Staro 20.11.2008., 22:05   #1
pexy
pexy's Avatar
Postovi: 39
Question N85 VS N96
Surfajući po netu naletio sam na taj N85. OK. Pa taj mobitel je kopija N96!!! ovak, sve isto sam kaj nema taj famozni dvb-h! uvjerite se sami... mislim više mi se ispalti uzet N85 iovak ne šljaka telka kod nas tak da se dođe na isto..
evo pogledajte usporedbu:
http://www.gsmarena.com/compare.php3...&idPhone1=2496
ooo drimbokše, ti kvalitetni komadu tehnologije!
pexy je offline   Reply With Quote
Staro 20.11.2008., 23:32   #2
SrKi
SrKi's Avatar
Postovi: 841
N96 - veci ekran i 16GB memorije
N85 - FM transmiter (po meni veliki plus)
SrKi je offline   Reply With Quote
Staro 21.11.2008., 01:33   #3
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
A kaj ima kod nas za kupit N85? stvarno s ečini bolja kupovina
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 21.11.2008., 10:15   #4
Arsenal-fan
Mallosi
Arsenal-fan's Avatar
Postovi: 338
-i po testu N85 ima skoro duplo bolju bateriju!
Arsenal-fan je offline   Reply With Quote
Staro 21.11.2008., 11:01   #5
Mad_Duke
Iako nekak je meni drazi N85. Ima isto famozni OLED ekran. pa kog veseli :P, samo jedan proc novije verzije. I BATERIJA!!!
Minus je samo sto ce se sigurno lakse naci jeftiniji polovni N96.
Staro 21.11.2008., 11:16   #6
pexy
pexy's Avatar
Postovi: 39
Ok N85 definitivno šiša u bateriji... al kučište je skroz identično...
mislim da je cjena N85 malo niža...
Staro 21.11.2008., 11:44   #7
Mad_Duke
Autor pexy Pregled postova
Ali, ekran joj je 0,254 cm manji :P
Staro 21.11.2008., 19:23   #8
pexy
pexy's Avatar
Postovi: 39
Staro 22.11.2008., 14:06   #9
Pink_Floyd
Postovi: 325
I N85 ima - ARM 11 369 MHz processor . a N96 dual core - Dual ARM 9 264 MHz CPU
Pink_Floyd je offline   Reply With Quote
Staro 22.11.2008., 14:36   #10
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 647
N96 plusevi: -veći ekran, TV, 16GB mem
N96 minusi: -dimenzije (ogromna je, držao ju u ruci), cijena
N85 plusevi: -AMOLED ekran (manje struje troši, bolji kontrast), bolja baterija, manjih dimenzija, dizajn identičan N96
N85 minusi: -8GB mem (naspram 16GB na N96, makar i to je dovoljno), TV (meni osobno nepotreban, no svako ima svoje potrebe...)
Trenutno imam N70 od prvog dana kada je izašla na Hr tržište (cca 3god), bolji je bio jedino N80, najvjerojatnije kupujem N85 ali tek kada malo cijena padne...
Mejzlik je offline   Reply With Quote
Staro 23.11.2008., 16:07   #11
pexy
pexy's Avatar
Postovi: 39
slažem se stobom Mejzliče! malkoc nek cjena padne i ja si mislim piknut N85
Staro 24.11.2008., 15:46   #12
SrKi
SrKi's Avatar
Postovi: 841
taj TV ne radi u hrv i pitanje je kad ce raditi.
jedno je integriranih 8gb/16gb, a drugo je kad se kartica stavlja, brzina pristupa podacima je dosta brza.
vidim da zaboravljate FM transmiter, to je odlicna stvar.
Staro 25.11.2008., 13:03   #13
gin.tonic
gin.tonic's Avatar
Postovi: 2,436
N85 definitivno
gin.tonic je offline   Reply With Quote
Staro 25.11.2008., 23:34   #14
ranGO
ranGO's Avatar
Postovi: 315
po ovim spefikacijama oboje imaju FM.... ili je pogreska na gsmareni?
AMD II X4 620/AC Freezer 64 pro
AsRock A785GHX
Baracuda 7200.10 250 gb
4GB DDR2 800 Patriot Viper
HD4200
Chieftec Aegis Black / Coolermaster 430W
Logitech tipkovnica/Razer Diamond Black 3G
Samsung 931bw
HP 9470m
ranGO je offline   Reply With Quote
Staro 26.11.2008., 00:14   #15
Mad_Duke
Autor ranGO Pregled postova
Pa ja sam bio uvjeren prije da N96 za razliku od obje N95 ima jedan proc i fm trans.
Staro 27.11.2008., 10:39   #16
Clansman
Clansman's Avatar
Postovi: 43
Imao sam oba mobitela u ruci jer sam im stavljao navigaciju i da uzimam uzeo bi N85 iako N96 meni izgleda upecatljivije.
N96 spora do bola iako ima dual procesor ali je pianje kako ga koristi. Kad se tek ukljuci ne diraj mob barem minutu jer je ne spor nego ultra spor. Primjetio sam da sistem radi kao i kod Viste (superfetch ali samo dok se ne iskljuci mob) a to je da snima sve sto radis s mobitelom i sljedeci put to digne puno brze. Rad u samim programima (Garmin, ...) je primjetno sporije nego na N85 i vuce se. Kao nasljednik N95 nije uopce dostojan barem dok ne izadje ako i izadje verzija 2 kao i kod N95 pa N95 8GB.
N85 ima puno bolju bateriju (1200 vs 950 mAh), tek malo manji ekran ali je zato sistem brz. Sve ide kako bi trebalo i reakcija je gotovo trenutacna. Ispitao sam i FM odasiljac a kao prijemnik je bila N96 i signal se gubio vec nakon pola metra ali kome to treba uostalom.
UP THE IRONS !!!
Clansman je offline   Reply With Quote
Staro 27.11.2008., 11:13   #17
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 647
Jedno pitanje:
Je li na N85 ostaju cak i najmanji otisci prstiju jer je full spolirana ??
Pitam jer frend ima 6600 slide, isto tako je spolirana ali se bas i ne kuze ti otisci...
Staro 27.11.2008., 12:06   #18
Mad_Duke
Autor Clansman Pregled postova
Da, ali to ti je sa "male antene" na "malu antenicu" odasiljanje. Koliko sam citao svugdje i od par frendova sa normalnom antenom (npr. auto) da stvar radi odlicno. A i nekako mislim da je to jedna od najboljih primjena Dodjes u auto, kresnes ga, podesis frekvu i deri
Staro 05.12.2008., 15:26   #19
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,824
Jel možda ko ima N85?Da malo javi dojmove,pošto vidim da je mob na papiru dost jak.
Staro 05.12.2008., 19:42   #20
KidBoy128
KidBoy128's Avatar
Datum registracije: Apr 2008
Postovi: 291
po mome oba su prevelika ali kad pogledam sve ostale stvari onda bi i na veličinu zaboravio ("veličina nije važna")
baš me zanima kad će doć vrijeme kad ćemo imat fotošop na mobitelima i kad budemo igrali crysis na mobu
KidBoy128 je offline   Reply With Quote
Staro 05.12.2008., 20:52   #21
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
pa quake 3 mos vec lagano igrati na n95 8gb tak da za godinu dana ces igrati crysis.
.i.
Razer Blade 15
Staro 26.12.2008., 01:28   #22
cupe
Lokacija: Srebrenik
Postovi: 5
Nokia N96
Ajmo,ko ima ovaj telefon da cujemo,vrijedil te novce???
cupe je offline   Reply With Quote
Staro 26.12.2008., 03:26   #23
Pink_Floyd
Postovi: 325
Zaboravi ga apsolutno , za puno manje novaca imas n95 8gb za kojeg mogu slobodno rec bolji.Imam oba pa znam o cemu pricam..
Staro 26.12.2008., 12:10   #24
MAXx
Čupavac
MAXx's Avatar
Postovi: 261
N85 nisam imao u ruci ali imam doma N95 i N96 pa mogu reći nešto o njima.
N96
Ljepi veliki ekran
16Gb memorije koja se još može nadograditi sa karticom
tanja od N95 (stare)
Previše stisnute tipke ispod ekrana u odnosu na N95 (stare)
ispolirana: ostaju otisci i skliže se u rukama
TV ne radi u Hrv
slabiji zvučnici od N95 (stare)
nema poklopac na kameri
kamera je lošija od one na N95 (loše boje)
duža od stare N95
ima nekakav debilni USB konektor (nije mini USB)
trajanje baterije
tipke sa slovima i brojevima su mnogo lošije nego one na N95
N95 (stara)
Dobra kamera koja ima poklopac
oštar i velik ekran
kada se stavi veća kartica ne usporava se; čak se ubrzala (sa 512mb na 4Gb)
jači zvučnici u odnosu na N96
čvrsto leži u ruci i ne ostaju otisci na kučištu
mini USB
velike tipke ispod ekrana
trajanje baterije
malo memorije
Eto to je moje mišljenje o ovim modelima.
Nadam se da će pomoći u konačnoj odluci.
Science cannot be stopped. Man will gather knowledge no matter what the consequences – and we cannot predict what they will be. - Linus Pauling
MAXx je offline   Reply With Quote
Staro 26.12.2008., 13:11   #25
cupe
Lokacija: Srebrenik
Postovi: 5
Eto sad ispade da je stariji model bolji od novog,stvarno ste me doveli u nedoumicu sta uzeti!
Staro 26.12.2008., 14:37   #26
MAXx
Čupavac
MAXx's Avatar
Postovi: 261
Autor cupe Pregled postova
Da, tako je .
Ako se mene pita bilo bi ti najbolje da kupiš N85 jer ima skoro sve isto ko i stara N95 i N96. Još si samo kupiš micro SD karticu i vozi.
Mislim da je N96 bacanje novaca tj. žao mi je što sam ju kupio.
Staro 29.12.2008., 15:07   #27
BraBUS
Nervozni poštar
BraBUS's Avatar
Datum registracije: Mar 2008
Postovi: 258
n85 odlican mob, napokon poštena nokija.
ne kužim zašto je mobis uvozi n96, kad se ne može koristiti tv?? nikad im necu oprostiti što nisu uvezli nokiju n92 takodjes s nepodržanim tv-om!
nVIDIA+INTEL=klasika
This message is hidden because Crash009 is on your ignore list.
BraBUS je offline   Reply With Quote
Staro 31.12.2008., 00:01   #28
killah_tm
killah_tm's Avatar
Postovi: 900
pitanje OT: da li se isplati mijenjati n82 black za n85?
killah_tm je offline   Reply With Quote
Staro 31.12.2008., 19:31   #29
zvonac
zvonac's Avatar
Postovi: 5,824
Autor killah_tm Pregled postova
Pa mislim tu nema govora,u svakom slučaju daleko bolji mob spram n82.
Staro 07.01.2009., 09:58   #30
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
dobro ajde mi nabroji jednu bitnu razliku u odnosu na n82? Ima malo bolji ekran i malo vecu bateriju...jaka stvar. kako volim dok ljudi pisu gluposti....
normalno da se ne isplati osim ako nemas fetish na klizne mobitele
ukratno n85 ti je klizni n82 sa malo boljim ekranom...
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
