80286
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Kubuntu 8.10 + HD4670
Stavio sam Kubuntu 8.10 u dual-boot sa XP-om. Prva stvar koju zelim srediti su driveri za grafu i rezolucija. Skinuo sam drivere sa AMD-ove stranice i slijedio sa ove stranice metodu 2, odnosno Manual install method. Sve prodje dobro no nakon restarta kompa se monitor blesira i kaze "Signal out of range". Pokrenuo sam u recovery modu i odabrao "Try to fix X" nakon cega mi je vratio originalni xorg.conf, a evo prilozit cu xorg.conf kako izgleda nakon instalacije drivera za slucaj da u njemu nesto treba mjenjati. Code:
# xorg.conf (X.Org X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the xorg.conf manual page. # (Type "man xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # Note that some configuration settings that could be done previously # in this file, now are automatically configured by the server and settings # here are ignored. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "ServerLayout" Identifier "aticonfig Layout" Screen 0 "aticonfig-Screen[0]-0" 0 0 EndSection Section "Files" EndSection Section "Module" EndSection Section "Monitor" Identifier "aticonfig-Monitor[0]-0" Option "VendorName" "ATI Proprietary Driver" Option "ModelName" "Generic Autodetecting Monitor" Option "DPMS" "true" EndSection Section "Device" Identifier "aticonfig-Device[0]-0" Driver "fglrx" BusID "PCI:4:0:0" EndSection Section "Screen" Identifier "aticonfig-Screen[0]-0" Device "aticonfig-Device[0]-0" Monitor "aticonfig-Monitor[0]-0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection
80286
Postovi: 1,724
Nisi pisao badava toturial, ali cisto instaliranje fglrx-a preko Synaptica prodje bez ikakvog ucinka, ni nakon dpkg-reconfigure xserver-xorg ne bude ama bas nista. Moram vidit ovo sto je Brutus stavio jos.
Lokacija: München/Varaždin
Postovi: 4,793
Hm...nisi jedini s tim problemom... http://forums.opensuse.org/hardware/...870-fglrx.html https://bugs.launchpad.net/ubuntu/+s...er/+bug/290704 A ati driver? Ako ništa drugo ne profunkcionira,probaj sa vesa driverom. |
