Staro 15.08.2004., 18:01   #1
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Doom 3 problemi?
Kad pokrenem igru,već na onom namještanju mi slika počne bježati gore dolje.
U readme fileu piše da trebaju biti instalirani driveri od miša i tipkovnice i tako instaliram i njih i opet ista stvar.
Imam i DirectX 9.0b i omegine drivere za grafu(53.03).
Da li je netko ima sličnih problema i da li znate kako da to riješim?
Staro 15.08.2004., 18:08   #2
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
kaj nije za doom 3 mozda potreban DX 9.0c.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 15.08.2004., 18:09   #3
Bl@de
Bl@de's Avatar
Postovi: 2,004
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 15.08.2004., 18:37   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Je.
tor je online   Reply With Quote
Staro 15.08.2004., 18:38   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Je.
Staro 15.08.2004., 18:48   #6
Veki-os
Veki-os's Avatar
Postovi: 3,996
DirectX(r) Detection & Installation
The Doom 3 installer does not check for the version of DirectX(r) you
have currently installed, it just prompts you to install DirectX(r)
9.0b. Activision recommends allowing the installer to proceed with the
DirectX(r) 9.0b installation, even if you think you may have 9.0b
installed. Re-installing DirectX(r) 9.0b will not harm your DirectX(r)
configuration. Doom 3 requires DirectX(r) 9.0b to install and play.
E vidiš da nije!
Staro 15.08.2004., 18:58   #7
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
tor spammeru
+1
Staro 15.08.2004., 19:28   #8
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Originally posted by MadBoY
tor spammeru
+1
Ma slučajno
Probaj staviti c ako niš drugo ne uspije...
Meni se čini da je kod instalacije pitao "du ju hev dir x 9.0c"
Staro 15.08.2004., 19:34   #9
Bl@de
Bl@de's Avatar
Postovi: 2,004
ma meni je malo zastekao net pa sam mislil da ni proslo pa kliknuljos jednom na send i onda zato imamo dve poruke.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 16.08.2004., 15:50   #10
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Je, je tak je i meni bilo
Staro 16.08.2004., 17:21   #11
Veki-os
Veki-os's Avatar
Postovi: 3,996
Jedna mala ispravka!Slika u meniju bježi gore dolje a u igri se raspada!To ja kao da se grafa raspada,tisuću artifakata(valjd se tak kaže,malo sam zaboravio).Stavio sam najnovije omegine drivere i sve isto..Dajte ljudi pomagajte,baš sam se namjerio igrat kad ono ovakvo sranje!
Staro 16.08.2004., 19:33   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Pa jesi probao s c? Jel ti komp ocan? Malo ga "primiri" pa vidi...
Staro 16.08.2004., 19:56   #13
Veki-os
Veki-os's Avatar
Postovi: 3,996
Nije ocan,sve na defaultu.Ne da mi se skidati 9,0c s mojom vezom to bi trajalo oko 2 i pol sata.Mislim da nije u tome problem,piše u readme fileu da mu je dovoljan 9,0b..
Zadnje izmijenjeno od: Veki-os. 16.08.2004. u 22:40.
Staro 16.08.2004., 22:25   #14
Gile
Postovi: 380
Probaj staviti Doom 3: CATALYST 4.9 BETA drivere.
Gile je offline   Reply With Quote
Staro 16.08.2004., 22:34   #15
Veki-os
Veki-os's Avatar
Postovi: 3,996
Jel ti vidiš čitati?Vidiš da imam nvidiu.
Staro 16.08.2004., 22:37   #16
Gile
Postovi: 380
Ma skužio sam kada sam već postao
Staro 16.08.2004., 22:45   #17
Bl@de
Bl@de's Avatar
Postovi: 2,004
ovak, meni sad isto nije nesto jasno. naime doom koristi pixel shadere 3.0 koji su tek podrzani u 9.0c DX-u dakle onda 9.0b nemoze po toj logici biti dovoljno, bez obzira kaj ti nemas PS 3.0 ne znaci da netreba DX 9.0c pa daj nazicaj nekoga a skidat 34 mb stvarno nije puno. trebalo bi ti negdje 2 h.
velim ja i dalje mislim da problem lezi u DX-u. BTW probaj kod nekog drugoga pokrenuti igru na dx 9.0b pa pogledaj dali ce raditi.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 16.08.2004., 22:49   #18
Gile
Postovi: 380
Kod mene radi sa dx 9.0b
Staro 16.08.2004., 23:37   #19
Bl@de
Bl@de's Avatar
Postovi: 2,004
onda stvarno netreba DX 9.0c...hm.... zanimljivo.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 17.08.2004., 14:20   #20
>>>KUKY<<<
>>>KUKY<<<'s Avatar
Lokacija: Vinkovci
Postovi: 1,055
Imao sam i ja iste probleme sa doomom.isti ti artifakti bas kao da se graficka raspala...to je bilo prije nego sam naredio refresh rate na 85 i sad mi sve radi...
Sig mi nije u skladu s pravilima.
>>>KUKY<<< je offline   Reply With Quote
Staro 17.08.2004., 17:29   #21
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
Sa fx 5200 če ti doom 3 malo teže normalno radit!
X
Staro 17.08.2004., 19:01   #22
Veki-os
Veki-os's Avatar
Postovi: 3,996
Ne brini ti za mene,nije bilo pitanje da li će mi raditi s mojom grafom nego nešto drugo tako da ne kužim zašto se uopče javljaš kad ne misliš pomoći?
Jadan ti je ulet...
Staro 18.08.2004., 00:37   #23
Veki-os
Veki-os's Avatar
Postovi: 3,996
Evo sad sam stavio najnajnajnovije drivere 65.62 i konačno sve radi kako treba i ništ ne trza.
