Staro 13.07.2009., 16:07   #3451
doorman
weliki pwner...
doorman's Avatar
Lokacija: čakovec
Postovi: 131
GTA IV & driving force pro
bok ljudi imam jendo pitanje kako da igram gta IV s ovim gore navedenim volanom? treba nekaj posebno podesavati? jer ako samo ustekam ne radi... a ne vidim nigde nikve postavke!
hvala
modovi ako je tema stavljena krivo sry, premjestite ju!
hvala
CPU: Intel Core 2 Duo E6300
MBO: Gigabyte 945P-S3
RAM: 2X1GB KingMAX i GoodRAM
GPU: ATi Radeon X1600
HDD: Hitachi HDP725025GLA380 (250 gb) & Hitachi HDT722516DLA380 (160 bg)
OPT: nec dvd r/rw
PSU: chieftech 440w
OS: Windows XPSP2 & Vista
Rijeci su isto kao i gomile ljudi, nije nuzno znati za sve...
J. B. Štulić
doorman je offline   Reply With Quote
Staro 13.07.2009., 17:51   #3452
STOPMessages
Datum registracije: May 2009
Postovi: 39
Problem sa instalacijom
Evo ovako instalacija krene i instalira gta social club i onda krene da bi mi igru instalirao i onda dolazi do problema tocno kaze ovo: "Your system is incompatible with %P"???? Nekuzim
Only God can judge Me!!!
STOPMessages je offline   Reply With Quote
Staro 13.07.2009., 18:14   #3453
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor STOPMessages Pregled postova
Stvarno teško : http://tinyurl.com/lp96kw
Hi guys!
I also had such problem a few minutes ago, but i found the solution..)))
I just wanted to help u loosers, that is why i regestred here So:
1) You don't need XP... just use Vista!
2) Go to the options of the setup.exe on your GTA disc.
3) Choose rhe compatibility options there.
4) You need to tick the field with Windows XP (SP2) and accept changes.
5) Say thank you to Great Britain, where i live now.
6) Say thank you to Russia, the country where i came from.
7) Enjot the new GTA, with russian guy as a main hero
God bless mr. Putin!!!
...by the way, the installation is fuckingggg long)))
Staro 13.07.2009., 18:30   #3454
STOPMessages
Postovi: 39
Svaka ti dala
Staro 14.07.2009., 11:03   #3455
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,281
kolko ja znam Niko nije rus.....
"I intend to live forever. So far, so good."
job security - example
rodney je offline   Reply With Quote
Staro 14.07.2009., 11:29   #3456
Reedy
Reedy's Avatar
Postovi: 770
Balkanac ;-)
Reedy je offline   Reply With Quote
Staro 14.07.2009., 18:51   #3457
Ementaler
Ementaler's Avatar
Postovi: 133
Kako bi bilo fino da imamo ovo na PC-u, a dečki?
GTA 4 - The Lost And Damned
To je ona prva od najavljene 3 ekspanzije za GTA 4. Xbox 360 ekskluzive. Probao sam igrati malo i stvarno je jedna od najboljih epizodnih dodataka koje sam vidio. Dosta novoga sadržaja i apsolutno zanimljiviji grad postane...
Moguće da nakon što sve tri ekspanzije izađu za Xbox 360, da će se izdati sve tri u nekom packu i kao PC ekspanzije. Ipak je Games for Windows naslov, a Microsoft stoji iza Xbox 360 ekskluzivnosti ( koja bi u ovom slučaju o kojem pričam bila samo vremenska ekskluzivnost )... nada postoji!
Manuel Calavera: I just locked an open door... strange, yet symbolically compelling.
Ementaler je offline   Reply With Quote
Staro 15.07.2009., 13:10   #3458
zdvd
Datum registracije: Mar 2009
Lokacija: split
Postovi: 9
Zadnje izmijenjeno od: tor. 18.07.2009. u 21:30.
zdvd je offline   Reply With Quote
Staro 15.07.2009., 13:20   #3459
Reedy
Reedy's Avatar
Postovi: 770
ne vjerujem jer svi imamo original
Staro 15.07.2009., 13:24   #3460
Nybelung
Ili nešto radiš pogrešno ili si dobio loš primjerak..
Javi se na support.rockstargames.com oni bi ti trebali pomoći, ipak je to njihov proizvod..
Staro 15.07.2009., 13:53   #3461
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
skinuo kažeš?probaj pitat Tor-a šta on misli o tome?mogao si malo diskretnije priopćit odakle ti igra.
i btw. igra radi fino i na xp-u.samo mora biti sp3.u biti nemora, može biti i dvojka samo se u registriju moraju postelat neke stvari da ga vidi ko trojku.
Zadnje izmijenjeno od: sinisa1989. 15.07.2009. u 20:27.
Staro 15.07.2009., 18:40   #3462
zdvd
Lokacija: split
Postovi: 9
Staro 15.07.2009., 18:54   #3463
Baja 001
Baja 001's Avatar
Postovi: 7,504
Staro 15.07.2009., 19:01   #3464
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
Stvarno čudno...
Ja kad sam kupio igru nisam morao otpakirati sa winrarom
meni je sve normalno radilo... a sta spominjes ovaj krek ? pa to se ne dobi... ja to na dvdu od igre nemogu nac ..
pomoc ?
xD
ehehhe Dirigent
~Kaiser_Chief~ je offline   Reply With Quote
Staro 15.07.2009., 20:26   #3465
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
kako se nikom neda čitat.ja sam naučio na teži način da se moraju čitat pravila
Staro 15.07.2009., 23:14   #3466
Reedy
Reedy's Avatar
Postovi: 770
evo, samo da podjelim svoja iskustva s GTA IV. Znači fino mi radi, konačno sve fixiro itd... ugl...Eto, došao ja do one misije di moram izabrat ubit Dmitrija ili natrag radit za njega... Išao sam ga ubit, dakle dođem na onaj brod, sve ih pokoljem, otvorim si ona vrata dolje, skočim unutra, ubijem ih nekoliko, i onda mi ja specijalac oču bacit bombu i sam sebe raznesem, kad je bacio koda je kilav... i ja se razj*** u P.M, natrag moro sve ispočetka, ali mi se nije dalo pa sam išao na onu misiju da radim natrag za njega i dobio brdo love ... sve super, zatim ubiju romana tamo na vjenčanju, i onda idem s Little Jacobom ubit ovog Dmitria, i onda najprije sljedim neki šugavi auto 30 min, onda dojdem tam do ovih likova, par puta me pobiju, ajde idem natrag, i natrag sam išao par puta, i pobijem ih, dođem do broda, par puta me raznesu bazukom kad sam pratio dok su se vozili helićem, i onda sam probao 5x...a naravno pizdim ko luuud.... i onda gle čuda, nisu me pogodili, 6x sam imao sreće zatim dojde Little Jacob s svojim helićem, i onda ih još moram s helićem pratit, i onda sam se tamo polomio, i onda vidim sve ispočetka ja u bolnici, onda sam popizdio al ono... ko zvjer sam bio lud.................. ijaooo...... isssss.................... aaaaaaaaa......... ugl... glavna stvar je da sam slomio kad sam to radio subwoffer... udario sam ga punim šusom pao je dolje na na pod i više nije radio, i još su se neki kabli rastrgali kad je palo... itd... i kako se nekom isplati igrat GTA IV ....
BTW... ima li možda ko game save iza te misije??
Staro 16.07.2009., 09:10   #3467
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
xGAME je offline   Reply With Quote
Staro 16.07.2009., 09:20   #3468
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
ma to je vec bilo receno, cak postoji i tema.....
nadam se da ce cudo biti optimiziranije, jer ovu cetvorku nisam dovrsio do kraja bas zbog toga...
jednostavno skoro nikakve razlike izmedu low i high osim sta na high nemogu vrtit
tj. nisam mogao...
bas bi mogao probati, sad kad je nova grafa tu..
Staro 16.07.2009., 15:45   #3469
STOPMessages
Postovi: 39
Staro 16.07.2009., 15:49   #3470
Speedbreaker
Postovi: 545
Autor ~Kaiser_Chief~ Pregled postova
tj. nisam mogao...
mislim da nećeš vidjeti poboljšanje u performansama.
procesor te koči.
Speedbreaker je offline   Reply With Quote
Staro 16.07.2009., 16:43   #3471
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
Autor Speedbreaker Pregled postova
procesor te koči.
tocno to... nakon malo razmisljanja necu ni probavat... proc je i prije bio na 100% tako da...
Staro 17.07.2009., 12:49   #3472
zdvd
Lokacija: split
Postovi: 9
Staro 17.07.2009., 13:05   #3473
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
da, treba ti originalni key
Staro 17.07.2009., 18:35   #3474
zdvd
Lokacija: split
Postovi: 9
Zadnje izmijenjeno od: tor. 18.07.2009. u 21:31.
Staro 17.07.2009., 18:45   #3475
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
kupiti ga...
tko bi rekao da ovo modovi ne gledaju...
mozda i gledaju pa se smiju
Staro 17.07.2009., 18:53   #3476
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
Autor zdvd Pregled postova
kako do orginalnog kljuća doći ?????
koje pitanje?pa vjerojatno da bi došao do originalnog ključa moraš kupit igru.
kolega trebal bi si malo pročitat pravila postanja na ovom forumu
Staro 17.07.2009., 18:53   #3477
zdvd
Lokacija: split
Postovi: 9
moželi netko pomoći !!!!???
Staro 17.07.2009., 19:01   #3478
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
evo ti link : http://www.gamestop.com/Catalog/Prod...oduct_id=72574
skini od tud.. ostalo ce doc postom ako se ne varam
Staro 17.07.2009., 19:01   #3479
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
moraš kupit igru.ako hoćeš igrat na taj svoj način preko postova ništa samo preko PM-a
Staro 17.07.2009., 23:30   #3480
DanielDJ
DanielDJ's Avatar
Lokacija: Đakovo
Postovi: 250
GTA IV - a ako nezelis narucivat iz amerike ima i u nasim trgovinama.
DanielDJ je offline   Reply With Quote
