Staro 15.02.2009., 19:44   #1051
LuxZg
Postovi: 512
Autor Hindenburg 129 Pregled postova
Imaj na umu to da dvije 4870 traže dosta struje. Da se nebi iznenadio....
Ne bih rekao da treba paničariti.. ima 650W napajanje, čisto dovoljno. Još mu ostane "kusur" više od 200W za overclockanje cijelog kompa.
EDIT: Draž, čemu 32bit Windowsi kad si se već išao sa Win7 igrat.. joj joj... :P Onda budi faca pa stavi 64bit verziju i kvit!
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 15.02.2009., 19:58   #1052
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor LuxZg Pregled postova
Ma nije mi pol igrica radilo na 64bit sedmici! Ostajem ja pri 32-bitnim dok neizade full verzija windows 7, i napravit cu dual boot sa xp-om ako opet nebude radilo pol stvari!
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 15.02.2009., 23:15   #1053
Hindenburg 129
Hull
Hindenburg 129's Avatar
Lokacija: - okolica Koprivnice -
Postovi: 25
Vidiš, nisam mu ni gledao napajanje. Za 650w nema panike, no ipak nebi bilo loše pogledat preporuku corsaira što se napona tiče (za svaki slučaj).
- dell 3543 i7 -
Hindenburg 129 je offline   Reply With Quote
Staro 19.02.2009., 00:32   #1054
windfucker
Hehe, bez brige, biti će dosta.
Staro 21.02.2009., 22:07   #1055
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Odustajem od crossfire-a. Ovaj x3 720 je pogurao grafu lijepo do kraja i sad se u krizi do 99-100% optereti i daje mi ugodni framerate bez frame dropova.
Na high oko 35fps-a 1680x1050 i neide ispod 25, budem jos vidio na assault levelu jer je on najzahtjevniji.
TV: LG 7450
GAMEPAD: XBOX One
Staro 13.03.2009., 21:20   #1056
ivo1950
ivo1950's Avatar
Postovi: 172
mozete rec kolike su temp u loadu u ovom powercolorovom modelu
http://vemil.hr/opis.aspx?prikaziTem...&Sifra=1130299
ivo1950 je offline   Reply With Quote
Staro 14.03.2009., 16:16   #1057
Xenon
Postovi: 1,542
Autor ivo1950 Pregled postova
ja imam powercolor HD3870 i temp je oko 60 a ventialtor je dosta bučan kad se cpu optereti
Xenon je offline   Reply With Quote
Staro 14.03.2009., 18:37   #1058
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Xenon Pregled postova
Misliš na GPU?
Ali mi ovdje pričamo o hd4870, i ona se po meni dosta više grije od hd3870!
TV: LG 7450
GAMEPAD: XBOX One
Staro 14.03.2009., 19:39   #1059
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
pošto je to isti cooler kao na ovoj Club3D OC što ja imam,
onda je i glede temperatura to ista stvar...
(osim možda taktova koji uzrokuju 1-2C gore/dole, Club3D ima 800/950, ne znam točno za PCS)
temp su: 65-67C u loadu (vent na auto, a to je oko 35-40%) sa ostalim 12cm ventovima na 5V(1upuh + 1ispuh u case)
u idleu grafa drži automatski oko 55-60C, tj skroz uspori vent, da ne bi pala temp prenisko,
jer navodno nisu baš zdravi veliki i nagli temp šokovi, zbog rastezanja materijala i ostaloga...mislim da je cijela jedna serija mobilnih nvidia imala problema upravo zbog toga, pucali su čipovi.
pa onda grafa održava razliku idle/full load u nekih 15C (što bi bilo i preko 50C da drži vent stalno na istoj vrijednosti)
sada cu tu usput i staviti fotke koje pokazuju kako nije bitno da grafa ima 3 žice do venta da regulira vrtnju.
što je prilično uvriježeno mišljenje kako na forumu tako i šire...
naime, Club3D ima 3 žice, ali samo 2 su u funkciji, kada se digne konektor u zrak to se vidi, ima samo 2 pina ispod.
dakle, grafa ne zna na koliko se vent vrti, samo mu šalje određen 'duty cycle'
tj. regulira koji postotak vremena ce vent dobivati struju.
i njega mijenaj ovisno o temp GPU-a
onda se može uštekati BILO koji vent u to i njime se upravlja kao da je stock. npr 1x12cm
sve to bez gubitka garancije.
evo slika koja to potvrđuje:
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
Zadnje izmijenjeno od: TomRi. 14.03.2009. u 19:56.
TomRi je offline   Reply With Quote
Staro 14.03.2009., 20:17   #1060
mislav_os
freak
Postovi: 2,688
TomRi
Na koliko ti se vrte ta dva Sharkoona sto si stavio na grafu?? Jesu isto kao i ona dva (upuh/ispuh) na 5V??
Staro 14.03.2009., 20:35   #1061
TomRi
TomRi's Avatar
Postovi: 2,073
Autor mislav_os Pregled postova
TomRi
jedan je uštekan u grafu i ima autoregulaciju, a drugi fixno na 5V (preko molexa)
temp su iste, ali se grafa ne čuje.
pošto je onaj stock vent manji i brže se okreće,
a i kao da ima glasnije ležajeve.
no on se izvadi poptuno van da ne smeta protoku zraka.
vidi se sve na slikama.
Water cooled PC
Moj najveci MOD
Staro 19.03.2009., 11:08   #1062
mario6
Postovi: 45
http://www.bali.hr/index.php?main_pa...ducts_id=30293
Zanimljivo,iako vjerojatno greška
mario6 je offline   Reply With Quote
Staro 24.03.2009., 17:08   #1063
LuxZg
Postovi: 512
Autor mario6 Pregled postova
Malo kasnim, al nije greška.. links ima već duže vrijeme cijenu od 1959kn, a evo, ima sad i D24: http://www.diskont24.com/product.php?productid=56530
Riječ je o Gainward GS 1GB kartici, za 1915-1920kn. Na nabava.net stoji da je D24 nudio i za 1906kn
a evo i Sapphire TOXIC 1GB za 1860kn!
http://www.instar-informatika.hr//ar...e=11133-14-20R
Možda ima i jeftinijih, samo je bed kaj pola dućana nema ni slike kartica, ni detaljnije specifikacije :/ Referentnih 1GB ima podosta oko te cifre 1850kn.
Ja ću sačekat još ovih 10 dana dok ne objave HD4890 (il kak god da će se zvat) jer mislim da će cijene opet padat.. A i tak ne igram niš sad dok ne nabavim veći disk.. (no space to install )
Staro 24.03.2009., 17:50   #1064
mario6
Postovi: 45
Ja bih isto uzeo toxic.Koliko čitam dosta je tiha i hladna.Jedina ja mana kaj pola vrućeg zraka izbacuje van iz kučišta,a pola unutra.Ali ako imaš dobro provjetreno kučište to nije problem
A ona cijena za Gainwardicu je bila 866 kn,ali su ipak ispravili,Šteta,haha
Staro 25.03.2009., 16:30   #1065
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,310
Staro 25.03.2009., 21:13   #1066
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ne kuzim sta fali referentnim HD4870, pa je nekakav Vapor-X must have?
Ovaj cooler cak i ne izbacuje vruc zrak van.
Staro 26.03.2009., 07:24   #1067
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Slažem se, ja sam evo našao jučer 4870 Force3D DHT za 1100kn,sa 20mj garancije,i još razmišljam.Kako će me glava bolit kad ju ne kupim,jao.
Staro 26.03.2009., 10:55   #1068
Postovi: 33,970
Razmišljaš? Kupi! Dok razmisliš - ode.
Staro 26.03.2009., 11:38   #1069
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
@thedream
Kupi obavezno i napiši vrijedi li šta ta grafa jer nova u 24diskont cca 1.350kn
ja gledao jučer i isto razmišljam "kupiti ili nekupiti pitanje je sad" bit če dobra za 22" monitor jer sam u planu nabave samo dok nađem ono što zadovoljava moj "budžet" i potrebe naravno.
Nisam vidio da je netko kupio istu a dosta su povoljne s obzirom na slabije modele kao i druge proizvođaće gdje su cijene ohoho više.
Staro 26.03.2009., 11:47   #1070
Cele303
Cele303's Avatar
Postovi: 337
Imam ju ja i prodao sam ih cca 15ak komada i svi su zadovoljni, ali obavezno DHT Freezer, ne ove dual slot, one su lošije iako ni to nije neki minus kartici... DHT se clocka kao životinja, Gainward GS se može sakrit a skoro 50% joj je bila veća cijena...
Cele303 je offline   Reply With Quote
Staro 26.03.2009., 11:51   #1071
thedream
thedream's Avatar
Postovi: 5,458
Autor coconut Pregled postova
A poznavajući moje razmišljanje,već je otišla.Poslao sam upit za rezervaciju do plaće,za tjedan dana mi negdje sjeda,oko 3.4. Do tad ako se ne proda,jao. Ne mogu više u minus ić šta ti je .
Autor ECHO Pregled postova
@thedream
Mislim da ti to nije ta (DHT) nego običan plastičnjak dual slot,ali isto dobra kupnja. Ako se varam ispravi me. Cele je ovu za nekih 1460 prodavao.
Za 1100 znam da je must have,tj. must buy.
@ cele,je to je ta tvoja identična,DHT,evo za 1100 ja rezervirao izgleda,do idućeg petka,znači tjedan dana. Nadam se da ću ostvariti kupnju,to bi mi bila jedna od zadnjih gaming kartica,ne bi mijenjao više, pošto selim brzo u stan s curom i uzimam laptop,sve ću brijem rasprodati najesen.
Staro 26.03.2009., 12:11   #1072
Cele303
Cele303's Avatar
Postovi: 337
Ja sam svoju DHT nabavio novu za 1000kn a prodavao sam ih po 1420kn kad je bila oko 1500 u Diskontu24 kao jedinoj konkurenciji... Poslije je meni poskupila na 1500 kad je u diskontu bila prešla 1600...
Evo thedream slika...
http://forum.pcekspert.com/showthrea...91#post1231691
Zadnje izmijenjeno od: Cele303. 26.03.2009. u 12:24.
Staro 26.03.2009., 12:47   #1073
ECHO
Postovi: 2,354
@cele303
Postoji li još kakva mogučnost nabave te grafe(DHT) i naravno mogučnosti plačanja
recimo "diners" ukoliko je moguče neznam jer je ima u diskont24 nepiše ali bi mi odgovaralo do cca 1500kn ukoliko nije više te bi svoju onda utopio i pridodo ostatak
Staro 26.03.2009., 12:56   #1074
Cele303
Cele303's Avatar
Postovi: 337
Na žalost ih više nema u HR, samo ove "retail dual slot" a "DHT Freezer" su bile aktualne u 12. i 1. mjesecu... Ne znam kakva je situacija u diskontu24 sa plaćanjem, vjerojatno se može platit Dinersom... Ako želiš što jeftiniju 4870 Force3D je skroz ok za svoje novce...
Staro 26.03.2009., 13:43   #1075
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Jap, čisto pristojna grafa za te novce, ja sam zadovoljan
Staro 26.03.2009., 14:49   #1076
ECHO
Postovi: 2,354
http://www.imagesforme.com/show.php/..._GrafaATI1.JPG
http://www.imagesforme.com/show.php/417927_GrafaATI.JPG
Evo našao još ove dvije i sad sam stvarno u nedoumici, a razlika 100Kn u odnosu na 4870 Force3D model u diskont24.Jedino da uzmem koja je ljepša.
Dolazi Uskrs valjda če neki zec nešto donijeti.
Staro 26.03.2009., 16:24   #1077
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Ova sapphire je stvarno bucna u loadu. Da bi ostala ispod 80C vent ide preko 3k obrtaja i cuje se ko fen. Za ovu drugu ne znam
dmr je offline   Reply With Quote
Staro 26.03.2009., 18:28   #1078
mario6
Postovi: 45
Ova crna?Šteta,bila mi je prvi izbor,ali ovako otpada.Tražim nešto tiše
Staro 26.03.2009., 18:55   #1079
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Da crna. Spram 8800gts 320MB ova sapphire je bar duplo glasnija. Doduse nemam iskustva sa ostalim 4870 karticama, mozda je to kod njih normalno
Staro 27.03.2009., 09:15   #1080
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,763
http://www.tigerdirect.com/applicati...31359&CatId=28
Kako kaže jedna pjesma "Jer Amerika je zemlja daleka"
Bila je 160 USD pa 165 pa sad opet 159,99 USD
Zadnje izmijenjeno od: E-mil. 10.04.2009. u 23:50.
E-mil je offline   Reply With Quote
