Staro 23.03.2009., 19:12   #1
Futura IT
Futura IT's Avatar
Lokacija: Zaprešić
Postovi: 508
Nema ikone za hard disk
Evo pogledajte sliku pa ako mi može netko reći kako popraviti:
Futura IT je offline   Reply With Quote
Staro 23.03.2009., 19:36   #2
Postovi: 23,583
Krivo si se odrazio, ima ikone ali prikazuje krivu tj. onu za ne definirane slućajeve.
Potraži "restore original icons on xp".
Jedna od procedura:
Restore Default Icon For My Computer, Recycle Bin, Others
SUMMARY: Revert your My Computer, My Documents, or Recycle Bin icon on your Windows XP desktop back to the default.
Has the icon for one of the following desktop items changed and you want to revert it back to the default?
* My Computer
* My Documents
* My Network Places
* Recycle Bin (full)
* Recycle Bin (empty)
1. Right-click an empty area of the desktop and choose "Properties".
2. When the "Display Properties" multi-tabbed dialog box appears, click the "Desktop" tab.
3. Click the "Customize Desktop" button.
4. A "Desktop Items" dialog box will appear. Make sure the "General" tab is selected.
5. Choose an icon to change back.
6. Click "Restore Default".
7. Click "OK" on the dialog boxes to close them.
Slično s opcijom:
Right Click anywhere on the desktop ...you will reach Display Properties....
now under the "Desktop Tab"....click "Customize Desktop..."
Now Desktop Items will show up click the "Web Tab"....
Under the web tab....uncheck all the check boxes....including "lock desktop items" and all the pages listed (including hompage)....
This should do it.....
From this on use bmp or jpg or png as you desktop background only...a gif will re-enable the web option and cause the same problem....
so after this change your desktop background...
Staro 23.03.2009., 19:38   #3
Joke
N00B
Joke's Avatar
Postovi: 3,886
A je li disk mozes otvorit dvoklikom na tu "ikonu"? Jesi provao preko TuneUP stylera sa replace icon?
Staro 23.03.2009., 20:47   #4
Futura IT
Futura IT's Avatar
Lokacija: Zaprešić
Postovi: 508
diskovi normalno rade, ali ikona je takva kakva je... Nikky ovo tvoje sam probo al ništa.. Imate još kakvih ideja?
Staro 23.03.2009., 20:57   #5
Postovi: 23,583
Pa upotrebi Google kao i ja sada. Probaj ovo:
http://www.tomshardware.co.uk/forum/...3383_35_0.html
