Zaključane teme
Staro 30.06.2009., 09:49   #1351
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
pozdrav,
da ne zujim previše po webu ima možda netko nekakav link na kojem su navedeni lapovi na koje može ici hekintoš?
Lp
Hamm je online
Staro 30.06.2009., 09:55   #1352
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,127
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
^SuperUnknown^ je offline
Staro 30.06.2009., 09:56   #1353
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
e to...hvala
Hamm je online
Staro 03.07.2009., 21:41   #1354
Shuky
Shuky's Avatar
Postovi: 683
ima li itko da mu radi hackintosh na windowsima, ala wmvare?
treba mi da programiram tamo gdje imam samo windowse...
Shuky je offline
Staro 05.07.2009., 12:57   #1355
Mac_F
Pauk mrežar
Mac_F's Avatar
Lokacija: Zagreb (Bjelovar)
Postovi: 278
To ti baš i ne radi glatko.
PCAP or it didn't happen
Mac_F je offline
Staro 07.07.2009., 12:18   #1356
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor Shuky Pregled postova
Postoji
Autor Mac_F Pregled postova
da radi
moj komp..intel konfiguracija..vmware workstation 6
Hamm je online
Staro 07.07.2009., 15:03   #1357
Killer_99
Ubojito stvorenje
Datum registracije: Apr 2008
Lokacija: Irland
Postovi: 97
Molio bih Vas za misljenje dali moj komp mozhe ici na mac os i koji bi stavio gore
I eventualno gdi bi moglo zapesti?
Im here to kill You
Killer_99 je offline
Staro 07.07.2009., 15:07   #1358
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Hamm je online
Staro 07.07.2009., 22:17   #1359
Shuky
Shuky's Avatar
Postovi: 683
Autor Hamm Pregled postova
Postoji
da radi
intel ibm konfiguracija....mogu li dobiti neki tutorial.ili linkove..prema file-ovima.
sve u redu...nasao..
Zadnje izmijenjeno od: Shuky. 07.07.2009. u 22:39.
Shuky je offline
Staro 08.07.2009., 00:34   #1360
Garak
Lokacija: Sveta Nedelja
Postovi: 173
Garak je offline
Staro 08.07.2009., 19:54   #1361
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
moze pomoc sa dual bootom?
imam instaliran retail 10.5.7, kod instalacije sam sa disk utilityem napravio jednu hfs+ i jednu fat32 particiju na guid partition shemi. imam chameleon 2 bootloader. kako sad instalirat windows xp na tu fat32 particiju? naso sam milijun tutoriala/guideova al nemam povjerenja u to jer sam dosad na laptopu i na desktop pcu dosad 50 puta valjda reinstaliravo i sve i nemam zivaca ni vremena vise. na svim tim tutorialima pise nekima radi nekim ne..
komp je msi wind
Shockre je offline
Staro 08.07.2009., 20:00   #1362
Roberto
Roberto's Avatar
Postovi: 2,649
Autor Shockre Pregled postova
Nikako. Win Xp 32 bit ne radi na GPT particijama. Eventualno možeš probati s Win XP 64 bit (i to mislim samo ona itanium verzija), oni navodno imaju GPT podršku ali nisam probao. Win Server 2003, Vista, Server 2008 imaju GPT podršku, vjerojatno će imati i Win 7.
Trebao si formatirati disk u MBR, 2 particije (jedna ntfs za XP i jedna fat32 koju iz disk utilitya kasnije staviš u HFS+) onda staviti XP, a onda OSX i chameleon 2.
Roberto je offline
Staro 08.07.2009., 21:01   #1363
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
Autor Roberto Pregled postova
ma radi sigurno jer kad sa disk utilityem radis prije instalacije partition shemu tako da napravis jednu hfs+ i jednu fat32 particiju onda napavi hybrid shemu gpt+mbr. al ne znam kako instalirat winse da ne zeznem bootloader/aktivne particije itd, ne kuzim to bas.
Shockre je offline
Staro 08.07.2009., 21:55   #1364
Roberto
Roberto's Avatar
Postovi: 2,649
Pa tak si mogao odmah napisati
Instaliraj winse najnormalnije (nemožeš time zeznuti chameleon) i nakon toga se uvjeri da je OSX particija postavljena kao aktivna i preko chameleona ćeš moć bootat particiju s winsima.
Možeš pomoću chain0 metode staviti i win particiju kao aktivnu i bootati osx preko bootloadera od win xp. Tako imam ja riješeno, obje varijante rade bez problema.
Roberto je offline
Staro 08.07.2009., 22:52   #1365
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
ee too sam trazio!
znaci instaliram winse i stavim osx particiju ko aktivnu. fala puno. mislio sam da treba nes vise od tog jer sam naiso na sve neke outdated tutoriale sa kojima ima 500 koraka i ceg sve ne.
Shockre je offline
Staro 10.07.2009., 11:20   #1366
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Instalirao sam Leopard sa retail DVD-a na poseban disk sa GUID partition shemom prema ovom boot-132 vodiču za AMD a zatim napravio EFI bootloader prema munky's guide.
Sve je prošlo ok samo što nisam jučer zapisao UUID te EFI particije pa ne mogu bootat.
Zanima me sad hoću li morati kod svakog boota upisivati ovo:
Code:
bt(0,0)/mach_kernel.voodoo -v boot-uuid=dugi_uuid_brojcek
i može li se to nekako automatizirati?
Konfa je iz MojKomp (SB750, RTL 8111C, ALC889A), graficka 7600GT, Wifi Asus WL-138g v2.
P.S. Koji fix moram instalirati da mi prepozna USB HDD koji spajam kad je već komp uključen? (Prepoznaje ga samo ako ga spojim prije uključivanja.)
flajpan je offline
Staro 10.07.2009., 22:29   #1367
noobinator
noobinator's Avatar
Datum registracije: Mar 2008
Postovi: 120
1.pitanje
kod voodoo kernela treba negdje upisat cpu množitelj, a di točno?
btw... athlona prepoznaje kao Intel Core Duo
noobinator je offline
Staro 11.07.2009., 00:22   #1368
Garak
Postovi: 173
Jos jedan uspjeh. Vec jedno vrijeme planiram instalaciju na laptop Fujitsu Siemens U9200 c2d 1,6 GHz, 12,1" ekran, 3 GB rama, wifi, bt, 320 GB disk...).
Veceras sam konacno krenuo i koristio iAtkos 10.5.7 distribuciju. Proradilo je sve osim wirelessa, a ethernet jos nisam testirao.
Kamera radi, bluetooth radi (isprobao ga s bt Logi mx900 misem), USB VMC radi!!
Pokusao sam natjerati wifi intel 3945 abg da proradi, ali nazalost bez uspjeha. Kako citam po forumima jos se nije rodio tko je uspio tako da cu nabaviti mini pcie koja inace ide u macbook i staviti je u ovaj laptop...
Ako netko ima iskustva s 3945 i uspio je ipak natjerati da proradi neka se javi - svaka pomoc je dobrodosla
Garak je offline
Staro 11.07.2009., 00:54   #1369
Facelessone
Facelessone's Avatar
Postovi: 4,204
nema pomoću za intel 3945. Najlakše riješenje ti je ebay i dell 1490
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Facelessone je offline
Staro 11.07.2009., 01:16   #1370
Garak
Postovi: 173
Na putu je jer sam i sam zakljucio da je lakse tako
Hvala
Garak je offline
Staro 11.07.2009., 10:44   #1371
Roberto
Roberto's Avatar
Postovi: 2,649
Autor flajpan Pregled postova
Code:
Možeš dodati kernel flags u boot property list da ti se upisuju automatski:
http://www.insanelymac.com/forum/lof...hp/t32616.html
Za onaj USB probaj USB fix i pročitaj prvo ovo:
http://www.insanelymac.com/forum/ind...howtopic=95789
Koji si kext koristio za ALC889a? Slažem jednom frendu OSX na PC već tjedan dana, muči me taj kext jer mu ni jedan ne radi kak spada.
Autor noobinator Pregled postova
1.pitanje
Vidim da nisi pročitao upute od voodoo kernela, tamo ti sve piše što trebaš znati
BTW, normalno je da ti athlona prepozna kao core duo, to je namjerno tako da bi mogao koristiti apple update.
Roberto je offline
Staro 11.07.2009., 11:49   #1372
flajpan
flajpan's Avatar
Postovi: 1,796
Koristio sam OVAJ sa IPC 10.5.6 DVD-a.
To je .pkg koji sam instalirao iz OSX-a. U postavkama zvuka nakon reboota odaberi Output > Built-in speakers ili tak nešto.
EDIT: Reuploadao sam ispravni file (samo ga odzipaj prvo)
Zadnje izmijenjeno od: flajpan. 11.07.2009. u 12:00.
flajpan je offline
Staro 11.07.2009., 11:59   #1373
Baja 001
Baja 001's Avatar
Postovi: 7,504
Koristio sam ovaj sa IPC 10.5.6 DVD-a.
Zgodan je taj iPC zbog silnih kextove, samo ga još nikako nisam uspio upogoniti na par računala
Jedan prijedlog, znači svi PCEKspertovci bi mogli napisati ponešto o svojim OSX mašinama, konkretno kakav setup su koristili, što radi/ne radi i tako to
Baja 001 je offline
Staro 11.07.2009., 12:29   #1374
Roberto
Roberto's Avatar
Postovi: 2,649
Hvala na trudu, ali već sam bio isprobao taj pkg, ne dobim čak ni nikakav output prepoznat u system pref.
Za divno čudo, nije radio ni nakon što sam iz linuxa izvadio souncard codec dump i patchao appleHDA kext s HDA patcherom
Ovaj thread je već ionako postao preglomazan, to bi moglo ili u poseban thread ili da ljudi jednostavno dopune već postojeću bazu na OSX86 wiki, tamo ionako fali svježih informacija a ljude se uvijek upućuje tamo
Roberto je offline
Staro 11.07.2009., 12:33   #1375
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ma zanm za tu bazu, nego sam htio više PCE bazu i postupke, jer vidim već par puta da se pita za Intel 3945 ABG
Baja 001 je offline
Staro 11.07.2009., 18:11   #1376
noobinator
noobinator's Avatar
Postovi: 120
Ma to sam negdje pročitao na forumu da treba to upisat. Tad je još bio u beti.
Sad imam final i nigdje u uputama ne piše da je obavezno. Vjerojatno sam detektira. Osim mem koja "radi" na 0mhz. Kernel panike sam rješio sa AppleSMBIOSEFI kextom, kako piše u uputama.
Još samo da napravim backup particije i idem na 10.5.7
(Zbog safari 4 )
Staro 12.07.2009., 00:10   #1377
Garak
Postovi: 173
@noobinator: kad napravis update i instaliras zadnji Safari 4.0.2, potrazi Glims Safari plugin...
Garak je offline
Staro 12.07.2009., 12:38   #1378
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Garak Pregled postova
Dobar plugin Tek sada sazanao za njega. Uglavnom svi koji ga nisu stavili neka ga stave
Baja 001 je offline
Staro 13.07.2009., 12:35   #1379
Garak
Postovi: 173
@Baja: Da, Glims je super
Sad ima vec valjda 9 mjeseci da mi je OSX postao primarni sistem (Windowse vise ni ne koristim doma osim tu i tamo kad upalim stari ThinkPad T22 koji ima oko 8-9 godina...).
U ovih 9 mjeseci nasao sam dosta softwarea i naucio dosta trikova. Cim budem trebao mijenjati hardware koji koristim prijeci cu na Maca. Mozda u medjuvremenu naprave i neki MacPro za mase
Garak je offline
Staro 13.07.2009., 13:31   #1380
Baja 001
Baja 001's Avatar
Postovi: 7,504
I ja ga koristim ima od 10.4 verzije, aktivnije sam na njemu od 10.5 verzije. Uglavnom dosta sam promjenio konfa sa OSXom i stvarno sam zadovoljan. Sada baš se spremam na i7 i onda OSX
Što se tiče pravog Maca, trenutno pišem sa iMaca 20", ali mi oni nisu primar. Iz njihove linije je prebolestan ovaj iMac te MB(P), što se tiče MacProa on mi nije toliko napet iz razloga što volim začinit stvari pa malo OCati (a on i nije baš za to). Uglavnom Ja sam zadovoljan.
Kažeš da si našao softwarea podjeli s nama (Roberto, SU i ja smo pisali o SWu koji koristimo, i koji nam je uljepšao OSX pa baci i ti koju riječ).
Baja 001 je offline
Zaključane teme
