Datum registracije: Aug 2009
Postovi: 6
Problem s HP Pavilionom
Pozdrav svima,evo ovako,imam problem sa hp pavilioonom 8000t racunalo je kupljeno u nekoj azijskoj drzavi,neznam sad tocno kojoj,Singapur,Tajvan,i uz normalna slova ima i njihove znakove. uglavnom ovo je sta se nalazi u njemu ExpressCard/54 Slot (also supports ExpressCard/34) 1 Type I/II 32-bit card bus (also support 16-bit) 1 IEEE 1394 Firewire Port 4 Universal Serial Bus (USB 2.0) TV-Out (S-video) Integrated Consumer IR (remote control receiver) Microphone in 1 modem port (telephone) 1 Expansion Port 2 Connector 1 Ethernet port 1 VGA port Built-in Altec Lansing stereo speakers ExpressCard/54 Slot (also supports ExpressCard/34) 1 Type I/II 32-bit card bus (also support 16-bit) instaliro sam na njega win xp + sp2 i iso na http://h20000.www2.hp.com/bizsupport...468&taskId=135 po drivere no kad bi instaliro drivere za graficku,ili ta mrezu poco bi mi izbacivat Data Execution Prevention feature (DEP) pokuso sam sljedece da se toga rijesim 1. Click Start 2. Select Control Panel 3. Select System 4. Click the Advanced tab 5. In the Performance region select Settings 6. Click the Data Execute tab in the dialog box that opens 7. Select Turn on DEP for all programs and services except for those I select 8. Click Add. 9. The open dialog box will open. Browse and select your application. 10. Click Open 11. Click Apply 12. Click Ok 13. Reboot ali posto mi dep dolazi kad pokusam ic u add i remove programs i u cdm i u jos neke stvari pokuso sam ikljucit error reporting u msconfigu ali i dalje nije radilo drivere za nvidi-u sam skinuo sa sluzbene stranice neznam zasto se pojavljuju dep upozorenja,ako mi neko moze to pojasnit bio bi zahvalan,ili ako me neko moze uputit na neko mijesto di mogu nac neke kompitabilne drivere za ovu verziju laptopa. drugo imam gericomov laptop kupljen u njemackoj ne radi cd room pokusao sam bootat sa usb sticka imam dvije opcije boot from sub fdd i boot from usb rmd-fdd imam bootable usb stick sa linuxima koji radi na ostalim pc-ima,probo sam obadvije opcije u kombniaciji sa svim portovima,i ne zeli ga bootat, je moguce da nece bootat radi linuxa?ili je nesto drugo u pitanju? ako imate kakvo rijesenje bio bi8 vrlo zahvalan trece imam winbond isdn pc card 491-00011-04 nakon malo googlanja naso sam drivere za nju ali kad ih instaliram na sistemu sa win xp+sp2 sve se zamrzne svaki prijedlog po tom pitanju je dobrodoso,link sa driverima koji sljakaju,neki nacin da ovi prorade itd itd hvala! |
Postovi: 33,926
1. Koliko vidim, postoje modeli sa Intelovom integrušom i sa nvidia grafičkom. Pitanje je koji ti model uopće imaš. Na doljnjoj strani, na naljepnici se uz ime modela nalazi i jedan kod koji zapravo više govori o samom modelu. Taj kod je najčešće u obliku 2 slova+3 brojke+2 slova. Nađi to i napiši koji je da možemo dalje. Primjer: svi ovi lapovi imaju isto ime, ali razlika u kodu daje razliku i u opremljenosti i samoj konfiguraciji. Kontaš? http://www.nabava.net/trazilica.php?q=hp+4510&x=0&y=0 2. mislim da je problem u tome što BIOS ne raspoznaje baš najbolje usb stickove. Šta napraviti? Izvadi hard, spoji ga na neki komp i instaliraj winse na njega (SAMO winse BEZ ikakvih drivera!). Vrati ga nazad u lap i dovrši instalaciju sa driverima i programima. 3. Winbond je proizvođač čipova, a ne isdn kartica tako da je vrlo upitno jesi li stavio dobar driver na nju. Daj link za taj driver jer gugl izbacuje samo 4 rezultata. Ako ti je baš potrebna isdn kartica (za što?), imam ja par komada u ormaru pa ću ti jednu pokloniti.
Postovi: 6
evo ovako dole pise s/n cnd6274xnh p/n re345ea#abv dv8393ea warranty 1 year ok,ovo drugo cu napravit,hvala puno ma doboro ovo za isdn karticu nije bitno,naso sam tu,na kojoj nista nista ne pise osim winbond,ali izgleda da je to cip :-),i jos jednu etherlink 3 pise 94-ta ali mislim da je iz 97,pa sam htio vidjet dal ce radit.ustvari mi za nista ni ne treba samo sam bio radozano hvala jos jednom na pomoci |
Postovi: 33,926
Podaci o HP-u http://h10025.www1.hp.com/ewfrf/wc/d...reg_R1002_USEN Driveri 1. za grafu koristi SAMO nvidijine, a ne i Intelove, 2. instaliraj MS UAA driver prije Conexant Audio drivera, nakon instalacije MS UAA HD napravi restart i tek onda Conexant 3. modem je vezan na audio drivere tako da njega staviš tek nakon audia http://h10025.www1.hp.com/ewfrf/wc/s...roduct=3216295
Postovi: 6
hvala.puno,ovo mi je pomoglo,idem instalirat |
