Staro 08.04.2009., 13:21   #1
jolehr
Datum registracije: Apr 2009
Postovi: 2
Killer NIC™ M1 Gaming Network Card
Killer NIC™ K1 Gaming Network Card
Zanima me dali netko zna gdje se u zg-u moze nabaviti ova graficka?
jolehr je offline   Reply With Quote
Staro 08.04.2009., 13:23   #2
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Sinko ajd ti malo na google pa citaj.
Valjda ti je jasno da mrežna i grafička kartica nisu isto.
Staro 08.04.2009., 13:26   #3
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
To nije graficka, to je mrezna kartica, kao sto ti i pise u imenu
I nece ti to poboljsat gaymanje
rams je offline   Reply With Quote
Staro 08.04.2009., 13:34   #4
jolehr
Postovi: 2
Autor rams Pregled postova
kk sve pet krivo sam napisao gdje se moze kupiti ova mrezna?
Staro 08.04.2009., 13:52   #5
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,877
nisam je nigdje vidio ali što će ti ona si čito ovaj review
http://www.legitreviews.com/article/478/7/
i zaključak
After spending an evening of gaming with and without the Killer NIC and Killer K1 on both our Windows XP Pro and Windows Vista Ultimate test systems it was the unanimously agreed by all that the Killer NIC and Killer K1 is not worth the added $180-$250 cost. The Killer NIC and Killer K1 did reduce our pings and improved frame rates, but by less than 5%. The difference was so small that no one could correctly tell when the Killer NIC was or wasn't installed in our 'blind' taste test, which was rather alarming. If someone is going to spend $180-$250 on something they better be able to see and notice the difference when they game.
u jednostavnom prijevodu nije vrijedna tih novaca,jer se dobije oko 5% povećanje framerejta i smanjenje pinga.
Staro 08.04.2009., 14:18   #6
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
naruci preko ebay-a
.i.
Razer Blade 15
Staro 11.04.2009., 17:30   #7
AiM
Postovi: 355
omg..
AiM je offline   Reply With Quote
Staro 24.11.2011., 17:12   #8
DiTech
DiTech's Avatar
Postovi: 345
Novi model je izasao, ping je dosta poboljsan, vjerovatno su neki qos napravili, samo cijena je ono $$$.
http://www.overclockersclub.com/revi...t_killer_2100/
DiTech je offline   Reply With Quote
Staro 24.11.2011., 17:19   #9
syss
syss's Avatar
Postovi: 10,805
ovo je korisno tik iza podloge za miša od 379kn
Staro 24.11.2011., 18:32   #10
DiTech
DiTech's Avatar
Postovi: 345
Ti to ne kuzis, ti nisi pravi gaymer
Mislim kad gledas da si ekipa kupuje brze linkove radi boljeg pinga, onda i nije tolko skupo 70$ za avg 184 -> 116 ping.
Staro 24.11.2011., 18:37   #11
Postovi: 8,229
Pa bolje onda kupit snajpera, na njima po defaultu dolazi Killer.
Zadnje izmijenjeno od: Pupo. 24.11.2011. u 18:46.
Staro 25.11.2011., 00:18   #12
syss
syss's Avatar
Postovi: 10,805
u kojem bi se to svemiru isplatilo dati 1000-1200kn više od sasvim solidne ploče za stvar koja može doći max 400-500kn.
još na kraju imaš fakin metke na čipsetu
