Staro 01.03.2009., 21:18   #3211
studenac
ludjak
studenac's Avatar
Postovi: 257
Autor Reedy Pregled postova
Ma meni se igra ruši svakih 20 min igre,,,
ako ti se rusi nakon nekog vremena igranja, onda moras pratit temperature, mozda ti proc ili grafulja dosezu visoke temp iz nekog razloga (prljav vent) pa ti se zato gasi komp.
studenac je offline   Reply With Quote
Staro 01.03.2009., 21:21   #3212
BeroVK
Lokacija: Vinkovci
Postovi: 780
Kupite XBox pa igrajte bez stekanja i rusenja
Salu nastarnu, probajte novi patch i nove drajvere ja nisam imao apsolutno nikakvih rusenja, igrao sam je i na HD3850 i na 9600GT
BeroVK je offline   Reply With Quote
Staro 01.03.2009., 21:31   #3213
Neo-ST
Neo-ST's Avatar
Postovi: 8,326
A koji je to novi patch?
Staro 01.03.2009., 21:47   #3214
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
pa dvojka...2. po redu
Ugl., meni radi bez ikakvih problema, sve na high osim textura, detail na 15, i distance an 30, definition ON, vsync off ofkors...37FPS prosijecno na 1280x1024(+185.20 driveri)
Iako se nisam maknuo sa 3% igre, vec samo divljanje po gradu banšeom
edit: evo neki dokazi...
Statistics
Average FPS: 40.92
Duration: 36.97 sec
CPU Usage: 91%
System memory usage: 62%
Video memory usage: 99%
Graphics Settings
Video Mode: 1280 x 1024 (75 Hz)
Texture Quality: High
Render Quality: Highest
Reflection Resolution: High
Water Quality: High
Shadow Quality: High
View Distance: 13
Detail Distance: 21
Definition: Off
VSync: On
Hardware
Microsoft Windows XP Professional
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 Ultra
Video Driver version: 185.20
Audio Adapter: SB Audigy 2 ZS Audio [E800]
AMD Athlon(tm) 64 X2 Dual Core Processor 4400+
File ID: Benchmark.cli
Statistics
Average FPS: 39.77
Duration: 37.07 sec
CPU Usage: 93%
System memory usage: 59%
Graphics Settings
Video Mode: 1600 x 1200 (60 Hz)
Water Quality: High
View Distance: 15
Detail Distance: 30
Definition: Off
VSync: On
Hardware
Service Pack 3
iako ovo jako malo znaci...jer im taj benč ne drži vodu
Zadnje izmijenjeno od: Halos. 03.03.2009. u 21:55.
Staro 08.03.2009., 13:43   #3215
Hurricane
I´m CREEPING DEATH !!!!
Hurricane's Avatar
Postovi: 135
Dali se može u GTA IV nekako isključiti onaj j........ limitator za grafiku, imam 1024 Mb memorije na grafičkoj, al on uporno očitava 470 MB, koji su k........... uopće stavljali taj j............ limitator, stvarno su napravili neke velike pizdarije za PC verziju!!!!!
Hurricane je offline   Reply With Quote
Staro 08.03.2009., 16:10   #3216
Reedy
Reedy's Avatar
Postovi: 770
upiši u commandline
-avaiblevidem 3.500 i da vidiš
Reedy je offline   Reply With Quote
Staro 08.03.2009., 16:12   #3217
Neo-ST
Neo-ST's Avatar
Postovi: 8,326
upiši u commandline
Ako to upiše neće vidjet ništa...
Staro 08.03.2009., 16:49   #3218
Hurricane
Hurricane's Avatar
Postovi: 135
Jebga, ništa onda, morat ću igrat s limitatorom!!!
Staro 08.03.2009., 17:08   #3219
Reedy
Reedy's Avatar
Postovi: 770
ma hoće, očeš screen, imam grafičku 256 mb, a u igri piše da je 648
Staro 08.03.2009., 17:58   #3220
Baja 001
Baja 001's Avatar
Postovi: 7,504
Je li tko ima problema sa zadnjim patchom? Ulazilo mi u igru 10 minuta, sa 1.1 patchom sve OK.
Staro 08.03.2009., 18:08   #3221
Hurricane
Hurricane's Avatar
Postovi: 135
Piše da je 648 mb zato što si napisao -avaiblevidem 3.500 u command line??
Ako je to istina onda
Staro 08.03.2009., 19:13   #3222
Reedy
Reedy's Avatar
Postovi: 770
Ne ja nemam upisano 3.500, ja imam "-availablevidmem 2.875"
I NEMOJ MI SR** JER JE ISTINA, (ne govori nešto što neznaš i što nisi probao)
Staro 08.03.2009., 20:12   #3223
Hurricane
Hurricane's Avatar
Postovi: 135
mislim da sam krivo to upisao, ja sam to upisivao pod target, u proportiesu na ikoni, neznam gdje da drugdje upišem, komandni prozor u igri mi se ne otvara kad stisnem tildu
Staro 08.03.2009., 20:21   #3224
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
napravis commandline.txt u gtaIV folderu u program filesima, upises availablevidmem-xxx (kolko oces) i to je to
Staro 08.03.2009., 21:46   #3225
Hurricane
Hurricane's Avatar
Postovi: 135
odlično, radi, puno hvala
Staro 08.03.2009., 21:51   #3226
Reedy
Reedy's Avatar
Postovi: 770
Da, sad hvala, a u 18 sati si mi se smijao
Ali nek ti bu
Staro 08.03.2009., 22:34   #3227
Hurricane
Hurricane's Avatar
Postovi: 135
Koji k....., nisam ti se ja uopće smijao, ako misliš na onog smajlića krivo si shvatio!!
Staro 10.03.2009., 11:43   #3228
V3rt!g(o)
V3rt!g(o)'s Avatar
Lokacija: Marija Bistrica
Postovi: 70
Nakon 2. patcha još uvijek se događa da se igra "zaguti" nakon pol sata igranja. Padne na <1fps. Dal se to i drugima događa il je to do moje konfe? Na stranim forumima ljudi vele da su riješili to sa Cache Boosterom ili bilo kojim drugim alatom za optimizaciju memorije, no ovdje je uvijek isto.
::Think for Yourself; Question Authority:: T. Leary
V3rt!g(o) je offline   Reply With Quote
Staro 22.03.2009., 12:59   #3229
vercetti
vercetti's Avatar
Datum registracije: May 2003
Postovi: 1,226
New GTA IV PC patch available
GRAPHICS:
Interior Lights for ATI 1900 series cards
- All light sources appear for users with 1900 series ATI cards. (ie. Pool Mini Game)
- ALT-TAB fixed
Graphics Settings
- Added menu option "OFF" for Reflection quality
- Added menu option "OFF" for Shadow quality
PERFORMANCE:
- Physics optimizations to improve situations with heavy physics calculations (ie. 32 player races)
- Graphical Performance Optimizations
MULTIPLAYER:
NAT Type detection
- Detect if user has a "strict" NAT and displays message for user
Voice chat is received even if your microphone is turned off
CONTROLS:
Keyboard/Mouse
- Remapping restrictions removed
- Allow Enter, Backspace, and Arrow keys to be remapped by user
- Allow multiple mouse buttons to be mapped
Enable/Disable DirectInput in Menu
- Users can now activate/deactivate Direct Input devices from "Controls" menu.
- If commandline "-usedirectinput" is active, it will override pause menu setting
Use 2 direct input devices simultaneously (ie. Wheel and Gamepad)
- Users can now use 2 different controllers at once, including 1 XInput and 1 Direct Input device
Added more Direct Input / XInput device support
- Saitek P380/P480/P580/P990
- Saitek PS1000/PS2700/P3200/P3600
- Gravis Eliminator Shock gamepad
SECURITY:
Detect modified files and prevent users from entering multiplayer if found
- Game will prompt with a message after blocking user with modified data files from entering multiplayer
- Should prevent multiplayer access from cell phone and GFWL join in progress
VIDEO EDITOR:
Scroll Bar improved response
- Tweaked to respond better to keyboard inputs
Sped up load times for users with many clips
TITLE UPDATE 2 FIXES:
Return of Hot Dog Stands and other props
- Missing hot dog vendors, fences, gates, pylons should be present throughout the world
Scrolling signboards
- Activate missing scrolling signboard text (ie. highway signs, Star Junction, Clock Tower Sign)
ALT-TAB pauses game during cutscenes
- Cutscenes should now pause and resume correctly after an ALT-TAB task switch. Audio remains in sync
GENERAL ADDITIONS/FIXES:
Mismatched MODO/Perseus Clothing
- Fixed a bug when Niko mixes clothing from Perseus and Modo
360 Controller Texture
- Controller image should be visible in Controller Configuration screen
vercetti je offline   Reply With Quote
Staro 22.03.2009., 13:01   #3230
jurbAs
jurbAs's Avatar
Postovi: 2,583
kad neko proba sa ATI karticom nek napise jel ima kakvih poboljsanja ili ne... tako da znamo....
Staro 22.03.2009., 14:07   #3231
chingyos
chingyos's Avatar
Postovi: 375
Autor jurbAs Pregled postova
Ja sam probao patch i super sam zadovoljan jer se šugave sjene mogu iskljucit i puno se glađe vrti,tak da opet krecem igrati gta na multyplayeru
chingyos je offline   Reply With Quote
Staro 22.03.2009., 18:19   #3232
Reedy
Reedy's Avatar
Postovi: 770
instaliram patch: FATAL ERROR EFC20 Ma to je sve gore i gore od tog rockstara
Staro 22.03.2009., 23:33   #3233
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,509
i ja sam dobio neki error nesto sa 10, pise da restartam komp, restartao par puta, ali i dalje error. na kraju uninstall
imaticx je online   Reply With Quote
Staro 22.03.2009., 23:36   #3234
kasper_sky
Drive. vruummm,shatatataa
kasper_sky's Avatar
Lokacija: 1.Rijeka-2.VG-3.Zg
Postovi: 773
ja imam ati hd3870 pa cu probat
btw jel treba imat prije 1.2 patch
kasper_sky je offline   Reply With Quote
Staro 22.03.2009., 23:47   #3235
Hurricane
Hurricane's Avatar
Postovi: 135
trebate skinuti xlive.dll i kopirati ga direktorij od GTA IV, crack i 1911.dll su isti kao i kod 1.0.2.0
Zadnje izmijenjeno od: Hurricane. 23.03.2009. u 09:27.
Staro 23.03.2009., 00:13   #3236
kasper_sky
kasper_sky's Avatar
Postovi: 773
stavio patch i FATAL ERROR EFC20 također
onda sam stavio daj xlive.dll od huricana i igra radi ali nema mojih sejvova jer je moj xlive.dll težak 13mb i nakon 30 sec igre. igra počinje štucati fps nešto pada raste bezveze.
edit:kam bi trebo ić taj 1911.dll
Staro 23.03.2009., 00:35   #3237
Hurricane
Hurricane's Avatar
Postovi: 135
isto tamo gdje i xlive.dll
Staro 23.03.2009., 00:41   #3238
BeroVK
Lokacija: Vinkovci
Postovi: 780
Mislim da je zabranjeno postavljanje linkova na ilegalne sadrzaje tako bolje da editiras post dok nisi dobio bananu.
Staro 23.03.2009., 00:49   #3239
kasper_sky
kasper_sky's Avatar
Postovi: 773
bude ekipa sutra instališala patch pa će svi nać riješenje za probleme
edit:malo googlo pa izgleda da je ovak. ovaj patch ima neš u sebi šta blokira gusarske igre. a origigi ide ok. dok ne izađe "patch" za gta4 1.3 patch niš igranja.možda sam u krivu javi na pm ako znaš nešto.
moj info. da se zna...imo patch 1.1 pukno 1.3 i izbaci error.
pukno patch 1.1 preko 1.3 i ništa stavio 1.2 na 1.1 ,a prije 5 minuta imo 1.3
i sa tim 1.2 igra radi. malo manje fps-a imam.
i idem probat stavit 1.3 i opet error.
stavio sam ovaj gore xlive.dll i igra radi ali nemam sejvove i imam opasan frame drop.
valjda budu preko noći radili "riješenja"
Zadnje izmijenjeno od: kasper_sky. 23.03.2009. u 02:05.
Staro 23.03.2009., 09:20   #3240
Hurricane
Hurricane's Avatar
Postovi: 135
ja sam igrao sa 1.3 patchem i po meni je igra puno bolja, sredili su kontrole malo, grafika je poboljšana, nema bugova, kod mene su se FPS-ovi povisili i mogu sada igrati sa većom daljinom ( stavio sam na 100) i FPS-ovi su bili oko 40, sto prije nisam mogao, trebao sam staviti na 30. A što se tiče saveova, u 1.3 patchu su izbacili Games for Windows, i sada se igra direktno snima u folder u My Documents, ja sam već prešao 65 % igre i sad sve ispočetka, al šta je tu je, nisam siguran dali se zbog xlive.dll više nemože korisiti account ili zbog patcha.
Zadnje izmijenjeno od: Hurricane. 23.03.2009. u 09:37.
