Staro 04.08.2009., 13:38   #1
eXit
Lokacija: Brdovec City
Postovi: 7
DVI problem
pozz, frend je kupio LG 20" monitor -http://www.magazinrs.hr//artikl.asp?code=W2043T-PF, ima dvi-d ulaz ali ne pase na grafu ulaz jer od grafe je obican dvi valjda, pa ga zanima jel postoji neki konektor il bilo sta sto bi mogo stavit na grafu u taj dvi a da s druge strane dvi-d kabal ulazi
http://img109.imageshack.us/img109/1...ubsizedyw0.jpg
kaze da je ulaz slican ovom al nema 8 nego ima 3 pa razmak pa 3 rupice...
Zadnje izmijenjeno od: eXit. 04.08.2009. u 13:53.
eXit je offline   Reply With Quote
Staro 04.08.2009., 14:09   #2
Wolverine
Wolverine's Avatar
Postovi: 12,425
pa kaj onda ovo na slici je DualLink DVI-D a on ima SingleLink DVI-D
ide unutra bez problema osim ako hoće ugurat DualLink kabel u SingleLink DVI-D
evo slika
http://www.interfacebus.com/Design_C...e_DVI_Bus.html
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 04.08.2009., 14:22   #3
eXit
Postovi: 7
veli da je od grafe Dual Link DVI-I, a od monitora Single link DVI-D
i pita dal ovo treba mozda?
http://www.mcmelectronics.com/product/83-9870
Staro 04.08.2009., 16:19   #4
Wolverine
Wolverine's Avatar
Postovi: 12,425
ne treba ništa ako je kabel od monitora SingleLink DVI-D
fino ga ušteka u grafu i to je to
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 04.08.2009., 16:44   #5
Postovi: 23,510
Po ovom LG W2043T-PF User manual - u na monitoru je (po slici a i po textu) Dual Link DVI-D.
Nisi dobro definirao kakav je konektor na grafičkoj, vjerojatno Single Link DVI-I ili DVI-D (ima 3 pa razmak pa 3 rupice).
Ako imaš DVI-I kabel, njega nemožeš uštekat jer "smetaju" pinovi (vidi slike u linku iz 2. posta).
Tebi treba CC GMB DVI-D Monitor kabel 3m, Single Link 2xDVI-D M
Staro 04.08.2009., 17:51   #6
Wolverine
Wolverine's Avatar
Postovi: 12,425
kartice obično imaju DulaLink DVI-I i u njih možeš uštekat svaki DVI konektor
treba mu običan SingleLink DVI-D kakv je ziher i dobio uz monitor jer DualLink ne treba za rezoluciju koju ima taj monitor
fakat ne vidim di je problem
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
