Staro 06.11.2007., 19:01   #1
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
AMD Dual-Core Optimizer
Da li ga koristite?Kakva su vam iskustva.Kada sam prvi puta upiknuo ovaj x2 3800 stavio sam ga na windowse i to me dovelo de formata c.Jednostavno su windowsi uporno javljali grešku .Sada mi vrag neda mira i stavio bi ga najradije ponovno.Ustvari podsjetila me igra Company of heroes-opposing fronts koja je vidi vraga javila da imam x2 i da bi bilo dobro staviti optimizer od amd-a.
Igra radi savršeno i bez tog drivera za procesor ali baš me zanimaju iskustva ako koristite taj optimizer.
AMD Dual-Core Optimizer - The AMD Dual-Core Optimizer can help improve some PC gaming video performance by compensating for those applications that bypass the Windows API for timing by directly using the RDTSC (Read Time Stamp Counter) instruction. Applications that rely on RDTSC do not benefit from the logic in the operating system to properly account for the affect of power management mechanisms on the rate at which a processor core's Time Stamp Counter (TSC) is incremented. The AMD Dual-Core Optimizer helps to correct the resulting video performance effects or other incorrect timing effects that these applications may experience on dual-core processor systems, by periodically adjusting the core time-stamp-counters, so that they are synchronized.
http://www.amd.com/us-en/Processors/...1_9706,00.html
Zadnje izmijenjeno od: Mladenxy. 06.11.2007. u 19:13.
Staro 06.11.2007., 20:55   #2
Ovca
KozajeZakon.
Ovca's Avatar
Postovi: 303
Koristim ga od prvog dana sa X2 4000+...jednostavno me jedno citanje ovog threada nagovorilo i sljaka bez beda...prati upute.
http://www.xtremesystems.org/forums/...ad.php?t=81429
Ovca je offline   Reply With Quote
Staro 06.11.2007., 22:00   #3
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Koristio sam ga na sva 4 windows sustava koja su trenutno u opticaju (oba XPa i obe Viste) i nikad s njim nikakvog problema nisam imao...
Have a nice day...
Staro 06.11.2007., 22:16   #4
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
Upravo instalirao i sve pet,fakat ne kužim koji je vrag bio prošli puta kada me ta bezazlena instalacija dovela do formata c.
Staro 06.11.2007., 22:19   #5
p3tar
Mozilla Slave
p3tar's Avatar
Lokacija: Daruvar
Postovi: 494
I ja isto ga koristim od kad sam kupio Opterona, tak da ni neznam kako bez njega rade igre
p3tar je offline   Reply With Quote
Staro 07.11.2007., 01:25   #6
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,951
Hehe, i meni se to dogodilo. Uglavnom, kad se promijenio kernel za 1 jezgru na 2, windowsi se zblesirali i to je to :-D Reinstall
m4dm4n je online   Reply With Quote
Staro 07.11.2007., 06:44   #7
yedwy
yedwy's Avatar
Postovi: 6,956
DA to sa kernelom je opće poznata "nezgoda" kod upgradea...
Have a nice day...
Staro 07.11.2007., 11:59   #8
majk
majk's Avatar
Lokacija: Ri
Postovi: 300
Autor yedwy Pregled postova
Neki put se nece windowsi prepoznati viseprocesorski sustav ili
nema driver za "Multiprocessor ACPI" na listi.
U boot ini dodati za "Multiprocessor ACPI PC"
/HAL=Halmacpi.dll /kernel=ntkrnlmp.exe
(nisam probao ali ntkrpamp.exe bi trebao prepoznati >4GB RAM-a na 32-bitnim sustavima ako ga uzmete sa SP za W2003 server)
ili ako nece raditi onda nazad na "ACPI Uniprocessor PC"
/HAL=Halaacpi.dll /kernel=ntoskrnl.exe
Mozete staviti dva reda (jedan za Uniprocessor drugi za Multuprocessor) pa ce se otvoriti meni kod svakog bootanja.
Prije stavljanja bilo kakvih parametara u boot.ini treba provjeriti da li su ovi fajlovi stvarno u \Windows\System32\ ako nisu onda su negdje u SP2 cab-u.
majk je offline   Reply With Quote
Staro 02.01.2008., 05:06   #9
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Evo malo čitao i našao isti problem ko moj, jel mi možete točno reči kaj se dobiva instaliranjem dotičnog, jer ja sam ga stavil na XP i sve se s***alo, pa sam spojil kontakte na CMOS i onda se je napokn sistem dignul i odma uninstal, sad imam Vistu pa neznam da da to stavljam jer mi se neda reinstal windowsa radit???
danc00 je offline   Reply With Quote
Staro 02.01.2008., 17:49   #10
yedwy
yedwy's Avatar
Postovi: 6,956
Ja samo mogu ponoviti - ja nisam imao amam baš nikakvih problema ali s napomenom da su svi XPi bili nativno instalirani na dual core dakle ne da je već bio OS gore prije nego je promjenjen procesor...
A što se dobiva - puno ili ništa, ovisno dal koristiš nešto što ga treba, ako ne onda ništa, ako da onda će ti to nešto puno lošije i sporije raditi ako ga nema, doduše to je na s939 za ove AM2 proceve koji imaju virtualizaciju nisam siguran jel im treba uopće taj fix...
Have a nice day...
Staro 03.01.2008., 00:08   #11
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
E pa ti si tak puno odg. s tim postom da je to strašno! Dobivaš puno i ništa, ovisi za kaj ga koristiš...BTW ko stavlja novi procesor a da ne mijenja windowse???
Staro 03.01.2008., 00:17   #12
Postovi: 7,568
Autor danc00 Pregled postova
Ja sam prilikom promjene Opterona i ovog X2 ostal na istim Windowsima. Onda dalje imaš ljude koji bez problema prelaze s Intela na AMD (i obrnuto), pa ostavljaju iste Windowse. Maknu sve drivere, naprave promjenu platforme i rade. Naravno ne ide svaki put sve bez problema, ali opet ovisi u kakvom stanju su Windowsi, ovisi kolko ljudi imaju strpljenja i volje, jer najlakše je oderat format, pa sve ispočetka. Sve u svemu reinstalacija Windowsa nije nužno potrebna prilikom promjene hardvera.
Staro 03.01.2008., 17:44   #13
yedwy
yedwy's Avatar
Postovi: 6,956
A kaj oćeš da ti kažem? Geeee kako si pametan jer nisi instalirao stvar koju je AMD izdao za svoje procesore, pa ti si onda definitvno car jer očito si pametniji od svih njihovih inžinjera i programera koji su jadnici i kreteni koji su nepotrebno išli pisati komad softwarea, ono bilo je ljudima dosadno pa eto išli nešto napisati... Jesi to htio čut? e sad si čuo a ti instaliraj ili nemoj - kako te je volja...
Have a nice day...
Staro 03.01.2008., 19:21   #14
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Bravo care !!! Htio sam čuti razlog zbog kojeg da stavim jer mi sad radi super a kad sam ih stavil zadnji put na XP sve mi se s***alo, pa pitam da ne skitam...al ti očito... ubiti nebum komentiral,da ne ispadnem pametan ko ti!!!!
Staro 03.01.2008., 19:28   #15
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ne kužim oko ćega se pjeniš ? Malo si napet
Mjenjao osobno i na soc. 939 i na AM2 jednojezgreni sa dvojezgrenim i nakon paljenja Windowsa, instaliravanja drivera od strane Windowsa (pisalo je onako - new hardware found) i nakon toga bio je potreban samo jedan restart i proradilo je sve bez reinstalacije Windowsa. Ne pada mi na pamet Windowse reinstalirati radi promjene proca...
Staro 03.01.2008., 19:30   #16
yedwy
yedwy's Avatar
Postovi: 6,956
Pa jesam ti ljepo rekao razlog postoje apolikacije koje ga trebaju inače će imati šugave performanse, koje aplikacije ga točno tebaju ti ja neznam reći ali sumnjam da je neko posebno i brojao, ima veze sa korištenjem određene instrukcije iz reperrtoara procesora i znam da su mahom igre, za veliku većinu aplikacija nema profita od optimizera, ali s obrzirom da optimizer NIJE razlog za tvoje probleme sa sistemom jer ako ih samo ti imaš a 99.9999´ usera na svjetu nema onda očito to NIJE uzrok nestabilnosti sustava, ali sam napomenuo da je to bio čisti install windowsa neznam dal ima kakvih problema na "nadograđenim" XPima jerr nisam isprobavao, na Visti 32 bit nema jer sam to imao pa znam ali za XPe neznam i za x64 neznam jer sam uvjek imao OS na dual coru originalno instaliran s njima u igri...
Have a nice day...
Staro 03.01.2008., 19:35   #17
Grofaz
Postovi: 285
Autor Vuco Pregled postova
Lol, meni na pamet ne pada ni kad matičnu mijenjam, kamoli proc.
Grofaz je offline   Reply With Quote
Staro 03.01.2008., 20:36   #18
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
ja ljepo pitam i onda se pjenim,a nije mi niš objasnil!?? Pa čemu služi forum nek da se izmjenjuju informacije!!! Pa nikad kad sam na forumu se ne pjenim, nek moram prestati onda stavljati tolke uskličnike i upitnike ak po tome zaključujete dal je netko živčan, ,sorry
P.S-po tome meni netreba taj optimizer, niš mi se komp ne buni bez njega!
Staro 03.01.2008., 20:51   #19
Vuco
Vuco's Avatar
Postovi: 9,505
Pa lijepo ti objašnjenje stoji u prvom postu.
Rijetko tko bi ti znao to objasniti po naški - al očito dolazi do problema oko sinkronizacije kod mjenjanja power management stanja. Šta da ti drugo kažemo ?
Ako si primjetio neka usporenja ili ti se neki benchevi čine presporim u odnosu na druge - može biti da ti treba Optimizer. A vidiš da se igre najčešće spominju kao problematične.
A zašto si ti imao problema sa Windowsima kada si ih stavio ? Tko će ga znat. Windowsi sami po sebi znaju puknuti kada se naknadno stavljaju driveri na već malo stariju instalaciju. Sve drivere je najbolje staviti kada su Windowsi friški i onda s njima nikada problema.
EDIT:
A i što se uskličnika tiče - i tu si u pravu. Ne znam za ostale, ali ja postajem napet kad vidim tisuću upitnika i uskličnika i dosta često mi se baš i ne odgovara na takve postove - kad sam napet, rađe odem dalje di se ne nerviram
Staro 14.01.2008., 20:29   #20
mikey_rs
volveraš
mikey_rs's Avatar
Postovi: 386
Respect. Ne kužim zakaj ljudi moraju svaku rečenicu 'izderavat'. I to s tolko uskličnika...
"I will like to die in my sleep like grandpa and not screaming like his passengers..."
mikey_rs je offline   Reply With Quote
Staro 08.10.2008., 21:57   #21
galatasaray
galatasaray's Avatar
Lokacija: Tuzla
Postovi: 35
Ja nikad nisam koristio ovaj optimizer, evo slucajno od kako visim na ovom extra forumu svasta sam naucio. Skinuo sam taj optimizer ima neka 4 MB, koristim 5200+ AM2 al onaj link gore na pocetku sto je postavio @Ovca, ondje ne radi onaj hotfix, jel moram instalirat i njega i gdje da ga nadjem il samo ovo sto imam instaaliram??
AMD 5200+ AM2, dual core/Sapphire HD 4850 512 MB/2x1GB Take MS (800Mhz), WD 160GB/ Pioneer DVD-RW/ Fortrnon BlueStorm II ATX 500 W
galatasaray je offline   Reply With Quote
Staro 08.10.2008., 23:53   #22
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
EDIT: agrrrrhhh, sto mrzim kad netko ovako digne thread star godinu dana iz mrtvih a ja ne pogledam jebeni datum i potrosim pola zivota tipkovnici na post. smrt njubarama, sloboda narodu...lock threadovima starijim od mjesec dana
Staro 09.10.2008., 00:09   #23
galatasaray
Lokacija: Tuzla
Postovi: 35
Autor greg SE Pregled postova
Haj ne zezaj, sad ispade da mi sto smo od skora na forumu treba da odemo sa njega, jel to???
Pito sam ako mozes pomoc bio bi zahvalan ako ne....
off topic
Vi iz vinkovaca treba da ste mekan narod, imam ja na faxu nekih doduse djevojke
Staro 09.10.2008., 03:17   #24
Vuco
Vuco's Avatar
Postovi: 9,505
Autor galatasaray Pregled postova
Pa jel imaš kakvih problemasa radom procesora ? Inače, optimizer i hotfix su potrebni ako koristiš CnQ-et.
Zakrpu (ako ju želiš stavljat) skini s ovog linka:
http://support.microsoft.com/?id=896256
Direktan link na DL:
http://www.microsoft.com/downloads/d...8-34FB8A0FCE3B
Staro 09.10.2008., 11:56   #25
hrcfaca
hrcfaca's Avatar
Postovi: 524
Kako se on aktivira amd optimizer?
hrcfaca je offline   Reply With Quote
Staro 09.10.2008., 12:07   #26
Vuco
Vuco's Avatar
Postovi: 9,505
Autor hrcfaca Pregled postova
Instaliraš ga.
Nećeš ti ništa osjetiti, osim ako do sada nisi imao problema u igrama (najčešće) ili slično. Prouči malo tematiku, pa ćeš vidjeti gdje i zašto je on potreban.
Staro 09.10.2008., 12:19   #27
hrcfaca
hrcfaca's Avatar
Postovi: 524
o nema veze ako mi igra šteka rdi grafe?
Staro 09.10.2008., 12:22   #28
Vuco
Vuco's Avatar
Postovi: 9,505
Ako ti šteka radi grafe, onda nema ama baš nikakve veze nit će ti Optimizer išta pomoći.
Velim, prouči tematiku, pa ćeš to i sam vidjeti.
Staro 09.10.2008., 15:28   #29
galatasaray
Lokacija: Tuzla
Postovi: 35
Hvala drug, extra objasnjeno. Hvala na linkovima!!!!!
