Postovi: 231
Microsoft WSE 3.0 Runtime
Pozdrav, Uglavnom nedavno sam skužio da imam ovu aplikaciju instaliranu na računalu, a ni sam neznam kako je dospjela na moj PC? Mislim da se čak instalirala kada sam instalirao neku od igara ili SP2 za Windows Vistu Ultimate (x64). No zanima me ako mi netko može reći za što točno složi ovaj Microsoftov WSE 3.0 jer bi ga u slučaju da mi ne treba izbrisao sa sustava. Čitao sam malo na Wikipediji o čemu se radi no idu previše u širinu i nikako mi nije jasno zašto se to instaliralo i to bez mojeg znanja (ili mi je jednostavno "promaklno" u jednoj od instalacija gdje se sitnim slovima koje je moguće pročitati samo mikroskopom navodi da će biti instalirana još dodatna aplikacija). Hvala. |
Postovi: 23,513
Web Service Enhancement (WSE) is add-ins to Microsoft Visual Studio .Net and Microsoft .Net Framework. WSE is a feature set, which developers can use for secured interaction between Web services based on different WS- specifications, such as WS-Security, WS-Addressing and WS-Policy. The Web Services Enhancements 3.0 for Microsoft .NET (WSE) enables developers to create interoperable Web services with advanced Web services features. With WSE 3.0 you can secure your messages using digital signatures and encryption, use MTOM to efficiently send large amounts of binary data, route messages through intermediaries, host Web Services outside of IIS, use the TCP/IP protocol and more. WSE 3.0 comes complete with samples and product documentation. WSE includes the following major features: 1. Easier message level security. 2. Interoperability with Windows Communication Foundation (WCF). 3. Improved Policy Framework. 4. Web services hosted by ASP.NET can now be hosted outside of IIS. 5. Improved session management. 6. Signature Confirmation. 7. Integrated tool support with Visual Studio 2005. 8. Support for updated Web services specifications. 9. Support for 64 bit runtime. 10. A comprehensive set of QuickStart samples showing the numerous features of WSE 3.0. pa ti sad zaključi jel ti to treba ili ne. |
#3 | |
Postovi: 231
Ako sam dobro shvatio iz ovog Microsoftovog trljezganja, radi se o nekom frameworku koji poboljšava interakciju web sadržaja s onim na desktopu? U svakom slučaju, ne bavim se izradom web aplikacija... prema tome nema ničeg što bi mi ovaj framework donio? |
