Staro 18.05.2004., 02:04   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
R300 Ruby Rap v2
Evo-kako je i obećao Colourless je izbacio i "pravu" verziju
Ukratko- Well, there you have it. Multipass versions of the shaders. All but one of the shaders should no produce identical output as the original, assuming I haven't fubared any of the shaders while attempting to multipass them and don't know it. The 'problem' shader is the Cornea Reflections on Ruby's Eyes. The multipass shaders that I've used should be reasonably close but it wont be the same. I doubt it's going to be something that people are likely to notice anyway but I have no idea what they are supposed to look like anyway.
Skidanje
http://www.users.on.net/triforce/ruby/r300rubyrap2.zip
Upute
http://www.users.on.net/triforce/ruby/r300readme2.txt
Sporije je, ali je puno ljepše
Uživajte.
Staro 18.05.2004., 14:13   #2
Jelc
Super Moderators
Postovi: 17,485
Evo-isprobano i radi
Staro 30.05.2004., 17:58   #3
rprivrat
Lokacija: Ribarska 29, 52203 Medulin, Hrvatska
Postovi: 225
Što radi ?
A što radi, ja sam to skinuo i neznam što bih sa time.
Dali mi nešto fali, razipao sam sve u navedeni direktorij, i sad neznam što sa time treba raditi, da dobijem neki rezultat.
rprivrat je offline   Reply With Quote
Staro 31.05.2004., 02:07   #4
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Re: Što radi ?
a da pročitaš upute?
pinsla je offline   Reply With Quote
Staro 31.05.2004., 09:44   #5
rprivrat
Postovi: 225
Re: Re: Što radi ?
Ako misliš na R300readme2.txt da su to upute, onda sam ih pročitao. Po tim uputama, (ako su to upute) razipao sam fajlu r300rubyrap2.zip u direktorij ATI Demos\DoubleCross i stvarno se ništa nije dogodilo, osim što sada imam u tom direktoriju i direktorij Shaders itd. uglavnom sve skupa veliko 755 Kb.
BTW fajla iz upita ( Sushi.ini ) niti ne postoji na mojem disku.
Dali sam skinuo neki krivi zip ??????????
r300rubyrap2.zip = 120 Kb
Staro 31.05.2004., 14:23   #6
Jelc
Super Moderators
Postovi: 17,485
Pa ako si skinuo demo sa ATI-jevih stranica, i stavio taj wrapper-moralo bi delati.
Samo nemoj reć da si zaboravil skinut demo
Meni dela i sa prvom i sa drugom verzijom...
Staro 31.05.2004., 16:51   #7
rprivrat
Postovi: 225
Demo?
Sory !
Nisam skinuo demo.
A niti ne mislim ( 130 MB ).
Thanks
Staro 01.06.2004., 00:09   #8
pinsla
pinsla's Avatar
Postovi: 1,860
Re: Demo?
Sory !
Nisam skinuo demo.
Thanks
Staro 01.06.2004., 12:24   #9
ßellerophon
Sannin
ßellerophon's Avatar
Datum registracije: Jun 2003
Postovi: 1,568
: hitthewal
YES - BUT /
