Povratak   PC Ekspert Forum > PC Ekspert > Članci
Staro 23.07.2009., 18:33   #151
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,763
itekako,
ako ga nisi dobro pričvrstio
E-mil je offline   Reply With Quote
Staro 23.07.2009., 23:55   #152
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor e1ectra_one Pregled postova
jel moguce da je sa Scythe Musashi.em temp 4890 preko 100 °c na jezgri
Nema šanse,vjerujem ni sa 1GHz verzijom u loadu pod krizom temp. nebi prelazila 65-70C.
Pod furmarkom na, 1280x1024,extreme burning, no AA i rename-anim furmark.exe bi išlo vjerovatno i to samo na 1GHz verziji.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 26.07.2009., 01:48   #153
e1ectra_one
Creepshow
e1ectra_one's Avatar
Postovi: 417
ma riješeno vec, pomaknio mi se kular malo i onaj komadić bakra. svanio novu pastu i radi sve 5
e1ectra_one je offline   Reply With Quote
Staro 26.07.2009., 22:16   #154
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Kaj, tako je dobar da ga već prodaješ?
Staro 27.07.2009., 10:29   #155
e1ectra_one
Creepshow
Postovi: 417
Autor Gilbert5 Pregled postova
ma nestane mi u kučište
Staro 27.07.2009., 16:13   #156
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,763
a koje to kućište imaš ??
ako se smije znati
Staro 27.07.2009., 23:10   #157
e1ectra_one
Creepshow
Postovi: 417
Autor E-mil Pregled postova
ako se smije znati
armor jr.
Staro 09.08.2009., 18:11   #158
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Par pitanjca:
Jer se isplati kupiti musashija ili cekati Setsugena? Da li je montaža komplicirana? Koliko je cijela kartica deblja kad se stavi musashi u odnosu na stock cooler? Da li je onaj limić koji drži vent skroz na kartici ili nije?
Pozdrav.
P.S. Molim sve odgovoriti Znam da su neki odgovori bili prije, ali neki i nisu.
fran123456 je offline   Reply With Quote
Staro 09.08.2009., 18:30   #159
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Autor fran123456 Pregled postova
Par pitanjca:
Pozdrav.
Da postaviš prava pitanja možda bi i dobio odgovor.
U odnosu na koji stock cooler? Od 8800GT ili od GTX260?
Cooler zauzima 2 slota, tako da je deblji od stock coolera recimo referentne 8800GT
Setsugen je namjenjen za GTX2xx kartice, ali sigurno će ići i na starije. Pitanje je kolika će mu biti cijena
Montaža Musashia nije komplicirana, no vjerovatno nije ni lagana kao npr Zalmanova (koji ima daleko najbolje montaže za VGA cooler koje sam osobno vidio)
O čemu ti?
blaa
Staro 09.08.2009., 19:18   #160
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
U odnosu na referentni hd4870 cooler.
Limić - http://www.scythe-eu.com/fileadmin/S...uttle/H7-1.jpg
Zanima me da li je taj "limić" skroz na kartici ili ima mali razmak između kartice i tog lima?
Staro 09.08.2009., 20:01   #161
IMunic
Datum registracije: Jul 2009
Postovi: 13
moguce je da ima spuzvu slicnu ko na mugenu2 da ne dira karticu direkno, no nebi znao rec sa sigurnoscu...
IMunic je offline   Reply With Quote
Staro 09.08.2009., 20:12   #162
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
Pa razmislite malo, kako bi kartica funkcionirala da lim dira elemente na kartici ??
Ima po sredini gumeni "čep" koji se spoljštava kako se kartica zateže šarafima.
stuc je offline   Reply With Quote
Staro 12.08.2009., 11:03   #163
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Kako ste vi uspjeli skinuti redplate? Ja lagano skinem cooler, tri šarafića od replatea, ali ostala 3 se nedaju.
Staro 12.08.2009., 13:12   #164
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,239
bemti musashija. kupio ga jucer al nikako ga natjerat da ohladi hd4890 kako treba. kad ju dignem na 930/4600 zroka se ubrzo. na stock cooleru je mogla izdrzat.
probao sam sa i bez onog bakrenog limica sto sjeda izmedju jezgre i coolera i nema neke drasticne razlike.
stavio sam jezice na sve zivo, di god sam mogo ih stavit.
ima netko jos koju ideju? neznam sta bi jos isprobao
btw, trenutno idle-a na def. clocku na 51/59/54/55C (gpu/memorija/shader/vddc) sto je po meni puno buduci da su oba venta na max okretajima
Staro 12.08.2009., 13:45   #165
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Autor Čuks Pregled postova
Stavi redplate ako ga uspijes skinut. Ja ga nisam uspio, no ako ga ti uspijes, svaka ti cast. Mislim ic do Linksa i dat da mi skinu ta 3 sarafa.
Staro 12.08.2009., 21:12   #166
ivan77
da li je neko musashija probao u praksi na Gigabyte 4850? Ima li kakvih problema , na nešto posebno što treba obratit pažnju? Jer onaj gigabyte stock "urla" na 75-90%..
Staro 12.08.2009., 21:34   #167
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Autor ivan77 Pregled postova
Ako hoćeš da ti se cooler drži što bolje drži stavi bakrenu pločicu. VRM ti sigurno neće biti hladniji ako imaš stock cooler (crveni) i ako ne staviš redplate.
Staro 12.08.2009., 21:49   #168
ivan77
kakvu sad bakrenu pločicu? Slika? Za red plate sam skužio al odakle sad bakrena pločica?
Staro 12.08.2009., 22:56   #169
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,239
kod mene je na xfx-u jebeni heatsink zajedno spojen na stock plate, tak da mogu jedino potrgat da to skinem.
da bar imam sarafe, nekako bi ot vec rijesio
Staro 12.08.2009., 23:37   #170
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Može pic? Inače, trgaj
Staro 12.08.2009., 23:43   #171
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,239
Staro 13.08.2009., 15:29   #172
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Imaš više opcija: Trgat taj cooler, prodat musashija na trznici, ili ostavit kako je. No, ako nemas barem 2 venta u kućištu, zaboravi na onakve temperature kakve nalazis na netu, tu ti neće ni stock plate pomoć. Očekuj dizanje svih temperatura u kućištu za barem stupanj.
Staro 14.08.2009., 00:06   #173
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,239
sve su prilike da cu ga il prodat il mjenjat, budem jos vidio dal ce prelazak na twin turbo pomoc
Staro 14.08.2009., 12:38   #174
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Nece, sigurno. Jedino na S1.
Staro 14.08.2009., 12:44   #175
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,239
kaj s1 pase na 4890?
mislio sam potrazit red plate za 4890 na trznici,
neznam dal pase redplate od 4870?
Staro 14.08.2009., 13:57   #176
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Nitko ti nece prodat redplate, svima treba Accelero S1 ide na hd4890.
Staro 14.08.2009., 15:31   #177
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,239
da, ide, al nist bez redplate-a. u ku*ac.
zalman je napravio cooler za vrm-ove, za 4870/90 , samo ga kod nas nema nigdje za nabavit, steta.
http://www.zalman.co.kr/ENG/product/...ad.asp?idx=352
morat cu se bacit u nabavku red plate-a, mozda pronadjem
Staro 14.08.2009., 16:47   #178
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
To ti ne pomaze puno, jedino redplate. Iako, ja bi dao cooler u servis i trazio da ti skinu plate.
Staro 15.08.2009., 01:57   #179
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,239
ovaj se neda skinut. nema nikakvih sarafa nit iceg. svarno neznam kako su ga slozili.
Staro 15.08.2009., 15:12   #180
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Ma i musashi i twin turbo su slabi kuleri, tj slabi su kad je u pitanju veća kolićina energije, jednostavno ne stignu hladit, premalo pajpova imaju!
Twin turbo sam imal na GTX+ i bio je bolji od referentnog samo kaj se buke tiće, u loadu su čak bile i veće temp! Onda znaš kak bude na 4890!
Moral buš za 4890 potražit nekaj jačeg i onda bude to to!
danc00 je offline   Reply With Quote
