#4835 |
Lokacija: VinkovcI
Postovi: 950
''kocka'' je DeskSpace, a dock je ObjectDock + KKMenu (malo je kompliciran za podesavanje, al kad se skuzi, ide ![]() EQ je Samurize...a wall je iz Hi-Fi rubike (audio-video) sa foruma ![]() |
#4836 |
Postovi: 298
#4837 |
Lokacija: /
Postovi: 2,053
@brentaal predobro izgleda ![]() ![]() @De5tr0yer cropana fotografija namijenjena za nešto sasvim, sasvim - drugo... ![]() Zadnje izmijenjeno od: svebee. 20.02.2009. u 22:57. |
#4842 |
Postovi: 18
#4843 |
Lokacija: Donji Miholjac
Postovi: 391
.....:::: There is no place like 127.0.0.1 ::::..... |
#4844 |
Postovi: 4,204
#4845 |
Eddie
Postovi: 5,506
#4847 |
Postovi: 391
desni klik na widget - skin menu - edit skin nadjes ovaj tekst Code:
;Please replace your location code of Weather.com below, e.g: Brno is EZXX0002. ;You can check it on Weather.com or Google. ; Osijek dest1=HRXX0003 ; define Fahrenheit Scale = f or Celsius = m SCALE=m ; define show Scale Mark SCALE.txt=°C ; !!!!! path is define HUD.Vision directory for changed 2 weather destination dir=C:\Program Files\Rainmeter\Skins\HUD.Vision\White ;================================================================
#4848 | |
Eddie
Postovi: 5,506
#4849 | |
Lokacija: Vinkovci
Postovi: 780
http://www.gadgetsforvista.net/ |
#4853 |
Postovi: 391
Code:
;=========================================== ; Rainmeter configuration file ;=========================================== [Rainmeter] Author=Jiri Mahel AppVersion=1.2 Update=10000 ;=========================================== ; Weather Dysplay ;=========================================== [Variables] ; nastaveni UpdateDivider pri Update=60000 na 1hod update.Spd=60 fontColor.Text=255, 255, 255, 160 bar.color=255, 255, 255, 50 bar.color=255, 255, 255, 50 graph.line1=255, 255, 255, 75 graph.line2=255, 255, 255, 37 border.color=255, 255, 255, 75 FontName=Tahoma FontHeight=8 AntiAlias=1 ; define interner Viewer eVIEWER=explorer.exe ;Please replace your location code of Weather.com below, e.g: Brno is EZXX0002. ;You can check it on Weather.com or Google. ; Osijek dest1=HRXX0003 ; define Fahrenheit Scale = f or Celsius = m SCALE=m ; define show Scale Mark SCALE.txt=°C ; !!!!! path is define HUD.Vision directory for changed 2 weather destination dir=C:\Program Files\Rainmeter\Skins\HUD.Vision\White ;================================================================ [MeasureWeatherRSS] Measure=Plugin Plugin=Plugins\WebParser.dll ; updated weather ~15minut UpdateRate=90 Url=http://xoap.weather.com/weather/local/#dest1#?cc=*&unit=#SCALE#&dayf=6 RegExp="(?siU)<weather ver="(.*)">.*<dnam>(.*),.*<tmp>(.*)</tmp>(.*)<t>(.*)</t>(.*)<icon>(.*)</icon>(.*)<day d="1" t="(.*)" dt="(.*)">(.*)<hi>(.*)</hi>(.*)<low>(.*)</low>(.*)<icon>(.*)</icon>(.*)<t>(.*)</t>(.*)<day d="2" t="(.*)" dt="(.*)">(.*)<hi>(.*)</hi>(.*)<low>(.*)</low>(.*)<icon>(.*)</icon>(.*)<t>(.*)</t>(.*)<day d="3" t="(.*)" dt="(.*)">(.*)<hi>(.*)</hi>(.*)<low>(.*)</low>(.*)<icon>(.*)</icon>(.*)<t>(.*)</t>(.*)" StringIndex=1 IfAboveValue=0 IfAboveAction=!execute [!RainmeterHideMeter MeterIconNA][!RainmeterShowMeter MeterIcon][!RainmeterShowMeter MeterTempZitra_Lo][!RainmeterShowMeter MeterTempPozitri_Lo][!RainmeterShowMeter MeterTempPopozitri_Lo][!RainmeterShowMeter MeterTempDnes][!RainmeterShowMeter MeterTempZitra][!RainmeterShowMeter MeterTempPozitri][!RainmeterShowMeter MeterTempPopozitri] IfBelowValue=2 IfBelowAction=!execute [!RainmeterShowMeter MeterIconNA][!RainmeterHideMeter MeterTempZitra_Lo][!RainmeterHideMeter MeterTempPozitri_Lo][!RainmeterHideMeter MeterTempPopozitri_Lo][!RainmeterHideMeter MeterTempDnes][!RainmeterHideMeter MeterTempZitra][!RainmeterHideMeter MeterTempPozitri][!RainmeterHideMeter MeterTempPopozitri] ;Debug=1 ;-------------------------------- [MeasureWeatherDestination] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=2 [MeasureWeatherTemp] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=3 [MeasureWeatherDesc] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=5 [MeasureWeatherIcon] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=7 ;------------------------- ;tomorrow's weather description, id=18 ;tomorrow's day, id=9 ;tomorrow's date, id=10, you can redefine the StringIndex value below with the id# [MeasureWeatherDate1] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=10 ;tomorrow's Hi-temp, id=12 ;tomorrow's Lo-temp, id=14, you can redefine the StringIndex value below with the id# [MeasureWeatherTemp1] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=12 [MeasureWeatherTemp1_Lo] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=14 ;tomorrow's weather icon, id=16 [MeasureWeatherIcon1] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=16 ;------------------------- ;D+2, weather description, id=29 ;D+2, day of week, id=20 ;D+2, date, id=21 [MeasureWeatherDate2] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=21 ;D+2, Hi-temp, id=23 ;D+2, Lo-temp, id=25 [MeasureWeatherTemp2] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=23 [MeasureWeatherTemp2_Lo] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=25 ;D+2, weather icon, id=27 [MeasureWeatherIcon2] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=27 ;------------------------- ;D+3, weather description, id=40 ;D+3, day of week, id=31 ;D+3, date, id=32 [MeasureWeatherDate3] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=32 ;D+3, Hi-temp, id=34 ;D+3, Lo-temp, id=36 [MeasureWeatherTemp3] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=34 [MeasureWeatherTemp3_Lo] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=36 ;D+3, weather icon, id=38 [MeasureWeatherIcon3] Measure=Plugin Plugin=Plugins\WebParser.dll Url=[MeasureWeatherRSS] StringIndex=38 ;================================================================ [refresh.weather] Meter=Button ButtonImage=refresh.png X=4 Y=8 ButtonCommand=!Execute [!RainmeterRefresh] [cara1] Meter=IMAGE X=0 Y=19 W=320 H=1 SolidColor=#border.color# [MeterIconNA] ImageName=na.png Meter=IMAGE X=40 Y=14r W=40 H=40 [MeterIcon] Hidden=1 MeasureName=MeasureWeatherIcon Meter=IMAGE X=0r Y=0r W=40 H=40 LeftMouseDownAction=!execute ["#eVIEWER#" "http://www.weather.com/outlook/travel/businesstraveler/local/#dest1#"] [MeterDnes] MeasureName=MeasureWeatherDesc Meter=STRING X=13r Y=-31r StringStyle=NORMAL StringAlign=CENTER FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Antialias=1 [MeterTempDestinace] MeasureName=MeasureWeatherDestination Meter=STRING X=-7r Y=17r StringStyle=NORMAL StringAlign=LEFT FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Antialias=1 [MeterTempDnes] MeasureName=MeasureWeatherTemp Meter=STRING X=-6r Y=52r StringStyle=NORMAL StringAlign=CENTER FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# PostFix="#SCALE.txt#" Antialias=1 ;------------------------- [MeterIcon1] MeasureName=MeasureWeatherIcon1 Meter=IMAGE X=70r Y=-39r W=40 H=40 [MeterZitra] MeasureName=MeasureWeatherDate1 Meter=STRING X=0r Y=-30r StringStyle=NORMAL StringAlign=LEFT FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Antialias=1 [MeterTempZitra_Lo] MeasureName=MeasureWeatherTemp1_Lo Meter=STRING X=6r Y=17r StringStyle=NORMAL StringAlign=LEFT FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Text="Lo %1#SCALE.txt#" Antialias=1 [MeterTempZitra] MeasureName=MeasureWeatherTemp1 Meter=STRING X=-6r Y=52r StringStyle=NORMAL StringAlign=CENTER FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# PostFix="#SCALE.txt#" Antialias=1 ;------------------------- [MeterIcon2] MeasureName=MeasureWeatherIcon2 Meter=IMAGE X=70r Y=-39r W=40 H=40 [MeterPozitri] MeasureName=MeasureWeatherDate2 Meter=STRING X=0r Y=-30r StringStyle=NORMAL StringAlign=LEFT FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Antialias=1 [MeterTempPozitri_Lo] MeasureName=MeasureWeatherTemp2_Lo Meter=STRING X=6r Y=17r StringStyle=NORMAL StringAlign=LEFT FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Text="Lo %1#SCALE.txt#" Antialias=1 [MeterTempPozitri] MeasureName=MeasureWeatherTemp2 Meter=STRING X=-6r Y=52r StringStyle=NORMAL StringAlign=CENTER FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# PostFix="#SCALE.txt#" Antialias=1 ;------------------------- [MeterIcon3] MeasureName=MeasureWeatherIcon3 Meter=IMAGE X=70r Y=-39r W=40 H=40 [MeterPopozitri] MeasureName=MeasureWeatherDate3 Meter=STRING X=0r Y=-30r StringStyle=NORMAL StringAlign=LEFT FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Antialias=1 [MeterTempPopozitri_Lo] MeasureName=MeasureWeatherTemp3_Lo Meter=STRING X=6r Y=17r StringStyle=NORMAL StringAlign=LEFT FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# Text="Lo %1#SCALE.txt#" Antialias=1 [MeterTempPopozitri] MeasureName=MeasureWeatherTemp3 Meter=STRING X=-6r Y=52r StringStyle=NORMAL StringAlign=CENTER FontColor=#fontColor.Text# FontSize=#FontHeight# FontFace=#FontName# PostFix="#SCALE.txt#" Antialias=1
#4854 |
420
Lokacija: Le Molve
Postovi: 1,577
#4855 |
N.K.D.Z.
Postovi: 37
... zagrebačko stanje uma dolazi sa ulica, ubojice dječjeg lica dolaze iz jaslica ... |
#4856 |
Postovi: 469
#4857 |
LateralusX
Postovi: 1,788
#4860 |
Postovi: 2,881
