Staro 30.05.2009., 23:10   #3361
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
na kojem procesoru...?cudno kako si uspio uopce pokrenuti...
Staro 30.05.2009., 23:15   #3362
vercetti
vercetti's Avatar
Datum registracije: May 2003
Postovi: 1,226
Laptop u "moj komp".
Patch 1.0.3, 800x480, sve low (naravno), jedino traffic na 20.
Ide 15-25 fps, zavisi kako koja situacija...
Igrivo, ali ne i "enjoyable".
vercetti je offline   Reply With Quote
Staro 30.05.2009., 23:29   #3363
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Hah
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX
Michel je offline   Reply With Quote
Staro 30.05.2009., 23:32   #3364
vercetti
vercetti's Avatar
Postovi: 1,226
Staro 03.06.2009., 22:39   #3365
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Molio bi nekoga da napiše par onih osnovnih naredbi što se stavi u prazan file u GTA IV folder
Ono "No restrictions" i ostalo.
Znam da ima na temi ali ne mogu prelistavati 150 stranica sada
Puknuo benchmark prvi put nakon prelaska na i7 i SLI i to je totalni boom performansi.
Igra doslovno leti na ~70 FPSa 1680x1050, teksture high, ono drugo very high, pa ovi distance-i i sve to pojačano.
blaa
Staro 03.06.2009., 22:41   #3366
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
Command Line Parameters
Tools
-benchmark: Runs the benchmark tool and immediately exits game.
-help: Display list of all command line options
Graphics
-renderquality: Set the render quality of the game. (0-4)
-shadowdensity: Set the shadow density of the game. (0-16)
-texturequality: Set the texture quality of the game. (0-2)
-viewdistance: Set the view distance of the game (0-99)
-detailquality: Set the detail quality of the game. (0-99)
-novblank: Disable wait for vblank (No Vsync)
-norestrictions: Do not limit graphics settings
-width: Set width of main render window (default is 800)
-height: Set height of main render window (default is 600)
-safemode: Run the graphics in the lowest setting possible
-frameLimit: Limit frame to interval of refresh rate (ex If refreshrate is 60HZ –frameLimit 1 = Locks down to 60HZ)
-refreshrate: Set the refresh rate of main render window – Warning - Monitor must support (ex. –refreshrate 60)
-fullscreen: Force fullscreen mode
-windowed: Force windowed mode
-availablevidmem: Set amount of physical Video Memory(ex. –availablevidmem 0.9)
-percentvidmem: Percentage of video memory to make available to GTA
Audio
-fullspecaudio: Force high-end CPU audio footprint
-minspecaudio: Force low-end CPU audio footprint
System
-noprecache: Disable precache of resources
-nomemrestrict: Disable memory restrictions
izvoli,kopirano sa jednog sajta
ne znam da li znas,napravis .txt datoteku,imenujes je sa commandline i smjestis u root folder gta 4...
Staro 03.06.2009., 22:48   #3367
hammer_of_thor
Postovi: 5,430
Hvala
Da, znam di to ide, imao sam to i prije samo sam brisao pa zaboravio itd
Nego, samo još nešto, dali je dovoljno samo u commandline file napisati npr:
-texturequality 2
-norestrictions
ili trebaju zagrade, dvotočke i ostalo. Ili je samo ovo dovoljno?
blaa
Staro 03.06.2009., 22:54   #3368
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
nisam bas previse u tijeku, pa me zanima jel izasao jos koji peč nakon trojke i jel ovo iznad kaj pomaze.zazelio sam se opet igrat samo me 25 fpsa zivcira.jer ak kaj pomaze odmah ga opet instaliram
Staro 03.06.2009., 22:54   #3369
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
ne trebaju samo povlaka i naredba...imas tu naredbu da ti koristi memoriju(video)max cijelo vrijeme itd.sve znas sam......i povecaj si kolicinu memorije...
Staro 04.06.2009., 12:27   #3370
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
nemogu vjerovat.nakon nekog vremena instaliram ponovno ovo cudo i sad mi igra zasteka.svaki put na drugom "mjestu".nekad kod sejva.nekad kod loadinga i tak.ne kuzim zakaj.prije mi je sve normalno radilo.da i to se sve desava na zadnjem patchu
Staro 08.06.2009., 17:49   #3371
Independent
Independent's Avatar
Postovi: 202
Ovako jedno pitanje samo, dali netko od vas igra na 1080p (1920x1080) sa svim instaliranim patchevima? Kako se igra vrti i na kojoj konfiguraciji ako bi netko mogao napisati, nije me volja traziti po cijelom topicu . Hvala
Independent je offline   Reply With Quote
Staro 08.06.2009., 18:17   #3372
Daten
Daten's Avatar
Postovi: 403
Autor vercetti Pregled postova
Tak ja isto igram, ali meni nakon par minuta FPS padne na 1-2...
Ja mislim da je to zbog onog programa Games for Windows Live, jer mi isto tako i fallout 3 pocne uzasno stekati nakon par minuta igranja...
Jel ima netko ideju sta bi mogao biti problem ili je imao isti problem?
Daten je offline   Reply With Quote
Staro 08.06.2009., 18:20   #3373
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
pa na core i7,gtx 260,6gb ddr3
vrti sve na max osim textura i detail distance na nekih 35fps
btw.evo ti benchmark na rezoluciji 17 incnoga monitora...
http://forum.pcekspert.com/showthrea...62354&page=113
EDITaten da ti nije memory leak,a uz usto imas 2gb samo...probaj download memturbo->freeware program,pusti ga u pozadinu(bezbolno cisti)te vidi da li problem se jos ocituje
ne moras imati upaljen windows live,naravno ako ne igras online
Staro 09.06.2009., 17:26   #3374
Ice Man
Postovi: 8
Što je nužno za GTA IV?
Znači šta je nužno promjenit za normalno igranje GTA IV?
Imam: CPU: AMD Athlon 3500+
MBO: Asus A8N-E
RAM: 1GB DDR1 (2X512 DUAL CHANELL)
VGA: Ati Radeon X550
A sve se to vrti na Visti Ultimate
Znam da je grafika katastrofa, al dal bi ovo ostalo bilo dovoljno ili treba još nešto nadogradit?
Molim preporuke za neku jeftinu, a dobru grafiku. do 400-500kn
Ice Man je offline   Reply With Quote
Staro 09.06.2009., 17:37   #3375
Joke
N00B
Joke's Avatar
Postovi: 3,886
Vec je bilo takvih 10 tema preporucenih konfiguracija..Vidi sta gugl kaze->
Minimum System Requirements
* OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
* Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
* Memory: 1.5GB, 16GB Free Hard Drive Space
* Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
* Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
* Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
* 18 GB Free Hard Drive Space
* Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Po ovome sta se vidi nece nikako moci ic GTA IV na visti a ni na XP ne trebas gledatjer ti "fali" tu jos dosta...
IE6
Linux is Not Windows
Staro 09.06.2009., 17:55   #3376
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,750
Hmm, tesko da ces s tom konfom vrtiti gta..(proc je preslab, malo rama, jos i vista sve to zagusi) Čak i da kupis nesto do 500-tinjak kn nece bas biti neke promjene.. Ja bi ti preporucia radeon 4770, jest da dodje oko 800kn ali je stvarno isplativa grafa za tu lovu, ako nemozes toliko izdvojiti onda 4670, ona je oko 500kn..
Staro 09.06.2009., 20:08   #3377
Markos
Markos's Avatar
Postovi: 1,061
to moraš čitav pc složit iskreno ovo nemre ni pokrenut gta a kamoli da bude igriv
Markos je offline   Reply With Quote
Staro 09.06.2009., 21:31   #3378
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
zar je tak teško koristit tražilicu na forumu ili pročitat pravila
Staro 09.06.2009., 22:26   #3379
Reedy
Reedy's Avatar
Postovi: 770
Potpis kolegama
Reedy je offline   Reply With Quote
Staro 10.06.2009., 00:15   #3380
žile
žile's Avatar
Postovi: 3,074
Kad god me netko pita,ja sam protiv ulaganja love jače od 200kn u krama računala.Nažalost,nemožeš na tom igrat ni GTA,a ni ništa novije.
žile je offline   Reply With Quote
Staro 12.06.2009., 15:38   #3381
studenac
ludjak
studenac's Avatar
Postovi: 257
kako promijenit rezu u GTA
igrica je GTA IV, zaboravio napisat u naslovu...
ne kuzim, u igrici imam opcije za mijenjat rezoluciju samo do 1280*1024, dalje od toga ne mogu... jel to moguce ili nesto krivo radim? volio bih vecu rezoluciju....
q9300, 3GBram, radeon 4870.
hvala svima na pomoci!
studenac je offline   Reply With Quote
Staro 12.06.2009., 15:50   #3382
bez_panike
dijete u vremenu
bez_panike's Avatar
Lokacija: OS
Postovi: 295
nije ista aigra ali možda pomogne http://forum.pcekspert.com/showthread.php?t=94894
besposlen pop i jariće krsti
bez_panike je offline   Reply With Quote
Staro 12.06.2009., 21:20   #3383
studenac
ludjak
studenac's Avatar
Postovi: 257
it didnt work...
sta je stvarno 1280*1024 najveza reza na kojoj igrate GTA IV ?
lom.
Zadnje izmijenjeno od: studenac. 12.06.2009. u 21:40.
Staro 12.06.2009., 22:54   #3384
DanielDJ
DanielDJ's Avatar
Lokacija: Đakovo
Postovi: 250
velicina monitora?
DanielDJ je offline   Reply With Quote
Staro 13.06.2009., 02:19   #3385
mislav_os
freak
Postovi: 2,688
Autor studenac Pregled postova
it didnt work...
lom.
Nope...igram na 1680x1050 normalno...Koji monitor ti je u pitanju?
Staro 13.06.2009., 11:19   #3386
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Eh, instal ja igricu, al mi se neda prelazit... Jel zna tko kako ubaciti save game? Sto god da sam pokusao (neki xlive, ma cijeli dan sam se jucer zazao) neuspijva mi... Ako netko od vas zna kako to napraviti, bio bi mu vrlo zahvalan kad bi mi rekao kako je to uspio...
EDIT: Rjeseno uz pomoc blave... Tnx
Dobro to ide na 3870 i slabom dualcu...
Zadnje izmijenjeno od: Campeonato. 13.06.2009. u 17:45.
Campeonato je offline   Reply With Quote
Staro 13.06.2009., 11:21   #3387
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
ti hoces da ubacis save...koji os,xp ili vista...
ae javi se na msn
Staro 14.06.2009., 11:57   #3388
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
nemogu vjerovat sad mi baca neki error da nemam dovoljno memorije na grafi.(RESC10).za popizdit pokrpam jednu gresku i onda baca drugu.
Staro 14.06.2009., 23:50   #3389
Reedy
Reedy's Avatar
Postovi: 770
evo moje trenutno stanje s GTA 4
AMD X2 4000 > AMD X2 7750+ BE
ATi HD3850 > GF 9800GTX+
Ovo srebrne boje sam imao prije, a ovo crno imam sada... Prije sam igro sve na FULL LOW 17-23 fps
Sada igram na medium view distance 40... 30-40 fps miran sam
Staro 20.06.2009., 20:54   #3390
Reedy
Reedy's Avatar
Postovi: 770
Danas 19.06.09 stigao nam patch 1.0.4.0
http://www.rockstargames.com/support...tch/index.html
Probao, ne vidim NIKAKVE razlike. Najmanje u FPS. Jedino mi je oduzeo save
