#91 |
machine that goes ping!
Postovi: 478
ne shvaćam što si želio reći... misliš na sRGB presetove u navedenim monitorima, koji u pravilu ništa ne valjaju? eizo standardno najbolje kalibrirani? http://www.prad.de/en/monitore/revie...t8.html#deltaE http://www.prad.de/en/monitore/revie...31w-part8.html http://www.prad.de/en/monitore/revie...1w-part11.html http://www.prad.de/en/monitore/revie...1w-part11.html a gle sad ovog malog TN-a: http://www.prad.de/en/monitore/revie...10.html#deltaE |
#92 |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,162
Htio sam reci da postojanje istih preseta, obicno govori da je posao bolje napravljen kao cjelina. Dal ce nekome boja biti nakon toga pre topla ili biti smatrana devijacijom od njegovih potreba... to se barem more podesiti ionako uobicajenim postupcima. |
#95 |
Postovi: 478
dobro, bitno je da tebi znači, iako u praksi - potvrđeno testovima i mjerenjima - uglavnom sliku pomakne još dalje od toga da ju se može nazvati dobrim. ako te veseli da ti u izborniku piše "sRGB", bez obzira na to kako uništilo sliku, široko ti polje. |
#96 | |
8-bit Gen.
Postovi: 3,162
#97 | |
Postovi: 602
Znači svi noviji ne-TN monitori će biti wide gamut? Kako se "problem" manifestira kod CRT-a? (još uvijek gledam u jedan 17" Trinitron) |
#98 | |
Postovi: 478
gle: http://www.tftcentral.co.uk/reviews/hp_lp2475w.htm The LP2475W offers a supposed sRGB simulation mode via the OSD menu as well, so we wanted to test how this performed, again with everything else left at default. The screen immediately looked darker and slightly more 'murky' to the eye, and the colorimeter revealed luminance was reduced down to 232 cd/m2 now. Colour temperarture moved further away from the desired 6500k (being 16% out now) and colour accuracy didn't really change. The main thing this mode is supposed to do is simulate the sRGB colour space, which is important for those not wanting to work with extended colour spaces. Strangely, this mode did nothing for the screens gamut, and the CIE diagram on the left shows the colour space remains considerably larger than the sRGB reference triangle! I am left to assume that all this mode really does is darken the image! Very odd... terminator02: nema ništa kvalitetnije u tim lampama i u wide gamutu, to je pošast koja u najboljem slučaju može aproksimirati standardan gamut (ali uz gubitak diskretnih razina boja). bit će bolje jednom kada sve vezano uz grafiku pređe 8 bitova po kanalu. |
#99 |
Lokacija: stan
Postovi: 97
Pradov review dotičnog HP2475w: http://www.prad.de/new/monitore/test...p-lp2475w.html Pokupio odlicne ocijene!
Kaaaaaaaj si! |
#100 |
Postovi: 478
na hardforumu je sve puno ljudi koji imaju ogromne probleme s monitorom - zeleno i rozo na rubovima ekrana, čudan izgled teksta (crveni rubovi, stepeničaste linije), "white glow"... nešto tu nije u redu. |
#101 |
Lokacija: cro
Postovi: 42
na hardforumu većina ljudi je zadovoljna s monitorom te ga ( istina neki od njih ) proglašavaju best buy (24''),normalno za prvo izdanje da ima i problema ( kao i za veliku većinu drugih proizvođača - samo se sjeti koliko revizija ima npr Dell s svojim modelima ), btw "white glow" postoji na svim H-IPS modelima kad se gleda sa strane ( osim kod Neca 2x90 serije koji to masno naplacuje jer ugrađuje A-TW polarizator ),ja kod sebe ( Dell 2007WFP S-IPS ) imam ljubičasti ![]() |
#102 |
Datum registracije: Feb 2003
Postovi: 1,556
#104 |
Postovi: 142
Ja se nisam htio kockat sa 5000kn, radije sam dodo još 1500 i kupio Eizo, i prezadovoljan. Oći ne žuljaju, glava ne boli, osvjetljenje uvijek na optimalnoj razini jer ima senzor koji javlja upravljačkoj elektronici koja automatski pojačava i smanjuje svjetlinu u ovisnosti o svjetlu u prostoriji, pa imaš dojam ko da je slika uvijek ista, tj optimalna. Nikad prije ni na jednom monitoru nisam vidio tako korisnu funkciju. Ma neznam zašto ovo pišem kad je dovoljna samo jedna riječ: EIZO |
#108 |
Lokacija: Vz - Zg
Postovi: 2,930
cekaj, stize philips s istom matricom, vrlo vjerojatno istom ili nizom cijenom i lako moguce boljim srgb modom rada, hehe kak je krenulo 24" postaje mainstream kroz kakvih godinu dana, fora.
#109 |
8-bit Gen.
Postovi: 3,162
I dalje mislim da je odlican (za novce) monitor, ali treba mu dati jos vremena da se sredi sa nekom prvom revizijom. No nesto me drugo bode u oci. LED 24" nadolazeci modeli imaju jako cudno deklariranje zivotnog trajanja lamperije. Jedan od najvecih problema sa LED-om je bila nemogucnost da ga svedu na upotrebljivu razinu upravo vremena trajanja. Sa time su imali velikih problema i to je puno puta bilo spomenuto kao veliki problem. Sjecam se da im je u pocetku jako brzo zivotni vijek padao na 50% od novog. To im je zadavalo puno problema. Slika neupitna, prednosti jos vise. Ali od pocetka je zivotni vijek bio veliki problem. U zadnjih pola godine fanfare sviraju kako ce zivotni vijek biti puno veci od LCD-a. Kojem god LED monitoru da iscitam specifikacije... gotovo identicno je iskazivanje srednje zivucem CCFL-u. Ovo je istom ispod cekicha izasao novi ECO Eizo LED 24" monitor. Specifikacije opet daju identicno trajanje koje imaju (srednje) zivuci CCFL-i. Nije 30k neki veliki problem. Ali nikako ne ulazi u sliku LED obecanja koji je trebao biti skoro 2x veci od CCFL-a! Sony kaze minimalno 60.000 chuki. Mali 2" OLED ekrani imaju deklarirano i preko 100.000 chuki (Panasonic), no cini se da se mnogi upravo sa malim hvališu i transponiraju kao pravilo za ostale gabaritne modele. OSRAM kaze da moze napumpati i preko 150.000 sati. Samo ja ne vidim trenutno ni jedan LED monitor u prodaji ili najavi koji prelazi CCFL specifikacije! Hoce li ovo biti jos jedna tehnologija koje ce se sredjivati dok je vec posijana po policama i domovima korisnika? Jesi li oni zbilja sredili te prvobitne mane LED-a, ako satnica ipak nije na visini predocenih obecanja? Hm ![]() |
#110 | |
Ali sto se tice deklariranog vremena. Ma da je i isto kao i CCFL, pogledaj sto se dogadja sa CCFL kako vrijeme prolazi. LED nema tih problema (fading). |
#111 | ||
8-bit Gen.
Postovi: 3,162
Ova satnica nije ravna onome sto su zacrtali.Citiraj:
Pravo lice ekspolatacije tog ekrana mozemo znati tek nakon koju godinu. Nadajmo se da je tako. Inace, samom LEDu se prilicno veselim. |
#113 | |
Postovi: 602
Bojim se da će ga u Filipsu nakrcati zvučnicima, web kamerama, mikrofonima, a što bi moglo biti najgore: piano sjajnim finišom plastike ![]() I ja to pomalo uviđam. Vjerovatno bi bilo bolje odmah "preskočit" 22" ne-TN monitore( lp2275w) i odmah izabrati optimalno rješenje a to je 24" i 1920x1200. Monitor se ne kupuje svake dvi godine (ja ne kupujem ni cipele svake dvi godine ) pa valjda neće propast svit za 1000,1500 kuna više u odnosu na 22" ne-TN.![]() Treba pričekati da na tržište dođe i novi Lenovo L2440x (LED) koji bi trebao prilikom predstavljana koštati početnih(sa tendencijom pada cijene) 4600 kuna. Treba pričekati i tog 24" S-IPS Filipsa, a i kako je Visaqe rekao koju reviziju LP2475w. Svaka čast 19 i 20" kvalitetnim Trinitron CRT-ovima, ali kako dobit 24" ili čak 30" CRT ?? |
#114 |
Postovi: 478
philips: http://www.tftcentral.co.uk/news_arc...ilips_240pw9eb 24" CRT: http://www.amazon.com/Sony-GDM-FW900.../dp/B00004YNSR (a na televizore si zaboravio? ![]() |
#115 |
#116 | |
8-bit Gen.
Postovi: 3,162
Postoji i jos tuniranija verzija GDM-FW9011 Pa i nije. U slucaju ukrocivanja tehnologije i onoga sto je zacrtao i obecao. Ali u slucaju iskazivanja prave dugotrajnosti, izvan sterilnih deklarativnih navoda samog proizvodjaca... nema bolje potvrde od buducih vlasnika koji ce svjedociti kako doista "stare" ti monitori. 8 |
#117 | ||
Postovi: 602
(ne sitin se povremeno svratit na tftcentral.. ![]() Smeta mi što ovaj LCD ima VGA ulaz , ne mogu vidit dobro sa ove slike, ali nadam se da neće biti sjajno crni.Citiraj:
![]() Bez obzira na 32" i čak 36" CRT televizore 32" monitori za računala ne postoje! Međutim, kad ljudi toliko plaču za izumrlim CRT-ovima, nikako mi nije jasno kako se proizvođači LCD monitora nisu dosjetili u računalne monitore ugrađivati zaslone bazirane na PLASMA tehnologiji, pošto plasma tehnologija ne koristi pozadinsko osvjetljenje, a sam način prikaza slike je vrlo sličan CRT tehnologiji?? ![]() Za razliku od CRT-ova plasma monitor nebi imao problema sa geometrijom na rubovima zaslona, a mogao bi se razviti u u većim dijagonalama od CRT-a. U usporedbi sa LCD zaslonom plasma nebi patila od ghostinga, input laga, problema vjernosti boja.. |
#118 | |
Postovi: 166
Plazma pati od burn - ina pa me bas zanima kako ce ovaj monitor funkcionirati s staticnom slikom koja je vecinom vremena na PC zaslonu. |
#119 | ||
8-bit Gen.
Postovi: 3,162
![]() 1) , 2) Ja sam jednog vec narucio. Gnomisa se pravi sramezljiv ali vec je lupio narudjbu sigurno. Citiraj:
Prouci malo kako je uopce dosla u konzumentske vode. |
#120 | |
Postovi: 602
Mislia sam na 24" ekrane rezolucije 1920x1200 sa plasma matricom ![]() Grozan mi je taj HDFury (to pretvarati HDMI signal u analogni..) ![]() Meni smeta samo postojanje analognog VGA ulaza na 24" LCD monitoru. Trebali su staviti samo naponski ulaz i mini display port! ![]() Što se tice plazme: Nisam od tebe očekivao da ti se ne sviđa plazma u nedostatku proizvodnje boljih CRT-ova? ![]() |
