Zaključane teme
Staro 02.01.2009., 16:16   #961
ivan_karlovac
ivan_karlovac's Avatar
Datum registracije: Aug 2008
Lokacija: karlovac
Postovi: 111
a da jednostavno makneš taj shut down temp na cca 85+°C
jer 65°C je normalna radna temp za CPU
Kako da stavim shut na 85 kada je maximalna tempoeratura e8600 72,4 ili oni lažu http://processorfinder.intel.com/det...x?sSpec=SLB9L# uglavnom stavio sam i na 75 ali i to ne može održati nego se ugasi.
ivan_karlovac je offline
Staro 02.01.2009., 16:20   #962
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Thermal Specification: The thermal specification shown is the maximum case temperature at the maximum Thermal Design Power (TDP) value for that processor. It is measured at the geometric center on the topside of the processor integrated heat spreader. For processors without integrated heat spreaders such as mobile processors, the thermal specification is referred to as the junction temperature (Tj). The maximum junction temperature is defined by an activation of the processor Intel® Thermal Monitor. The Intel Thermal Monitor’s automatic mode is used to indicate that the maximum TJ has been reached.
Jezgre mogu još bez beda... Pročitaj boldano
Hvala SRVu što me ispravio u vezi toga
Bullet1 je offline
Staro 02.01.2009., 16:27   #963
ivan_karlovac
Lokacija: karlovac
Postovi: 111
Autor Bullet1 Pregled postova
Ma u redu ali jbg ja sam paničar i bolje spriječiti nego liječiti. Uglavnom kupujem novi cooler sada me zanima koji a da košta 350 Kn i da nije preglomazan sada smo stavili Thermaltake Max Orb i jbg jedva je stao unutra.
Staro 02.01.2009., 16:34   #964
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
HR-01 + vent- upada u cjenovni rang a hladi odlično. Glomazan malo al stat ce sigurno
Bullet1 je offline
Staro 02.01.2009., 18:25   #965
Dottore
Dottore's Avatar
Postovi: 7,661
a kakva razlika od TRUE?
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Dottore je online
Staro 02.01.2009., 19:04   #966
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Autor Dottore Pregled postova
Veći je razmak između alu listića, tako da je bolji za pasivu ili za vent na malo okretaja.
Gilbert5 je offline
Staro 02.01.2009., 19:55   #967
Cele303
Cele303's Avatar
Postovi: 337
Meni je Nexus XIR-3500 totalno super, ne čuje ga se, odlično izgleda, mrcina, težak je oko 750 grama, košta 300 kn a hladi u rangu sa skupljima, univerzalan i za AMD i za Intel, po noći je zakon za nas koji brijemo na vizualno
Cele303 je offline
Staro 02.01.2009., 20:53   #968
Pippincro
Pippincro's Avatar
Postovi: 616
Autor Cele303 Pregled postova
E pa to pitanje sam postavio par postova prije
Jel moze malo vishe infa? Temp. pod opterecenjem trenutngo procesora i kolka je temp. okoline?
Jel to ona all copper verzija ili s aluminijskim finovima? Stock vent i kakav je - jel pwm opcija postoji?
Pippincro je offline
Staro 02.01.2009., 21:54   #969
ShAd0w_dAnCeR
ShAd0w_dAnCeR's Avatar
Lokacija: BJ/ZG
Postovi: 539
el postoji trenutacno sta bolje od TRUE na nasem trzistu?
ShAd0w_dAnCeR je offline
Staro 03.01.2009., 01:18   #970
Moree
Postovi: 328
Kupio danas Freezera 7 u vemilu - 139kn
Razlika od stock kulera u 15-20 stupnjeva
Moree je offline
Staro 03.01.2009., 01:48   #971
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor ShAd0w_dAnCeR Pregled postova
Vodeno
Mislim da mu uz bok idu ZeroTHERM modeli (Dizel ga ima) i slične mrcine iz Scythea,Xigmateka, ali generalno je vrhunski hladnjak.
Nego čuo sam da je shit ako se ne ispolira (dobro nije shit, ali se više očekiva od njega), ja sam sa svojim TRU120 vrlo zadovoljan, jedino bi ga mjenjao za vodeno
Baja 001 je offline
Staro 03.01.2009., 08:20   #972
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Zato je ZEROtherm NV120 ispoliran i izbrijan kao pica i mozes brojat dlake na njegovoj bazi. Plus toga sto ga spustis na cca 1000RPM i postaje gotovo necujan, a ucinak hladjenja je gotovo isti kao i pod full obrtajima (2700RPM), dobijes s njime i onaj potenciometar za regulaciju brzine.
Dizel je offline
Staro 03.01.2009., 20:40   #973
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor Dizel Pregled postova
jedino je problem sto ga u hrv. vise nema za kupiti
DeadMan+ je offline
Staro 03.01.2009., 20:58   #974
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Jako lijepo izgleda
Ima i pwm vidim, za ~300tinjak kn sasvim dobar.
blaa
hammer_of_thor je offline
Staro 04.01.2009., 14:27   #975
Cele303
Cele303's Avatar
Postovi: 337
Autor Pippincro Pregled postova
Nexusovi hladnjaci su među najtišima na tržištu zato mi se sviđaju, odličan omjer performansi, tišine, izgleda i novaca što im pruža raznovrsnost uporabe...
Moj 3500 je bakreni, aluminijska XIR-2300 varijanta je jeftinija 50kn a isto je dobar, možda čak i bolja kupnja s obzirom na malu razliku u temp a postoji i LXM-8200, konkurencija Freezeru 7, taj je još jeftiniji 50kn od 2300...
Vent je nečujan, ima pwm regulaciju, možeš ga i sam izregulirat u biosu (ovisno da li ti to bios daje) pa ako se stavi low postavka (slow, silent ili brojčana postavka ovisno o biosu) onda vrti na 800 okretaja umjesto 1200 što mu je minimum ako sam automatski regulira vrtnju...
Na E8400 imam Big Typhoona a 3500 vrtim na Phenomu pa ti brojke vjerojatno neće nešto značit... U odnosu na prethodnog Freezera 64 osjetno je smanjio temp, na 3.2 idle je 42°, load je 55° dok je sa Freezerom raspon bio 48°-65°, pravi test će doživit kada kupim Deneba... Na Intela ga nisam namontirao jer mi se ne da skidat Big Typhoona a mislim da je bolji za OC od Nexusa...
Cele303 je offline
Staro 05.01.2009., 14:56   #976
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
koji kuler možete preporučiti da zamjeni intelov stock na quadu,
sad, jedino kaj tražim je da ima recimo princip montiranja ko ovaj stock, tj. znači da se držači mogu samo onak odozgo zataknut jer ak ja moram vadit matičnu da bi ih od ispod šerafio, onda ništ ;-)
Pizz je offline
Staro 05.01.2009., 15:30   #977
Chome
TK
Chome's Avatar
Postovi: 1,092
Autor Pizz Pregled postova
Nisi naveo cijenu do koje ideš. Ali od tvorničkog je bolji Freezer 7, jeftiniji je, a ima taj način pričvrščivanja koji meni nije baš drag ali eto i sam ga koristim :-).
Chome je offline
Staro 05.01.2009., 15:59   #978
Alfa_R
Alfa_R's Avatar
Postovi: 2,904
Mah, cas posla je to vadjenje maticne. Bar u cm690 sa vodilicama za kablove.. Cuj, dosta ces biti ogranicen u izboru jer vecina njih se na muku muka namontira, a onda opet nisi 100% ziher. Evo, ja sam ninju namontirao vani. I rekao bi na pritisak da je to to, kad ono jedan pushpin nije uhvatio... a onda sa silom i kad se culo krckanje to je bilo to...
Lakse se dise kad se sve pogleda odispod i vidi da je sve 5.
Jedino sto je dobro ako uspijes kakvu grdosiju namontirati sa plocom unutra je to sto neces vidjeti sta ti radi od maticne ploce...
Alfa_R je offline
Staro 05.01.2009., 15:59   #979
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
cijena mi nije faktor nego način montaže
EDIT; da mogu vadit matičnu "čas posla" sigurno nebih tražio takav cooler, heh
hmm dobro zgledaju i jedan i drugi, makar imam osječaj da bi ninđa mogao
prevagnuti kučište na bok , kad se uspravi, hehe
Pizz je offline
Staro 05.01.2009., 16:57   #980
the-rider
ha?
the-rider's Avatar
Lokacija: Poreč
Postovi: 543
http://www.links.hr/index.php?naziv=...kl=050.903.135
ja imam ovog, malo je skup ali i hladi solidno
i ima push pinove za montazu
the-rider je offline
Staro 05.01.2009., 17:51   #981
Verbum
Postovi: 682
Danas mi je dosao Zerotherm Zen FZ120, hladnjak kojeg sam kupio od Burka. Kuler je stvarno fantastican.
Na def. voltazi i na 3.0Ghz quada u idlu drzi na oko 30C dok pod loadom (prime95) temperatura ne prelazi 50C.
Sad sam digao voltazu na 1.5 i digao quada na 3.5Ghz i temperature ne prelaze 75C.
Stvarno odlican cooler steta sto ga nema za kupiti kod nas, svejedno sve pohvale .
Jedno pitanje da li je previse dati quadu 1.5V za 24/7 rad ?
Jer samo sa tom voltazom zeli ici na 3.5Ghz.
Verbum je offline
Staro 05.01.2009., 18:14   #982
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Smanji mu i obrtaje na ispod 1200 rpm
Dizel je offline
Staro 05.01.2009., 18:37   #983
Verbum
Postovi: 682
Trenutno se vrti na oko 1300 rpm (što je i najniže) i stvarno se nečuje, tako da nema potrebe .
Verbum je offline
Staro 05.01.2009., 21:09   #984
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ček, jel zaj ZEN ima PWM regulaciju(4-pinsku) ili običnu 3-pinsku+potenciometar(opcionalno) kao i moja Nirvana NV120?
Dizel je offline
Staro 06.01.2009., 03:03   #985
Verbum
Postovi: 682
ZEN ima PWM regulaciju tj. 4-pinsku i nema potrebe ga stisavati ispod 1300 rpm-a (sto je i najmanje okretaja) posto je vent stvarno tih tj. skoro pa necujan.
Verbum je offline
Staro 06.01.2009., 11:39   #986
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
Autor the-rider Pregled postova
hoho, pa jel ima i bagera za montažu , pa to đubre ima kilu
EDIT; bolje kilo pršuta nego kilo kulera
Pizz je offline
Staro 06.01.2009., 11:54   #987
Wolverine
Wolverine's Avatar
Postovi: 12,425
To je ranije zvani model Scythe Infinity
Odličan cooler, sa odličnim 120mm ventom
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Wolverine je offline
Staro 06.01.2009., 16:00   #988
Alfa_R
Alfa_R's Avatar
Postovi: 2,904
Ja sam razmisljao da ga uzmem, Ali onda bi se pitao dali hitpajpovi bolje rade kad stoje vodoravno, a posto bitako ruzno mu stajao vent sa puhanjem prema nazad sam si skratio muku i uzeo ninju. sad bar znam da nemam sta optimizirati.
Alfa_R je offline
Staro 07.01.2009., 15:55   #989
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
JuiceBox je offline
Staro 07.01.2009., 17:01   #990
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Šta je to, roštilj ili kalorifer?
Dizel je offline
Zaključane teme
