Staro 01.02.2009., 22:30   #1
Postovi: 23,512
exFATfile system driver za XP
Evo kako Mirkosoft reagira kad ga proizvođači pritisnu.
http://support.microsoft.com/kb/955704/
This article discusses the key features and benefits of the extended File Allocation Table (exFAT) file system driver for Windows XP. In response to OEM feedback and to Independent Software Vendor (ISV) feedback, Microsoft released the exFAT file system driver for Windows XP on January 27, 2009.
Najvažnije:
The exFAT file system incorporates several improvements over FAT32. However, it keeps the simplicity of FAT-based file systems. These improvements include the following key advances:
  • Support for very large files and storage devices
  • Support for performance improvements
  • Support for extensibility features for future innovation
  • Added compatibility for flash media
The exFAT file system driver brings file system support parity to the following operating systems:
  • Windows Vista
  • Windows XP
  • Windows CE
The exFAT file system driver incorporates advanced structures for future scalability. The exFAT file system uses 64 bits to describe file size. This allows for applications that depend on very large files. The exFAT file system also allows for clusters as large as 32MB, effectively enabling very large storage devices. Specifically, exFAT adds the following features:
  • Support for volumes that are larger than 32 GB, the theoretical maximum volume size for FAT32 in Windows XP
    • The theoretical maximum volume size is 64 ZB.
    • The recommended maximum volume size is 512 TB.
  • Support for files that are larger than 4 GB, the theoretical maximum file size for FAT32 in Windows XP
    • The theoretical maximum file size is 64 ZB.
    • The recommended maximum file size is 512 TB.
Staro 02.02.2009., 13:02   #2
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
jel ima to kakvu primjenu osim u prenosivim HD.ovima i usb memorijama? HD u kompu ionako formatiramo u NTFS..
Staro 02.02.2009., 14:11   #3
Postovi: 23,512
Recimo to ovako:
- nemoraš formatirat u NTFS čak kad disk prelazi 32 Gb
- flash disk od 4 Gb formatiran NTFS - om "pojede" 47.2 Mb za organizaciju diska, dok kod exFAT to je 96 Kb
- vjerojatno glavni razlog "zahtjeva" ove verzije, veličina pojedinačnog dokumenta može biti 512 Tb a prije 2/4 Gb
Možda u budućnosti naletiš na medij sa ovim formatom pa bez drajvera tj. zakrpe kanta/lap ti ga neće skužit kako treba.
Za kraj, ne ubijajte glasnika
Staro 02.02.2009., 23:46   #4
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
Autor Nikky Pregled postova
mislim da će najveću korist imati ljudi koji spajaju disk na ps3 ili autoradio putem usb.a...
