Staro 26.09.2008., 13:48   #241
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Update: Google Chrome 0.2.153.1 Beta
Release Notes: 0.2.153.1
Highlights
  • r2266 Fix scrolling (cannot scroll up) with touchpads on most laptops. Issue 4.
  • r2334 Fix the problem in 152.1 with the About box spinning forever to check for updates and leaving behind an orphaned chrome.exe process. Issue 2362
  • r2282 and r2320 Remove the separate installer for the Gears component. It is now installed as a versioned component alongside chrome.dll. When 0.2.153.0 (or later) is installed successfully, the previous version of Gears is uninstalled.
New Network and Window Managers: Testers Wanted
To use the new backend features, you can add a command line flag to the shortcut you use to launch Google Chrome. You can have multiple flags, so you can test both features if you want. To add a command line flag, right click the Google Chrome shortcut, choose Properties, and edit the Target field. You can just add the new flags at the end of the Target line.
The new command line flags are:
<b>
--new-http
Enables the new network layer. This is nearly complete, but there are still be some things that don't work. Areas that need more attention: SSL and SSL-EV sites, proxies (especially requiring authentication), very large downloads (>2GB).
Please put [new-http] in the description for any bugs you file.--magic_browzR
Enables the new tab and window manager code. The code has been refactored to help make it more portable, easier to add new features, and make it more Windows-friendly. Things like ' Tile windows horizontally' or extensions that manage multiple desktops/monitors should work, the full Google Chrome window menu is available when you right click a pop-up or application window title bar, and pop-up address bars looks nicer.
A couple of known issues on Vista (already fixed, but not in time for this release): the new tab button does not work and you cannot resize windows. Please put [magic_browzR] in the description for any bugs you file.
</b>
Other Notable Changes
User Interface
  • r2026 Double-clicking a tab's entry in Google Chrome's task manager (Shift+Esc) brings that tab to the foreground.
  • r2222 Your choices for Clear browsing data... are saved so the same boxes are checked the next time you open the dialog.
  • r2322 Add an "Add to dictionary..." option to the right-click menu for misspelled words. Use this to add a word so that Google Chrome does not highlight it as misspelled.
  • r2412 Fix an issue that could prevent users from saving bookmarks. Issue 1946.
  • r2413 Allow mutiple bookmarks to refer to the same URL (which can be useful if you want a bookmark on the bookmarks bar and also saved under Other bookmarks). To get a new bookmark for a URL, either drop a link on the bookmarks bar (not by dragging the star) or right-click the Bookmarks bar and choose Add page...
  • r2504 Adds a Page info option to the context menu (right click). This brings up the same information as double clicking the lock or warning icon in the address bar of an SSL page.
Plugins
  • r2400 Add support for Adobe Reader's fast web view, which fixes a performance problem loading PDF files. Issue 206.
Javascript/Web API
  • r2061 Add anti-aliasing support for SVG shape-rendering="crispEdges".
  • r2250 Make navigator.language reflect the current UI language for Google Chrome instead of the operating system. Issue 1862.
SSL and SafeBrowsing
  • r1998 Fix a problem with links or redirects to pages containing malware. The warning page now correctly identifies the new page as the malware host, rather than the previous page.
  • r2098 Add support for Extended Validation (EV) certificates from GlobalSign.
  • r2363 Add support for Extended Validation (EV) certificates from CyberTrust.
Tab Model Rewrite (--magic_browzR)
  • r1996 Fix several issues on Vista, most notably that tabs were not selectable with the mouse.
  • r2205 Allow windows to be resized on Vista
  • r2406 Fix an issue with tooltips showing up in the wrong location.
Other
  • r2223 Turn off making a request to determine the local URL for Google (google.co.uk, google.co.in, etc) when Google is not your default search provider.
  • r2323 (related to r2223) Don't set a cookie when making a request to determine the local URL for Google.
  • r2287 Fix a problem that prevented Google Chrome from being uninstalled immediately. Issue 2321
  • r2457 Fix the Open dialog (Ctrl+O) so that it does not lock the directory from which you open a file. Issue 2617.
  • r2466 Fix proxy exceptions that include upper-case characters. Issue 541.
Crashes
  • r2028 Fix a crash when using Find next (F3). Issue 1669, <b/1341577>
  • r2090 Fix a crash when using View Source on an https page. Issue 1951.
  • r2131 Fix a crash when copying data to the clipboard. Issue <b/1374632>
  • r2261 Fix a crash when saving a page. Issue 2206
Liquid Snake je offline   Reply With Quote
Staro 04.10.2008., 00:01   #242
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,539
Zamrla tema pa da ju malo dignem, http://www.googlechromeplugins.com/.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 04.10.2008., 01:54   #243
thopok
Lokacija: Splity
Postovi: 3,003
Kako je i prije napomenuto:
On September 9, 2008 the German Federal Office for Information Security (BSI) issued a statement about their first examination of Chrome, expressing a concern over the prominent download links on Google's German web page, because "beta versions should not be employed for general use applications" and browser manufactures should provide appropriate instructions regarding the use of pre-released software. They did, however, praise the browser's technical contribution to improving security on the web.
Several privacy concerns have surfaced regarding data collected via Chrome, including browsing habits and personally identifiable information.
Tako je na kraju ipak uklonjen.
Staro 04.10.2008., 14:32   #244
Liquid Snake
Postovi: 166
Google Chrome 0.2.154.0 Beta
Code:
Release Notes: 0.3.154.0
Highlights: Plugin Fixes
This release includes several changes that improve the performance of plugins, especially Adobe Flash video.
  • r2459, r2744 Improve the performance and scrolling of plugins. This especially improves pages with multiple plugins playing video. Note to developers: this affects windowless plugins only. (Issue 93)
  • r2539 Fixes plugins not playing when embedded in a third-party frame on a page (Issue 1533)
  • r2740 Fixes a problem where using Flash plugins could lock up Google Chrome and cause 100% CPU usage (Issue 387, Issue 772)
New Network Layer: Testers Wanted We're just about ready to turn on the new HTTP networking code by default. There are a few remaining bugs, mostly in handling SSL edge cases and HTTP authentication. To use the new HTTP code, you can add a command line flag to the shortcut you use to launch Google Chrome. To add a command line flag, right click the Google Chrome shortcut, choose Properties, and edit the Target field. You can just add the new flags at the end of the Target line. The new command line flag is: <b>
--new-http Enables the new network layer. Please put [new-http] in the description for any bugs you file.
</b> Other Notable Changes User Interface
  • r2474 'Duplicate' (right click on a tab > Duplicate) opens a new tab instead of a new window.
  • r2631, r2678 Adds the ability to sort table views in the user interface and turns it on for the keyword editor (Options > Basics > Default search: Manage) and cookie manager (Options > Under the hood > Show cookies).
  • r2643 Makes the link in the About box clickable. The link opens a page acknowledging the authors and license terms of third party code and software used in Google Chrome.
  • r2645 Keeps focus on the last match after the Find in page box is closed. (Issue 455)
  • r2704 Ctrl+S now brings up a Save Page dialog. (Issue 1653)
Search Engines and Suggest Services
  • r2564, r2623 Fixes search results when the default search provider is voila.fr (or orange.fr) and enables search suggestions for voila.fr (French) and daum.net (Korean).
  • r2630 Fixes a problem with importing Windows Live Search as the default search engine.
JavaScript/Web API
  • r2571 Adds a command line switch to set the user agent string for testing: --user-agent="some string". We'll be making changes to the user agent string before we exit Beta, and this will help in testing site compatibility. This isn't really Web API, but seems mostly of interest to web developers.
Staro 13.10.2008., 02:13   #245
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Meni se još uvijek crasha glavni tab, te bilo kakvo diranje na YouTubeu osim gledanja klipa od početka do kraja. Iritantno da sam ipak ovisna o Ffoxu još.
Beta or no Beta
Ladybug je offline   Reply With Quote
Staro 13.10.2008., 02:17   #246
crn
The Geek Wants Out
crn's Avatar
Lokacija: xxx
Postovi: 1,193
pa samo skini Chromium... ja ga vozim od prvog dana i nikakvih rušenja ni problema.
The Geek Wants OUT
by Ernest Cline
At first glance
I probably appear to be a somewhat ordinary,
somewhat average looking fellow.
Calm, harmless, at ease.
But this is by design.
You see, it is through decades of research and rigorous training that I have crafted this façade of normalcy.
And now, through intense concentration,
I am able to function in a social setting.
I can speak at length with educated people about
pertinent matters of public importance,
such as literature,
or the current political climate in Europe.
I am capable of conversing with you
without ever revealing that just underneath the surface
of this manufactured veneer
there hides an altogether different person.
A monster, some might say.
My alter-ego.
He is the opposite of the image I project.
He is the antithesis of Cool.
He is the LAST person you want to get trapped in a conversation with.
He is The Geek.
The obsessive science fiction movie watching,
comic book collecting,
Monty Python dialogue memorizing,
Dungeons and Dragons playing GEEK
that I struggle daily to keep hidden from the world.
But The Geek Wants Out.
He want to talk to you.
He wants to give you his doctoral dissertation on why
The Adventures of Buckaroo Banzai Across the 8th Dimension
is the greatest fucking film of all time!
He wants to bitch slap you because
you’ve never seen Big Trouble in Little China.
What? Have you been living in a fucking cave?!
He wants to kick your ass in Star Wars Trivial Pursuit.
And he will.
Because he’s a fucking Geek.
And he wants his toys.
He wants the complete set
in mint condition,
still in the box.
He wants every item on the planet that is even remotely related to Ultraman.
Because Ultraman is Airwolf!
He could give a squirt of piss
about sports or politics or rhetoric.
Such things are of no consequence to him.
What matters is the release date of the next Lord of the Rings movie!
You see, The Geek can’t wait.
The Geek has no patience.
He wants what he wants when he wants it.
And all he wants is stupid shit!
He wants his own Tardis.
He wants his own light saber.
He wants to buy a DeLorean and he wants to drive it 88 miles per hour.
He wants movies.
He wants to see the Director’s Cut.
He wants the impossible to find Japanese bootleg with
6 minutes of never-before-seen footage.
He wants to watch Blade Runner. Again.
He wants to watch Brazil. Again.
He wants to watch A Clockwork Orange.
Again and Again!
But I deprive him of these things, as best I can,
until I can no longer ignore his voice
screaming in my head.
I am Jekyl. He is Hyde.
I am Bruce Banner. He is the Hulk.
Especially the Hulk from issues #272 to #378.
But no longer!
I am putting a stop to all this nerdy shit right now!
I’m an adult, for Christ’s sake!
And this body isn’t big enough for the both of us.
One of us has to go, and it’s gonna be him.
I banishing the Geek forever to the Phantom Zone,
just like in Superman II !
Because, in the end –
there can be only one.
crn je offline   Reply With Quote
Staro 13.10.2008., 02:28   #247
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Ista stvar (barem ovo s tjubom), s tim da Chromium rošta po Maxtoru toliko da poludim već.
Staro 13.10.2008., 09:36   #248
crn
The Geek Wants Out
crn's Avatar
Lokacija: xxx
Postovi: 1,193
Autor Ladybug Pregled postova
kod mene vrti youtube bez ikakvih problema i nema nikakvog roštanja po disku (i tako je od prvog dana)
XPpro sp2
Chromium 0.3.155.0 build 3281
Privoxy 3.0.10
The Geek Wants OUT
by Ernest Cline
At first glance
such as literature,
My alter-ego.
He is The Geek.
And he will.
in mint condition,
still in the box.
He wants movies.
Again and Again!
But no longer!
Staro 13.10.2008., 13:51   #249
bojan k.
Reserved Curator
bojan k.'s Avatar
Lokacija: Velika Gorica
Postovi: 78
Ako je ista stvar kao i kod regularnog Chormea, probaj pod Options/Under the hood isključiti "Enable phishing and malware protection".
bojan k. je offline   Reply With Quote
Staro 13.10.2008., 22:19   #250
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Autor bojan k. Pregled postova
Bez promjene. A nije ni u Flashu problem kad sam ga reinstalirala. Ha, well...
Staro 16.10.2008., 11:55   #251
Liquid Snake
Postovi: 166
Google Chrome 0.3.154.3 Beta
The release contains mostly bug fixes for 0.3.154.0, but it also introduces a new behavior for downloading files that could be executable content:
  • r3285 Changes the download behavior for files that could execute code (exe, dll, bat, etc.). These files are now downloaded to unconfirmed_*.download files. In the browser, you're asked if you want to accept the download. Only after you click Save is the unconfirmed_*.download file converted to the real file name. Unconfirmed downloads are deleted when Google Chrome exits.
User Interface
  • r3177, r3207 Enables sorting columns in the password manager, the list of URLs to load at startup, and the Google Chrome task manager. (Issue 2949, 95)
  • r3180 Adds a command line switch to start the browser in incognito mode. Thanks to Yarin.Kaul@gmail.com for the contribution. (Issue 1790, 2012)
  • r3189 Fixes the new bookmark bubble so that pressing enter with focus on the Edit button actually opens the editor. Thanks to developer0420@gmail.com for the fix. (Issue 2863)
  • r3209 Changes the text in the About dialog to link to credits for other open source software used in Google Chrome and to the Terms of Service.
  • r3264 Adds support for extended validation (EV) certificates issued ssued by Comodo using the AddTrust root. (Issue 2170)
Plugins
  • r3211 Fixes a problem with videos stopping after 1 second (Issue 115)
  • r3272 Allows plugins to post forms (for example, Adobe Reader forms). (Issue 629)
  • r3276 Adds better support for Windows Media player, specifically improving detection for that plugin at bloomberg.com. (Issue 2846)
  • r3327 Runs plugins at a normal priority so that they do not cause the browser to become unresponsive.
JavaScript/Web API
  • r3198 Optimizes the content-type detector ('MIME sniffer') to do fewer, more reliable checks based on data collected during the Google Chrome Beta.
  • r3231 Fixes a problem with page content disappearing behind plugin windows. For example, when you type a search on a page playing a YouTube video, the search suggestions stay visible instead of going behind the video window. (Issue 1788)
  • r3269 Change the minimum timer resolution for setTimeout() to 4 milliseconds (up from 1ms). At 1ms, some pages would spin in tight loops and consume 100% of CPU.
Crashes in 154.0
  • r3172 Fixes a crash when using the spell check Add to dictionary... fucntion. (Issue 3039)
  • r3278 Fixes a browser crash on tablet PCs running Microsoft Windows Vista.
Download
Staro 16.10.2008., 12:13   #252
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Dobro zar je toliki problem napraviti export bookmarka? I backup općenito barem passworda.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 18.10.2008., 15:41   #253
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Autor LAcy Pregled postova
O, da, jako monopolistički
Autor crn Pregled postova
Hvala na pokušaju pomoći, ipak je dakle samo bio problem u mom BIVŠEM zastarjelom kompu, koji je jučer zamijenjen zvijeri koja mi je promijenila život i poboljšala ga za 150%. Doživljaj YouTubea je kristalno jasan, nikakvih problema više nemam. Živijo!
Staro 19.10.2008., 01:14   #254
mikey_rs
volveraš
mikey_rs's Avatar
Postovi: 386
I dalje se ruši prilikom pokušaja otvaranja Opcija...
"I will like to die in my sleep like grandpa and not screaming like his passengers..."
mikey_rs je offline   Reply With Quote
Staro 19.10.2008., 01:23   #255
CeRmA
CeRmA's Avatar
Postovi: 137
Ma čini mi se da Chrome stvara velike probleme na slabijim konfama...npr. meni na EEEu šteka dosta. Stranice otvara ok, al Youtube...bljaky
IntelE5200 @3,6Ghz | Gigabyte P35-DS4 | 4 GB GSkill | VTX HD4850| Samsung F3 500GB+SamsungT166|LG H42N DVDRW |CREATIVE Audigy2 | GIGABYTE HybridTV | MicrosoftReclusa+ RoccatKone | DELLU2311H | & |ASUS EEE 1000HG - 2GB RAM Win7| & |Samsung Galaxy S2 | on TScum DSL routed by Siemens SX763 |
CeRmA je offline   Reply With Quote
Staro 19.10.2008., 01:28   #256
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Kako si google može dozvoliti takav fijasko sa youtube?! Nadam se da nije potrebno navoditi tko je vlasnik youtube-a.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 19.10.2008., 01:32   #257
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Staro 21.10.2008., 19:24   #258
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Jel kome izbacuje ovo na Chromeu?
http://www.imagesforme.com/show.php/194739_wtf.JPG
Staro 25.10.2008., 12:25   #259
Liquid Snake
Postovi: 166
Google Chrome 0.3.154.6
Bugs Fixed
  • r3753 Fixes a crash with Adobe Acrobat 9 whenever you close a tab that was showing a PDF file.
  • r3710 Fixes a crash while dragging tabs on Windows Vista with pen input or tablet services.
  • r3803 [Issue 3183] Fixes a crash while dragging tabs.
  • r3528 [Issue 2069] Fixes problems with the downloaded files shelf not closing and becoming unresponsive.
  • r3570 [Issue 3539] Fixes not being able to save 'unconfirmed' file types with different names (Save As...).
  • r3481 [Issue 666] Fixes Silverlight video not playing on some sites.
  • r3810 [Issue 2929, Issue 3315] Fixes the page encoding menu to work properly again.
  • r3546, r3659 [Issue 3039] Fixes a crash in the spell checker.
  • r3621 [issue 2901] Fixes Ctrl+K to work again (focus the address bar and clear it for a new search).
Staro 13.11.2008., 00:15   #260
Liquid Snake
Postovi: 166
Google Chrome 0.4.154.18 Beta
New Features
  • Bookmark manager with import/export.
    Use the 'Customize and control Google Chrome' (wrench) menu to open the Bookmark manager. You can search bookmarks, create folders, and drag and drop bookmarks to new locations. The Bookmark Manager's Tools menu lets you export or import bookmarks.
  • Cleaner Pop-up Blocker.
    The pop-up blocker formerly just minimized pop-up windows to the lower right corner of the browser window, create one 'constrained' window for each pop-up. Now, Google Chrome displays one small notification in the corner that shows the number of blocked pop-ups. A menu on the notification lets you open a specific pop-up, if needed.
Staro 13.11.2008., 01:34   #261
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Hm, da, a oni kojima server nije available za update, nek se krešu u registryju
http://www.google.com/support/chrome...&answer=111996
A ako ne nađu zadani folder u registryju, neka uninstaliraju i ponovno sami instaliraju. Koje li smo sreće, da ne možemo bekapirati bookmarkse prije uninstalla.
Staro 13.11.2008., 17:59   #262
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Ajd da dočekasmo i taj dan da možemo exportirati bookmarke, jupiiiiiiii. Update ne radi već odavno, od kada sam prvi put instalirao na divlje novu verziju.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 18.11.2008., 17:05   #263
Liquid Snake
Postovi: 166
Google Chrome 0.4.154.22
Bugs Fixed
[no id] Fixed horizontal scrolling with the mouse tilt-wheel.
49 Attempted fix for the Options dialog crashing Google Chrome on Windows XP 64-bit. We cannot reproduce the issue, so this might not fix all the crashes people are experiencing.
766 Folders you add to the bookmarks bar do not show up in the New bookmark folder list.
843 Invalid Content-Type in GET request to follow a 302 redirect from a POST request
2033 Text cannot be entered in textareas enabled by script.
2835 Changing the Google Chrome language only applies if you click OK.
3685 It was possible to show to context menus at the same time.
3424 Truncated confirmation button in download shelf for dangerous files.
4029 The context menu key should display the menu near the focused element.
4136 The download confirmation dialog would appear if you type in a file:// URL while a download is in progress.
4158 Javascript won't open an alert box when run from within a popup window
4178 Fix http://people.mozilla.com/~vladimir/demos/photos.svg (new Image() returns an <img/>).
4216 QuickTime plugin may display in the wrong position.
4271 Cleanup spacing and layout in the bookmarks manager.
4273 Plugin windows may stop responding to keyboard events.
4287 Exporting bookmarks saves the file without the .html extension.
4302 An unwanted download confirmation could render Google Chrome unresponsive when using a proxy server.
4306 Clicking to the right of text in the bookmark manager starts a select instead of a drag and drop event.
4316 Sometimes you have to restart twice to get an upgrade (will affect the next update, from 154.22).
4346 Clicking the 'plugin not available' link to install the missing Adobe Flash plugin would do nothing.
4364 Fix a crash when clicking away while a bookmark bar context menu is open.
4365 Search boxes on the New Tab page were too wide in right-to-left languages.
Staro 19.11.2008., 02:15   #264
Dottore
Dottore's Avatar
Postovi: 7,679
moraš ga ručno updateati ali u biti one početne 'ozbiljne' bugove su riješili skoro isti dan tako da se ne moraš opterećavati...
skini Chrome Nightly Builds Updater i sa njim možeš provjeriti koji je zadnji build, je li prošao stability testove i automatski ga skinuti ako želiš:
http://www.mediafire.com/download.php?lnlr71eu9sl
Restore last session tip
Updated version 1.2:
http://dirhael.dcmembers.com/cnu/
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 25.11.2008., 10:57   #265
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Hm, da, a oni kojima server nije available za update....
Woohoo, lijenost pobijedila once again. Chrome se sam apdejtao kako dobro
Staro 01.12.2008., 03:29   #266
tutix
tutix's Avatar
Postovi: 4,069
Postoji li kakvo riješenje za smooth scroll u Chromeu/Chromiumu? Fali mi to jer sam naviko na YASS u FF-u ili onaj ugrađeni scroll u Operi.
Staro 12.12.2008., 14:03   #267
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Evo koga zanima, dns je Chrome izašao iz bete, tako da možete slobodno update na novu verziju
Matth€w je offline   Reply With Quote
Staro 12.12.2008., 14:07   #268
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Nekako su na brzinu izašli sa finalom, negdje sam pročitao da bi se uvalili u preinstalciju. Još kad bi radio pod W7, možda i radi, provjerim kad dođem doma.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 12.12.2008., 14:23   #269
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Meni je Chrome normalno radio u W7?! Jos dok je bio beta. Verzija prije 2-3 tjedna ...
Tomo je offline   Reply With Quote
Staro 12.12.2008., 14:33   #270
Big Guy
RPG player
Postovi: 1,574
popravio se Chrome ili još ima onaj spyware ?
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
