#422 |
The Dark Side of Moon
Postovi: 3,945
#423 |
Datum registracije: Mar 2009
Lokacija: Murter
Postovi: 111
u biosu nisam primjetio nikakve raid postavke, stavio sam oba diska nigdje na netu ne mogu naci neki tutorial za raid. ovakav ssd je 290 e na geizhalt at , tri tjedna je bilo potrebno vrijeme za dostavu(U Bec). izvadio sam jedan hd 320 gb 7200 rpm a stavio dva samsunga mmcre28g5mxp te se battery life produzio sa 100 % 2:52min na 3:28min Zadnje izmijenjeno od: Andymur. 10.06.2009. u 19:20. |
#426 |
The Last Akkadian
Datum registracije: Apr 2008
Postovi: 194
Ne znam je li ovaj subforum savjetodavan/recenzijski karakterom ili newsflasherski ('prostite, nisam cital sve postove ), ali vidio sam nesto novo (meni) i cini mi se fascinantnim:"Photofast is on a roll with its G-Monster series solid-state storage, with product launches on a monthly basis. This time around, the company is readying two products that are unique in their own ways. First up, is the G-Monster-3.5, the company's first SSD in the standard 3.5" form-factor. The drive uses internal RAID to achieve high-capacities. While most other SSD manufacturers would simply stripe two SSD modules in internal RAID 0 configurations, Photofast used an internal RAID 5 configuration that ups reliability. The array is completely abstract to the host machine, which only sees it as a single drive. The drive uses a standard SATA II interface. It comes in capacities of 64, 128, 256, 512 GB, and 1, 2 TB. As far as its performance goes, the company rates the read/write speeds around 270 MB/s. The drive will be backed by a one-year warranty(?). Next up, is the G-Monster ExpressCard/54 SSD. This drive serves the purpose of expandable, removable storage for notebooks, that performs on par or faster than the hard-drive. The card comes in the standard 54 mm ExpressCard form-factor. It can function in both PCI-Express and USB 2.0 modes for the slot. When in PCI-Express mode, the drive provides stellar read/write speeds of 170/100 MB/s, and in USB 2.0 mode, 36/30 MB/s. It comes in 32, 48, and 64 GB variants, and boasts of 1.5 million hours MTBF(cca 170 godina, op.a.). It will be backed by a standard one-year warranty. There is no word on the pricing and availability. " Eto, meni stvarno interesantno. Jedino me piga gara od SAMO 12 MJESECI. Bzvz... Btw, ne cini mi se kao nesto sto ce nositi Fata1ity ime, vec kao ozbiljan komad HW-a... minus garancija... @techPowerUp! ![]()
#427 |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
podforum je ssd karaktera tak da, sam pucaj ![]() bitno je također kakav će kontorler imat taj đi skill, prethodni jmicroni baš i nisu bili nešto, čak ni u internim raid kombinacijama ali ak bude bilo što drugo osim jmicrona 602, bude veri najs |
#428 |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Softpedia: "The main differences between the two V5 models is that the former has been built using an Indilinx controller and 128MB of cache memory, while the latter has been designed using JMicron's latest controller, featuring 256MB of buffer. These enable the two drives to deliver various performance stats, with the Indilix-based V5 model offering read and write speeds of 270MB/s (32/64GB versions reach 200MB/s when writing), while the JMicron model provides speeds of 240/200MB/s respectively." Sto se tice JMicrona, proizvodjaci su poceli ugradjivati kombinaciju dva JMicrona (npr. JMF602B/JMB390 u novom Apexu) koji daju zanimljive performanse. Ako bude dobra cijena, mozda postanu solidna konkurencija Samsungu i Indilixu ![]()
The Secret ... |
#429 |
super user
Lokacija: Houston, TX
Postovi: 1,805
jel je moguce stavit SSD kao primarni disk (za os) i HDD za sekundarni disk? i od koje firme su dobri diskovi (sa MLC chipom 64 do 128gb),i da nisu skupi ,negdje do 3 k kn ![]() |
#430 | |
LateralusX
Postovi: 1,788
takav setup je kod vecine vlasnika SSD-a ![]() vaznije je znati o kojem se kontroleru radi jer iste firme imaju razlicite modele s razlicitim kontrolerima, po meni su trenutno najisplativiji (uvjetno receno ) oni SSD koji imaju Indilinx BareFoot kontroler, iako je Intel X25-M kontroler bolji, ali malo preskupako planiras kupnju u Hrv. onda preporucujem da kupis novi Bug jer su radili test s vecinom dostupnih SSD-a u kod nas, pa odmah mozes vidjeti i kako se krecu cijene (bitno se razlikuju od onih vani) ![]() |
#431 |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
evo baš ono što sam spominjao, kak samsung nema trajnih problema sa degradacijom, počelo se spominjati i na drugim mjestima.... dakle, onda jednom kad je gospon dh41400 složio iometre testove, ja sam odvrtio na svom sammy-u, performanse su opale, al kad sam drugi dan zavrtio vindoze, benčevi su se vratili u normalu.... a inteli i ostali su morali u tom slučaju napraviti secure erase i slično... tak da, ovo sa trimom i slično, čini se da je samsung to odavno predvidio i integrirao to u kontroler koji sam radi osvježavanje čelija bez da mu to mora govorit OS ![]() http://forum.notebookreview.com/show...postcount=6176 tako sam ponosan na svog sammy-a ![]() edit: ev link di sam to spomenuo...da neko ne pomisli da lažem ![]() http://forum.pcekspert.com/showpost....&postcount=330 al ne mog unaći ono sa iometrovima ?!?! edit2: evogac: http://forum.pcekspert.com/showpost....7&postcount=49 ![]() i ev na još jednom mjestu sam spomenuo: http://forum.pcekspert.com/showpost....3&postcount=28 daklem, samsung, čini se, ima nešt bolje od trima, disk se sam regenerira bez obzira na to koji je os na njemu... weeeee živio samsung ![]() Zadnje izmijenjeno od: darQ. 11.06.2009. u 13:38. |
#432 |
Postovi: 821
Evo jedan korišteni Vertex 30 GB na aukciji, no obratite pažnju na dostavu od samo 5 $, tako da samo na dostavi možete uštediti 150 kn ako Vam ne smeta što je rabljeni. Ja bi ponudio nešto al kriza i te stvari... |
#433 | |
kenova
Lokacija: München / Dubrovnik
Postovi: 926
#434 |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
erm, al moj slc ima kontroler druge genracije, tomy b je imao prvu generaciju kontrolera ![]() edit: 2tomy b, uz ovakve cijene ti razmišljaš o vertexu, no no no http://www.buy.com/prod/samsung-ente...210898931.html ![]() edit 2: gle stvarno, i vam piše da je prva generacija, hmh http://translate.google.com/translat...hl=en&ie=UTF-8 wtf ?? sam malo, a koja je onda bila ona generacija 16gb slc koju je tomy b imao -6-a ???? wtf ? uglavnom, to što je ocz otkrio da sad njihom summit ima te neke super fore i sad se hvale s tim, to ne znači da moj sammy to nema... odgovorno tvrdim da ima, jer, znam da je sam nadošao poslije onog zlo benča ![]() isto tak, ak na poslu cijeli dan rukam torrente, tj, prevučem jedno 5-gb u dl , malo mi se uspori po benčevima, ali, velim, drugi dan kad ponovno benčam, sve se vrati u normalu... Zadnje izmijenjeno od: darQ. 11.06.2009. u 18:05. |
#435 |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Znaci prema Tony-u, kada taj Samsungov Refresh odradi svoje dobijemo ~70 MB/s u Readu. Kada se na Vertexu "pokvare" performanse (bez ikakvog Trima ili "ciscenja"), ajmo reci da se prepolove ... znaci oko 120/90 MB/s (230/180 je normalno kad je nekoristen). Da li za jos nekoga postoji dilema ? ![]()
The Secret ... |
#436 |
Postovi: 821
niti jedna od onih trgovina nemaju niti jedan jedad Samsungov SSD, taj link sam vidio neki dan negdje pa sam provjerio sve već bi bio jedan na putu da imauju 32 GB SLC za 60 $ |
#437 | ||
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
#439 |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
njah... ajd da ti prevedem... 512k Random Write je bio 5MB/s i 4K random write je bio 0.34MB/s onda je ostavio komp upaljen, nakon 6 sati je potego 65MB/s i 7MB/s a nakon 8hr je potego 70MB/s i 8MB/s. 8 u odnosu na 0.34 nij nikak pola ![]() |
#440 |
Postovi: 821
ma sva ova nagađanja nemaju smisla, treba uzet Vertex-a i Samsung-a pa probat kak rade imao sam onog prvog Samsung-a i bio prezadovoljan, nikakav pad performansi se nije osjetio u radu, nikavo trzanje i gluposti da sam imo kud s njim ne bi ga sigurno prodao |
#442 | |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
uglavnom on ne ubije performanse za duplo, nego za 20 puta ![]() ne sumitu je valjd 8 4k write, a poslije tretmana se spusti na ~0.4 to je oko 20, jel ? samo sam to htio spomenut ![]() e sad, ovo automatsko poravljanje performansi kod sumita, ja sam samo želio reći da i moj sammy to ima, odgovorno to tvrdim... ![]() |
#444 |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
#449 |
Postovi: 821
dobro izgleda moram priznat da mi odmah palo na pamet kak bi možd dobro izgledalo da je kućište na laptopu prozirno i još od ssd-a da je prozirno čisto ono da se vidi da nema pokretnih djelova osim jednog ventilatora |
#450 |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
cijeli komp od prozirnog materijala ?!?! e to bi bilo zanimljivo, treba stavit prava na ovu ideju ![]() enivej, volio bih vidjet malo dojmova od ljudi koji su pokupovali ssd-e... mislim ono, niko više niš ne piše... |
