Lokacija: Novigrad / Zagreb
Postovi: 82
Bnet i WRT54GL
/dev/pts/0
Jan 1 01:30:30 ? daemon.notice pptp[1327]: warn[open_inetsock:pptp_callmgr.c:391]: connect: Network is unreachable
Jan 1 01:30:30 ? daemon.notice pptp[1327]: fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 10.64.0.1
Jan 1 01:30:30 ? daemon.notice pptp[1326]: fatal[open_callmgr:pptp.c:361]: Call manager exited with error 256
Jan 1 01:30:30 ? daemon.notice pppd[1321]: Modem hangup
Jan 1 01:30:30 ? daemon.notice pppd[1321]: Connection terminated.
Jan 1 01:30:30 ? daemon.info pppd[1321]: Exit.
Ima li tko riješenje, ili pak, te njihove postavke?Unaprijed zahvaljujem!--> Poštovanje,
Već se danima zezam oko toga.Zanima me, ako itko ima postavke konfiguriranja routera, kako bi PPTP (xCarnet) radio preko dotičnog routera, ovi iz Bneta mi vele da će poslati, triput ih zvao, i još nisu poslali. Išao sam postupkom ubacivanja default gatewaya (10.64.0.1) i username/password.Međutim, dobijam: Code:
Jan 1 01:30:29 ? syslog.info syslogd started: BusyBox v1.12.3 Jan 1 01:30:29 ? daemon.info pppd[1321]: Using interface ppp0 Jan 1 01:30:29 ? daemon.notice pppd[1321]: Connect: ppp0 <--> /dev/pts/0 Jan 1 01:30:30 ? daemon.notice pptp[1327]: warn[open_inetsock:pptp_callmgr.c:391]: connect: Network is unreachable Jan 1 01:30:30 ? daemon.notice pptp[1327]: fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 10.64.0.1 Jan 1 01:30:30 ? daemon.notice pptp[1326]: fatal[open_callmgr:pptp.c:361]: Call manager exited with error 256 Jan 1 01:30:30 ? daemon.notice pppd[1321]: Modem hangup Jan 1 01:30:30 ? daemon.notice pppd[1321]: Connection terminated. Jan 1 01:30:30 ? daemon.info pppd[1321]: Exit. Unaprijed zahvaljujem! Zadnje izmijenjeno od: BukYMast3R. 12.02.2009. u 15:18. |
#2 | ||
Lokacija: Splity
Postovi: 3,003
Još i oni koriste PPTP. ![]() Citiraj:
Zadnje izmijenjeno od: thopok. 12.02.2009. u 18:27. |
Postovi: 82
PPTP od ove godine. Probao sam sa Tomato FW, stockan, DD-WRT, i nit na jednome. Pozitivino je to što na DD-WRT dobijem default gateway i IP preko PPTP DHCPa, ali ne dobijem subnet i DNSove. |
#4 | ||
Lokacija: Splity
Postovi: 3,003
A o kojem se njihovu uređaju radi? Citiraj:
![]() Upute za postavljanje PPTP konekcije možete pogledati ovdje. Nevjerojatno da nitko s PPTP-om nije imao uspjeha. Zadnje izmijenjeno od: thopok. 12.02.2009. u 18:24. |
Postovi: 82
Pratio te upute, probao na 100 načina, i neide. Ništa, mislim da će uskoro slijediti raskid ugovora. |
Lokacija: NA
Postovi: 2,620
jesi prisiljen da koristish PPTP? nemozesh se vise spojiti putem PPPOE? |
Postovi: 82
Nemogu, samo PPTP. Evo nesto SSa: Code:
http://www.imagesforme.com/show.php/350663_Snap1.jpg http://www.imagesforme.com/show.php/350664_Snap2.jpg |
Postovi: 23,503
Opet tema bez svih potrebnih informacija. Kažeš Bnet, koji je njihov cable modem, koja mu je default IP adresa? Većina cable modema po defaultu je na 192.168.100.1, probaj otvorit u browseru i trebao bi dobiti stranicu sa statusom modema. Također nisi naveo da li ti radi 1. primjer iz uputa u thopok - vom 4. postu, znači bez WRT54GL (komp direktno spojen na cable modem). Ako ovo radi onda možeš ići dalje da tako kažem. IP adresu WRT54GL postavi na 192.168.100.2 (da bude u istom nizu kao i cable modem). Šta se tiće postavki mrežne na kompu probaj sa idiot (automatic), ja bih probao sa fiksnim IP=192.168.100.10, Subnet=255.255.255.0, Gateway=192.168.100.2 (ovo si u prthodnom koraku postavio). Šta se tiće DNS - ova najvažnije ih je postavit u routeru a nije na odmet i na kompovima. Vidi Sticky DNS by ISP. Zbog specifičnosti tvoje konekcije vidi šta kod tebe radi (jeli carnet ili Bnet DNS - ovi). |
Lokacija: Splity
Postovi: 3,003
Nešto valjda blokira(connect: Network is unreachable). Ne zna se radi li uopće(kad računalo ostvaruje konekciju). A dodatni problem je i Microsoft PPTP. |
Postovi: 82
Cable Modem je "Scientific Atlanta EPR2320R2" Default IP bi trebao biti 192.168.100.1 Bez router (modem direktno sa UTPom u komp) uredno radi, dobijem preko njihovog DHCPa adrese: 10.63.208.179 255.255.252.0 10.63.208.1 probat cu ovo sto si napisao. |
Postovi: 82
Ma kakvi, uspijem ak stavim pod "connection type: automatic DHCP", tada dobijem IP, subnet, gateway, ali se moram rucno spojiti preko konekcije. Ako stavim PPTP (bilo koji lokalni IP range), dobijem WAN IP, gateway, subnet ne dobijem. Code:
http://www.imagesforme.com/show.php/350857_22.JPG Code:
http://www.imagesforme.com/show.php/350847_Clipboard01.jpg |
Postovi: 23,503
Očito su nešto smućkali u onom uputstvu, usporedi brojeve. Probaj u WRT54GL umjesto sugerirano 10.64.0.1 stavit 10.1.1.1 |
Postovi: 82
Vratio se na stari soft: Code:
http://www.imagesforme.com/show.php/350999_22123.JPG Code:
http://www.imagesforme.com/show.php/350991_2212.JPG Ocito da me Carnet drzi samo na bridge mode-u preko PPTPa. Zadnje izmijenjeno od: BukYMast3R. 12.02.2009. u 23:16. |
#14 | |||||
Lokacija: Splity
Postovi: 3,003
![]() Citiraj:
Dok bi se korištenjem "pravog" uređaja to izbjeglo. Kod ostalih firmware-a vjerojatno nije sve podešeno onako kako je podešeno kod konekcije: Citiraj:
Ako U polje default gateway upišite: 10.64.0.1 radi, Citiraj:
Zadnje izmijenjeno od: thopok. 12.02.2009. u 23:59. |
Uptime 99.99%
Postovi: 2,545
Sad je full zao sto nemam xcarnet da isprobam ovo, ali ovako gledajuci ne vidim u cemu je problem. Imas interface jedan VLAN0 i 4 druga porta mislim da se zovu ETH0. Ako na VLAN0 uspostavis konekciju prema carnetu i dobijes skoro sve podatke preko DHCP ne vidim u cemu je problem. Kod ETH0 dhcp-a ionako ti sam mozes definirati postavke koje ce DHCP server davati klijentima, a WAN IP, subnet i gw mozes rucno upisati. Budem probao ako prijatelj uskoro dobije Metronet, ali sam siguran da ako neki soft to moze rijesiti onda je to DD-WRT.
#16 |
Lalalallalaaaaaa
Datum registracije: Mar 2009
Postovi: 521
Generalno, Bnet garantira za Linksys WRT54GC routere da će raditi bez većih problema. A sad na srž problema... 10.64.0.1 je adresa autorizacijskog servera za Carnet. Nikakvi DNS-ovi niti išta drugo bi trebalo uopće biti uneseno u postavke za spajanje preko linksysa... samo korisničko ime u stilu "ime@ustanova.hr" te šifra koja je dana od carneta. sve što se unosi je IP adresa servera dotičnog. samo 10.64.0.1 također, stavljanje MTU-a na 1400 bi moglo pomoći. Zadnje izmijenjeno od: Vrga. 21.04.2009. u 15:38. Razlog: nadopuna |
#17 |
Datum registracije: Mar 2008
Postovi: 34
/dev/pts/0
Ima li tko riješenje, ili pak, te njihove postavke?Unaprijed zahvaljujem! |
Poštovanje,
Jan 1 01:30:29 ? syslog.info syslogd started: BusyBox v1.12.3 Jan 1 01:30:29 ? daemon.info pppd[1321]: Using interface ppp0 Jan 1 01:30:29 ? daemon.notice pppd[1321]: Connect: ppp0 <--> /dev/pts/0 Jan 1 01:30:30 ? daemon.notice pptp[1327]: warn[open_inetsock:pptp_callmgr.c:391]: connect: Network is unreachable Jan 1 01:30:30 ? daemon.notice pptp[1327]: fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 10.64.0.1 Jan 1 01:30:30 ? daemon.notice pptp[1326]: fatal[open_callmgr:pptp.c:361]: Call manager exited with error 256 Jan 1 01:30:30 ? daemon.notice pppd[1321]: Modem hangup Jan 1 01:30:30 ? daemon.notice pppd[1321]: Connection terminated. Jan 1 01:30:30 ? daemon.info pppd[1321]: Exit. Unaprijed zahvaljujem! |
#18 |
Lalalallalaaaaaa
Postovi: 521
neće mu radit ako ide prek PPPoE. Čvorište na koje je spojen funkcionira jedino preko PPTP ako ima XCarnet il 3DCarnet i to se nemože promijeniti. |
#19 |
Postovi: 34
#20 |
Lokacija: Splity
Postovi: 3,003
To je samo privremeno. ![]() |
#21 |
Lalalallalaaaaaa
Postovi: 521
*facepalm* Ak si na tom čvorištu, sam PPTP može ak je prek xcarneta i 3Dcarneta. Zadnje izmijenjeno od: Vrga. 21.04.2009. u 15:38. |
#22 | |
Postovi: 34
Ne vjerujem ja vama... To sam našao na stranici od linksys-a kako se spaja cable modem i router i sve lijepo radi... ME HAPPY |
#23 |
Lokacija: Splity
Postovi: 3,003
Kako god, i dalje nije jasno zašto ugrađeni klijenti imaju problema sa spajanjem. |
#24 |
Lalalallalaaaaaa
Postovi: 521
ugl, dodatna količina carnetovaca se mora spajat preko PPTP-a, cijeli dan kaos. |
#25 |
Postovi: 82
Vidim da se ovdje otvorila ponovna rasprava.Uglavnom, stvar je riješena (privremeno) s ICSom. |
#26 |
Lalalallalaaaaaa
Postovi: 521
#27 |
Postovi: 77
meni još radi ppoe... inače imam isto WRT54GL... zadnji put kad sam probo stavit ga u pptp nije radilo..., ali nije radilo ni direktno pa pretpostavljam da kod mene to još neradi... nemam pojama... Do kad će se moć koristit ppoe?? |
#28 |
Postovi: 71
Zna li tko kako spojiti Zyxel P-660HW-D3 sa Bnet cable modemom. Mučim se već par dana i nikako. Kad se spajam direktno sa računalom sve radi, no kada bnetov cable modem spojim na WAN od Zyxela i ukucam Carnetovu šifru u njemu on se ne spaja. Jeli netko već uspio upariti ovo dvoje? Koristim PPPoE tako da bi trebalo radit. Dolje je opis konekcije kada se direktno spajam s računalom na modem. Zadnje izmijenjeno od: dome238. 16.04.2009. u 01:40. |
#29 | |
Lalalallalaaaaaa
Postovi: 521
@dome238 jesi li 100% siguran da ideš preko pppoe-a? na koji način se spajaš kad si direkt u win-u? |
#30 |
Postovi: 71
U prijašnjem postu sam stavio attachment u kojem piše sve o konekciji kad se direktno spajam, tako da sam siguran da je PPPoE. |
