Staro 17.01.2009., 17:03   #1
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,850
(riješeno) NTLDR is missing
digo nanovo sitem ali je stari xp pro još gore.
znači 3 diska 5 particija,xp pro su bili na e particiji i još,htio samprobati xp x64 pro na c particiju lai mi je bacao erroe kod instalacije pa sam ja prekinuo,nakon rebota NTLDR is missing press ctrl+alt+del to restart.
c-xp novi
d-ostalo
e--xp stari
f-ostalo
pokušao sam ja ovo s ove stranice
http://www.computerhope.com/issues/ch000465.htm
Windows XP users
1. Insert the Windows XP bootable CD into the computer.
2. When prompted to press any key to boot from the CD, press any key.
3. Once in the Windows XP setup menu press the "R" key to repair Windows.
4. Log into your Windows installation by pressing the "1" key and pressing enter.
5. You will then be prompted for your administrator password, enter that password.
6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Misconfiguration with the boot.ini file
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
ali nije uspjelo,ovaj misconf nisam probao,se može nekako vratit butabilnost starog xp-a??,ne treba mi ali da probam ako se to ponovo dogodi.sad gledam kad sam išo na repair da je ovdje stavio te 2 fajle jeli trbaju tu biti ili negdje drugdje??budem još pokušao fixati master boot record ake se može.
nije pomogo ni fixboot niti fixmbr ali je pomogo bootcfg /rebuild
Zadnje izmijenjeno od: demetrius. 19.01.2009. u 11:56.
Staro 17.01.2009., 19:03   #2
Gx25
RiSeN FrOm tHe BaNNeD
Lokacija: cro
Postovi: 662
Tribas namistit boot piorty hard diskova u biosu i bilo je vec ovakvih tema preko 100
Gx25 je offline   Reply With Quote
