Staro 11.12.2008., 21:34   #1
KidBoy128
KidBoy128's Avatar
Datum registracije: Apr 2008
Postovi: 291
Saitek Cyborg Keyboard
na ovo sam slučajno naletio http://www.saitek.com/uk/prod/cykey.htm
ima li to za kupit u Hr?
prvi put čujem za tu firmu al nema veze
možda je malo prešarena ali s cijenom od 80$ mogla bi dobro proć
u svakom slučaju jeftinija je od g15
a koliko sam pročito ima ima sve mogućnosti ko i g15
Cyborg Keyboard
High-end, adjustable, gaming keyboard with customisable backlighting,
programmable functions and media keys.
  • Multi-colour backlighting with Tru Vu illumination through keys (mix shades from Red through Amber to Green) and adjustable brightness
  • Touch-sensitive, backlit dashboard control panel
  • WASD, cursor, ‘Cyborg’ and NumPad keys can be lit independently from the rest of keyboard to highlight commonly used gaming keys
  • Cyborg Mode – instantly disable the Windows keys and configure the colour and brightness of your gaming keys at the touch of a button
  • Set and forget – persistent key illumination settings ensure colours remain even after a system reboot
  • 12 programmable ‘Cyborg’ keys
  • Hard wearing, metal-plated key caps in key gaming areas
  • Pass-through USB, audio and microphone sockets
  • Enhanced multiple key presses in gaming areas for complex in-game commands
  • Adjustable wrist rest and keyboard rake angle (front and back)
  • Gold-plated connectors for USB and Audio
System Requirement:
Connectivity: USB 2.0 Windows XP, XP64 and Windows Vista (all versions)
ako se može nabavit u Hr onda bi to mogla bit moja sljedaća tipkovnica
KidBoy128 je offline   Reply With Quote
Staro 11.12.2008., 21:44   #2
atha
atha's Avatar
Postovi: 9,067
Izgleda kao shit sa pocetka 80ih + je preskupa. Nije Saitek nepoznat, stovise vec dugo radi gaming opremu i periferiju.
U svoje doba Eclipse je bila solidna tipkovnica. Nazalost, dobar dizajn zasjenila je prilicno losa kvaliteta. Vec nakon godinu dana su tipke pocele zvoncati, slabije hvatati, guliti se i slicno...
___________
Just atha
x
Staro 11.12.2008., 21:57   #3
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,158
ta saitek je pobrala dobre ocjene u bugu od testiranih "gaming" tipkovnica, i mislim da se prodavala u linksu neko vrijeme, pa mozes upitat na njihovom forumu ako ce je nabavljat opet
Staro 11.12.2008., 23:54   #4
KidBoy128
KidBoy128's Avatar
Postovi: 291
to sam i mislio da nije kvalitetne izrade
al nema veze, godinu dana je dovoljno, poslje ju dam bratu i sve super
moram priznati da ne izgleda loše
Staro 17.06.2009., 00:47   #5
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,143
Autor KidBoy128 Pregled postova
ima li to za kupit u Hr?ako se može nabavit u Hr onda bi to mogla bit moja sljedaća tipkovnica
Imam mjesta + idealnu ladicu ispod stola za backup tipkalice. Za nocno klikanje - koliko god mi bile odbojne gamer tipkalice - nesto mi se svidja da je izvucem za lezerno kratko lampionsko tipkanje. Predpostavljam da sad ima vec ponesto PCE vlasnika? Ovo cudo se prodavalo u Linksu ali vise ga nema
Staro 17.06.2009., 09:03   #6
atha
atha's Avatar
Postovi: 9,067
The keyborad is so Visage.
Biti ce da prodaja nije polucila uspjehom.
___________
Just atha
x
Staro 17.06.2009., 15:15   #7
Dr. Faustus
___________
Dr. Faustus's Avatar
Postovi: 182
Melcomp, Varaždin
http://www.melcomp.hr/katalog/index....1&A=C&G=MOU&S=
Pogledaj pod šifrom MOU-469.
Bilo ih je i u Algoritmu (Zagreb), ali trenutno ih nemaju.
Ich fühle Mut, mich in die Welt zu wagen, mich in die Welt zu wagen,
Der Erde Weh, der Erde Glück zu tragen,
Mit Stürmen mich herumzuschlagen
Und in des Schiffbruchs Knirschen
nicht zu zagen.
Dr. Faustus je offline   Reply With Quote
Staro 21.06.2009., 17:55   #8
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,143
Autor Dr. Faustus Pregled postova
Melcomp, Varaždin
http://www.melcomp.hr/katalog/index....1&A=C&G=MOU&S= Pogledaj pod šifrom MOU-469. Bilo ih je i u Algoritmu (Zagreb), ali trenutno ih nemaju.
Navodno u Algoritmu stoji vec duze jedan jedini komad koji nije prodan. Melcomp su cudne biljke, morao bih tamo nazvati Darija pa znati tocno jel ih imaju. Ali ogadio mi je prijatelj neki dan tu tastaturu. Kaze da su "poboldane" tipke odvratno ljigave i sklizave. Posebno kad se spusti na normalne. Jednu je morao na zamjenu nositi jer mu je panel prestao raditi.
Hm. Jeste li obradili neku temu "tko je tko" medju keyboard krijesnicama? U nekom PCE postu veceg kalibra?
Koja je The tipkalica, sto manjih gabarita sa nekom plavkastom pozadinom i ako je moguce, da ima nesto macro~biotike od softa + pa par bochnih butona?
Staro 01.01.2012., 21:23   #9
/\ŁF
Datum registracije: Oct 2010
Postovi: 73
Da malo dignemo temu..
Imam Saitek Cyborg V. 7 tipkovnicu, pa me zanima da li se negdje mogu nabaviti tipke sa nasim znakovima?
Ili ako nista, s koje tipkovnice bi tipke odgovarale ovima?
/\ŁF je offline   Reply With Quote
