Staro 17.09.2008., 11:55   #1
baky707
Lokacija: Koprivnica
Postovi: 8
USB Gamepad problem
Kupio novi Gamepad Smartbox i kod cure i frenda radi bez ikakveh drivera, a kod mene nece USB da ga prepozna i u Device Manageru ga ocita kao Unknown Device te ga u Game Controllers ne ocitava!
Dal moze netko pomoci bio bih vrlo zahvalan jer mene je vec izludjelo?!
baky707 je offline   Reply With Quote
Staro 17.09.2008., 12:12   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Pa, sa njim dobiješ onaj minijaturni CD sa driverima-instaliraj ih
Staro 17.09.2008., 13:40   #3
baky707
Postovi: 8
Jesam, al ne reagira
Staro 17.09.2008., 14:00   #4
thopok
Lokacija: Splity
Postovi: 3,003
Try plugging the device into a different port.
1. Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.* If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2. Double-click the appropriate device category, and then look for an entry for the device you are having a problem with.
3. Right-click the entry for your USB device, and then click Properties.
4. Click the General tab, and then look in the Device status box to see if it mentions any problems with the device—specifically, a problem with the driver.
My USB device is not working.
Staro 17.09.2008., 14:17   #5
Jelc
Super Moderators
Postovi: 17,485
Autor baky707 Pregled postova
Koliko se ja sjećam prvo se instaliraju driveri, restarta pa tek onda ubode gamepad...
Staro 17.09.2008., 14:51   #6
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Koje windowse imaš, di si ga uštekal, napred na one usb-e na kučištu ili odostraga kak treba biti?
danc00 je offline   Reply With Quote
Staro 17.09.2008., 17:33   #7
baky707
Postovi: 8
XP sp2 imam samo iza
U Device statusu mi pise da nemam instalirani driver a kad ga instaliram s mini cd kojeg sam dobil s njim napravi mi PM25B1 file u Program files sa VL813.inf fileom te dok ga pokusam instalirati sa Update driver ispise poruku da spoecificiranalokacija ne sadrzi informaciju o mom uredaju
Staro 18.09.2008., 10:44   #8
domy_os
domy_os's Avatar
Postovi: 18,836
Ovo instaliraj...
http://rapidshare.com/files/67065446/smartbox_setup.rar
...pa onda nakon toga ubodi gamepad.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 18.09.2008., 16:30   #9
baky707
Postovi: 8
Jesam ,al nista sve je isto! Kad instaliram http://rapidshare.com/files/67065446/smartbox_setup.rar on cak u sebi nema ni *.inf file
Staro 18.09.2008., 17:12   #10
domy_os
domy_os's Avatar
Postovi: 18,836
Ni ne treba ti kad je to exe instalacija...
Staro 19.09.2008., 10:30   #11
baky707
Postovi: 8
jos uvjek ga ne prepoznaje, mozda neki drugi driver?
Staro 22.09.2008., 11:53   #12
baky707
Postovi: 8
El moguce da mi maticna ne podrzava taj gamepod jer koj god driver nasnimim ne prepoznaje ga!?
Staro 22.09.2008., 12:12   #13
Jelc
Super Moderators
Postovi: 17,485
Da si ispunio moj komp opciju znali bismo i koja matična...
Staro 22.09.2008., 20:03   #14
baky707
Postovi: 8
Dodano u Moj komp.
Sorry nisam znao
