uspjeha. Ima tko kakvih korisnih informacija, i da li je uopće moguće podesiti ovaj router da radi preko pptp protokola?
copy-paste system loga:
Jan 1 00:00:22 udhcpd: udhcp server (v0.9.9-pre) started
Jan 1 00:00:28 udhcpc: udhcp client started
Jan 1 00:03:09 udhcpd: sending OFFER of 192.168.2.100
Jan 1 00:03:09 udhcpd: sending ACK to 192.168.2.100
Jan 1 00:03:17 udhcpd: sending OFFER of 192.168.2.100
Jan 1 00:03:17 udhcpd: sending ACK to 192.168.2.100
Jan 1 00:05:16 udhcpd: udhcp server (v0.9.9-pre) started
Jan 1 00:05:32 udhcpc: udhcp client started
Jan 1 00:06:39 udhcpd: Received a SIGUSR1
Jan 1 00:06:41 udhcpc: Sending select for 10.63.217.226...
Jan 1 00:06:41 udhcpc: Lease of 10.63.217.226 obtained, lease time 43200
Jan 1 00:06:42 udhcpd: Received a SIGUSR1
Jan 1 00:06:46 syslog: anon log[mainptp.c:219]: The synchronous pptp option is NOT activated
Jan 1 00:06:46 syslog: anon log[pptp_dispatch_ctrl_packetptp_ctrl.c:630]: Client connection established.
Jan 1 00:06:53 syslog: anon log[callmgr_mainptp_callmgr.c:236]: Closing connection
Jan 1 00:06:53 syslog: anon log[pptp_conn_closeptp_ctrl.c:357]: Closing PPTP connection
LynkS je offline   Reply With Quote
Staro 01.09.2009., 02:55   #2
thopok
Lokacija: Splity
Postovi: 3,003
Čini se, po već prije napisanom, da ne treba mnogo očekivat.
Čak ni ovaj operator nije uspio s nekim uređajima, dok je druge trebalo "fino podesit".
Staro 01.09.2009., 12:17   #3
LynkS
LynkS's Avatar
Postovi: 49
Autor thopok Pregled postova
Znaš li možda neki jeftiniji router, a da provjereno radi na bnetu sa pptp-om?
Staro 03.09.2009., 13:42   #4
thopok
Lokacija: Splity
Postovi: 3,003
Pa upravo u njima i jest problem.
Autor Red_Baron Pregled postova
Malo sam zbunjen.
Znači ne podrazumijeva se da svaki ruter podržava i PPTP i PPPOE?
Može još jednom za nas glupe Koji je najjeftiniji ruter koji provjereno radi i sa jednom i drugom gore navedenom kraticom (što god one značile) a da ne treba imat sreće da ga se uspješno iskonfigurira za rad u wlan mreži sa tri računala
Staro 04.09.2009., 02:36   #5
BukYMast3R
BukYMast3R's Avatar
Lokacija: Novigrad / Zagreb
Postovi: 82
Autor LynkS Pregled postova
Isti problem kod mene (još uvijek), uređaj WRT54GL. Oni garantiraju da bi trebalo sve uredno raditi na uređaju WRT54GC.
BukYMast3R je offline   Reply With Quote
Staro 04.09.2009., 08:42   #6
Postovi: 23,508
Ja na tu priću gledam ovako:
Kada od xy uređaja jedva 1 radi onda nisu uređaji krivi i loše napravljeni nego dotični ISP koji nezna / namjerno ne želi da "stvar" funkcionira.
Također je indikativno da uređaj koji je baziran na linuxu (GL) bilo origigi ili DD-WRT a po "prijavi" kolega ne radi a GC verzija jedva radi.
Staro 04.09.2009., 09:23   #7
Armand
192.168.0.1
Armand's Avatar
Lokacija: BiH
Postovi: 463
Autor Nikky Pregled postova
Potpisujem
P4 3.0 Prescott (Zalman 7000b-cu) @ Gigabyte 8ik1100
2x512 Apacer ddr400
AiW x800xt + vf900
Hitachi 80gb Sata2
Corsair HX520W
Linksys WRT54GL@Tomato 1.25.8515 RAF (Victek Mod)
Armand je offline   Reply With Quote
Staro 05.09.2009., 18:38   #8
Triix
Postovi: 1
Autor BukYMast3R Pregled postova
Pozdrav,
upravo sam sredio PPTP konekciju na WRT54GL, pa sam odlučio to podijeliti s ostalima koji imaju taj problem.
...zato sam se i registrirao na forum jer mi je pun k. ISP-ova i njihovih nesuvislih obrazloženja, loših/nepotpunih tehničkih uputa itd., svi su ISP-ovici isti
Slijede koraci kako sam radio.
Modem: EPC 2203
Router: Linksys WRT54GL V1.1 - orginal FW v4.30.11
ISP: Bnet
1. Prvo sam provjerio da li mi konekcija radi direktno iz Windoza. Napravio sam prema uputstvima Bnet-a. ( Upute za spajanje 3DCARNet )
1.a.) Isključio sam modem iz struje ( maknuo napajanje ) - bar 5 minuta ostaviti da bude iskljućen. Jer je prvobitno bio spojen s router-om.
1.b.) Spojio komp i modem LAN kabelom, uključio modem, pričekao da se podigne.
1.c.) Napravio konekciju i spojio se na net. Stvar radi!
Nisam previše sumnjao da neće raditi, ali imam dva kompa koja moraju na net samostalno bez konekcija i ostalih zajebancija.
2. Provjerio sam IP modema - kod mene je 192.168.100.1
Zapisao IP koji sam dobio prilikom konektiranja - IP 10.63.x.x
Oba IP-a će trebati kasnije.
3. Korak je ponovno gašenje modema na 5 minuta.
3.a.) U međuvremenu sam postavio router na isti subnet kao modem - postavio sam IP routera 192.168.100.10
3.b.) Spojio sam modem i router ( router je bio upaljen ), uključio modem i pričekao da se podigne.
4. Na routeru sam podesio PPTP konekciju. Upisao IP koji sam dobio prilikom direktnog spajanja - IP 10.63.x.x. Za subnet sam upisao 255.0.0.0, a za gateway 10.64.0.1 - postavljen od Bnet-a.
5. Nakon spremanja postavki stvar mi funka!!!
Oba kompa preko wireless-a idu na net i sve radi kao što je i radilo na PPPOE.
Drago mi je ako sam uspio nekome pomoći.
Triix
Zeitgeist Movment
http://www.zeitgeisthr.com/
Triix je offline   Reply With Quote
Staro 05.09.2009., 19:26   #9
LynkS
LynkS's Avatar
Postovi: 49
Autor Triix Pregled postova
P....
Sorry što pitam gluposti, ali kako da provjerim ip modema? Da li je to 192.168.2.100 u mom slučaju (vidio gore onaj log u prvom postu)?
Staro 05.09.2009., 20:02   #10
Postovi: 23,508
Postavi mrežne postavke na Automatic, sačekaj malo, otvori CMD, upiši ipconfig /all, pronađi mrežnu u izlistanom i pod Gateway je IP adresa routera. U manualu stoji da da mu je defaultna IP adresa (znači ako je nisi sam mjenjao) 192.168.1.1.
Staro 08.09.2009., 02:59   #11
thopok
Lokacija: Splity
Postovi: 3,003
Eto problema.
