Staro 10.10.2008., 23:51   #1
Mario P.
Mario P.'s Avatar
Lokacija: stan
Postovi: 97
Najtiše kućište
Molim preporuku.
Raspolazem sa 1500kn i htio bih zbilja nesto sto buku smanji na minimum a opet da bude provjetrenost bude solidna npr. ne kao Antec 900 koji je glasni usisavač prašine vec nesto bliže Antec 182.
Hvala!
Kaaaaaaaj si!
Mario P. je offline   Reply With Quote
Staro 11.10.2008., 00:00   #2
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,358
Autor Mario P. Pregled postova
Molim preporuku.
Hvala!
uzmes antec P182 + 3 venta 120mm noctua ili scythe S-flex
Staro 11.10.2008., 00:01   #3
cuna
te je a...
cuna's Avatar
Lokacija: Duga Resa
Postovi: 598
Molim preporuku.
Hvala!
pa kaj ti fali antecu P182?
cuna je offline   Reply With Quote
Staro 11.10.2008., 00:09   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je online   Reply With Quote
Staro 11.10.2008., 00:19   #5
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor nick praskaton Pregled postova
Imao prije par dana takvo kućište, na servisu. Ono kućište je strava, jednostavno je tiho i ima dobru izolaciju, svi ventovi su bili ~900RPM (Scythe) i jednostavno se računalo nije čulo
Staro 11.10.2008., 07:43   #6
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
A recimo CM Cosmos (S)... vrlo kvalitetan layout, uz prostranost, zvucnu izolaciju, promisljenu strukturu i solidnu kvalitetu izrade, a jedina mu je (nazalost) mana cijena - malo veca od predlozene (1700-1800).
IMHO "pick of the year" !
EDIT: Test
The Secret ...
Staro 11.10.2008., 10:16   #7
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ne postoji najtiše kućište postoje samo kućišta sa boljim ili lošijim predispozicijama da se s njima složi tih stroj tako da staviš tihe komponente pretpostavit ću da (s obzirom na tvoj post) antec ne dolazi u obzir zbog cjene pa ću ti reć - Chieftec big toweri su ono što tražiš, koji model ćeš uzeti je tvoja stvar...
Na to kupiš još neke dobre ventove i pasivne komonente te neki tihi PSU (ili čak pasivni) i na kraju balu spužve za damping i objesiš diskovlje na lastike...
Have a nice day...
Staro 11.10.2008., 10:34   #8
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
da, ovaj...1500 kn, pa ajme meni kolko vi love imate?
BTW...dali meni tko moze preporucit kuciste do nekih 350 kn?
Evo, meni se osobno svidja ovo:
http://www.ve-mil.hr/opis.aspx?prika...=0&Sifra=21540
Dali je to dobra kupovina?Ili postoji nesto bolje?
Hvala
Staro 11.10.2008., 10:34   #9
veki19
veki19's Avatar
Lokacija: Viškovo,Rijeka
Postovi: 489
Autor yedwy Pregled postova
Slažem se u potpunosti.
Tihog kućišta nema,komponente u kućištu su te koje trebaju biti tihe.
Bolje sačuvaj 1000 kn i kupi si nešto jeftinije za 500,jer ćeš ostat razočaran kad uzmeš ''tiho'' kućište i vidiš da ti je buka opet ista.
veki19 je offline   Reply With Quote
Staro 11.10.2008., 12:00   #10
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Autor kkljajic Pregled postova
Hvala
Vrlo cvrsto i solidno, ali straga stane svega 92mm vent, sprijeda je 120mm koji puse u nista...ovaj grafu, a ovako glupo rjesenje hladjenja HDD-ova treba traziti.
Zapravo - ne znam ni sam sto bih kupio u tom cjenovnom rangu. Imas Gigabyte koji dodje s ventovima i cini se OK ali je uzasno lagan (5kg, horor, ko da je od papira izradjen), Chieftecove varijacije na temu, Sharkoone Rebel9/Revenge/Avenger koji su mozda i najbolji izbor ako upotrijebis dosta spuzve i/ili stiropora da pozatvaras nepotrebne rupe. A Anteca NSK4000 izgleda nema...
Staro 11.10.2008., 12:03   #11
cuna
te je a...
cuna's Avatar
Lokacija: Duga Resa
Postovi: 598
Dobar izbor bi mu bio i CM 690
Staro 11.10.2008., 12:23   #12
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Autor Tomislav Č Pregled postova
...koji je isto porozan ko ona kolica u supermarketu.
Staro 11.10.2008., 12:27   #13
yedwy
yedwy's Avatar
Postovi: 6,956
CM690 je jako dobar - ako znaš što radiš i ako ne cjepidlačiš oko gluposti, s obzirom da on neće takav prozračni case ima chieftece...
Have a nice day...
Staro 11.10.2008., 13:18   #14
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Antec P182 je jednostavno fantastičan, da skup je ali kućište se kupuje rijetko i ne mjenja se često.
Svog anteca sam uzeo prije jedno godinu ili nešto više, kućište je fenomenalno, promjenio sam ventove sa noisblocker xl1 koji rade na 700-800rpm i nečujni su.
Prednji filteri za prašinu su vrlo efikasni i u kućištu mi nema prašine (tj ima vrlo malo) iako ga 1 godinu nisam čistio (samo očistim filtere svaki mjesec 1x pod vodom za 10 sec).
Kućište je odlično napravljeno i ima odličnu izolaciju zvuka, te ne reznira za razliku od nekih
Temperature su naravno super iako ima spore ventilatore.
Staro 11.10.2008., 14:49   #15
VedroP
VedroP's Avatar
Postovi: 3
Hvala
Za te novce imaš sharkoon rebel9. Potraži malo po forumu ima nekoliko komada dobro sređenih.
VedroP je offline   Reply With Quote
Staro 11.10.2008., 16:17   #16
Exe
Exe's Avatar
Postovi: 349
Dali bolje hladi Antec 900 ili 182
Exe je offline   Reply With Quote
Staro 12.10.2008., 12:36   #17
Mario P.
Mario P.'s Avatar
Lokacija: stan
Postovi: 97
Hvala ljudi!
Jedna stvar sta me smeta kod tih skupih kucista ko npr. Antec 182, pazi sad, a i sami ste to rekli, kućiste je cirka 1000 kn. E sad, ventovi koj s njim dođu i nisu bas nesto u smislu protoka i buke, pa kaže, kupi 3 Sythe-ova ili Noctua, a svaki je nekih 120 kn...znaci na tih 1000 kn jos nekih 350 dodaj za ventove...
To mi se gadi kod tih kucista!
Pa jebem mu sunce, vec kad se prezentiras za vrh i papreniju cijenu i kvalitetu, budi to i do kraja!
p.s. Chieftec kažeš, hmmmm...pogledat cu ih malo al iskreno, ne sviđja mi se njihov izgled, a pošto ću pljunut malo vise love htio bih da mi se sve karte poslože
Kaaaaaaaj si!
Staro 12.10.2008., 12:38   #18
Mario P.
Mario P.'s Avatar
Lokacija: stan
Postovi: 97
Autor veki19 Pregled postova
A ovoga se najviše bojim
Kaaaaaaaj si!
Staro 12.10.2008., 13:11   #19
cuna
te je a...
cuna's Avatar
Lokacija: Duga Resa
Postovi: 598
Hvala ljudi!
Pa uzmi 3 chieftec ili coolermaster ventilatora od 120mm, to ti je sve zajedno 120kn!
Staro 12.10.2008., 13:39   #20
yedwy
yedwy's Avatar
Postovi: 6,956
Sa CM690 dobiješ 3 komada, nisu najbolji na svjetu ali nisu ni tak loši, ipak ako baš oćeš uber tiho najbolje je uzet neke druge ventove, s druge strane CM690 i 4 venta (kolko je njemu dosta da bude uber proluftan) ti koštaju oko 1000kn sve da uzmeš i ove skuplje ventove iako YLovi (čifteci) iz VeMulja i nisu skupi a dobri su...
Inače ja imam sve ventove ekstra podložene gumama, za svaki slučaj...
Have a nice day...
Staro 12.10.2008., 13:52   #21
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Hvala ljudi!
3 NB ili Chiefa su 100-200kn a odlični su, ne padaj na te brendove tipa noctua ili scythe
Ovi u antecu su tihi, nisu nečujni ali su tihi na low speed (1200rpm) i pritom generiraju soldian protok, da ne govorim kakav im je protok na medium i high brzinama
Staro 31.10.2008., 21:09   #22
Chome
TK
Chome's Avatar
Postovi: 1,090
Mene zanima isto koje bi kučšte bilo najtiše ali do ~400Kn a i da nije baš ružno.
Chome je offline   Reply With Quote
Staro 31.10.2008., 21:14   #23
yedwy
yedwy's Avatar
Postovi: 6,956
Ono u kojem nema niti jedne komponente...
Ne postoji "najtiše kućište" postoje samo više ili manje tihe konfiguracije a dobro kućište je samo jedna od stvari...
Ukratko - ako oćeš sam porčkati i dodatno utišavati - Sharkoon Rebel 9 ili neki chief bi ti bili ok, ako nećeš imaš antec midi towera u tom rangu cjena pa nekih coolermastera...
Have a nice day...
Staro 31.10.2008., 21:28   #24
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,691
Ako hocete tako jako tiho kuciste i sve to onda evo jedan link sa foruma
http://forum.pcekspert.com/showthread.php?t=124636 .Mozda malo glup i banalan prijedlog ali za onoga ko ima volje za to stavljat definitivno jako dobro rijesenje i ne previse skupo
Staro 31.10.2008., 21:32   #25
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,221
dosta vam je case (vazno da je dobro napravljen,ne savitljive stranice,cvrst) kao chuftek za cc600 kn. i radije onda ulupati parice za tise ventove,bolje hladnjake.
nego izbrojati 1000kn za case koji je isti racku ko ostali.ali vise cijenjen.
moje misljenje.
TomG je online   Reply With Quote
Staro 02.11.2008., 19:13   #26
weirdfreak
weirdfreak's Avatar
Postovi: 7
Talking Wooden Self-Made
Najbolje kućište ti je tvoja drvena ladica u stolu... Prosurfaj malo po netu i vidjeti ćeš šta ljudi rade... Ako imaš alata za obradu drveta i imaš malo volje, jedini trošak će ti biti kvalitetni ventovi
weirdfreak je offline   Reply With Quote
Staro 03.11.2008., 11:51   #27
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
sharkoon kučište (plus sharkoon napajnje), vent od proca stišati preko zalman fanmate, na grafičku stavit pasivni accelero kuler. po potrebi ostale 12cm ventove također stišati preko nekog potenciometra
ima cimer tu kombinaciju i što da kažem nečujno je. samo treba znati stišati ventilatore i odabrati tiho napajanje. po defaultu nema za kupiti tiho kučište. samostalan rad je neizbježan
jollyb je offline   Reply With Quote
Staro 04.11.2008., 03:19   #28
von Schultz
Postovi: 494
Autor Mar Pregled postova
Kaj onda na kraju uzeti? Jel su uopće navedeni primjeri poput NB.a i Chief.a barem malo efikasniji (tj. tiši) od originala u Antecu?
von Schultz je offline   Reply With Quote
Staro 04.11.2008., 15:24   #29
KidBoy128
KidBoy128's Avatar
Datum registracije: Apr 2008
Postovi: 291
Cooler Master Cosmos S 1850kn
ja ga imam i odlično je
ne samo da je tiho već i super hladi
jest da je malo više od tvojih 1500kn.
nemoraš kupovat niakve dodatne ventove jer ovi dovoljno dobro hlade i tihi su.
jedan na stranci koji puše po ploči, jedan sa stražnje strane koji ispuhuje topli zrak van, jedan je gore i jedan na kutiji za diskove
LINK
ili
CoolerMaster Cosmos 1430kn
stariji brat cosmos s
nisam ga imao priliku isprobt al je slično cosmosu s
u njemu također dobiješ ventilatore
uglavnom pogledaj na LINK
ps na gotovinu dobiješ popust par posto
KidBoy128 je offline   Reply With Quote
Staro 05.11.2008., 00:15   #30
von Schultz
Postovi: 494
Bio bih ful zahvalan ako mi netko može preporučiti ventove za mog anteca, odnosno odgovoriti na gore postavljeno pitanje!
Također, koji vent bi uzeo za proc, stari mi je na amd.u počeo zujati... Također da je ful tih...?
Puno hvala unaprijed!
