Staro 10.05.2009., 21:58   #31
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Hmmm, vjerojatno se onda osjeti razlika izmedju Himura i Quiet Drivea (overclock3D):
"Noise reduction is where the Scythe Quiet Drive quite clearly excels. With the Seagate SATA II HDD snugly encased in the Scythe Quiet Drive the usual noises emitted by a hard drive during spin-up was significantly reduced. The noise was reduced by so much in fact, that I really had to listen hard over the extraneous noise of the case fans. I found myself constantly feeling the outside of the Quiet Drive for the tell-tale slight vibration of the hard drive working inside."
Ova njegova guma/pjena mi izgleda vrlo solidno/tiho...
The Secret ...
Staro 10.05.2009., 22:43   #32
ShAd0w_dAnCeR
ShAd0w_dAnCeR's Avatar
Lokacija: BJ/ZG
Postovi: 539
Autor dh41400 Pregled postova
Ja o napajanju ...
Sto diskova tice, jedino nekakav silencer case pomaze (npr. Scythe Himuro, Quiet Drive ili sl.).
Sto se paljenja tice, to bas i nije normalno :S
izmjenio sam post, lapsuz...
ShAd0w_dAnCeR je offline   Reply With Quote
Staro 10.05.2009., 23:07   #33
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Na tvom mjestu bi upalio PSU na hladno (odspojio od ostatka kompa i zatim spojio zelenu i crnu zicu na 24-pin konektoru), te utvrdio u kojoj mjeri je izrazena buka samog napajanja.
Ako je buka stvarno iz napajanja (odnosno, ako je tebi preiritantna), te ako nije od njegovog venta (odnosno ne zelis ga mijenjat i izgubit garanciju) prodaj ga i kupi neko drugo .. jednostavnije nemoze
The Secret ...
Staro 10.05.2009., 23:39   #34
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,016
Ovo je malo u OT otišlo...
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
