Lokacija: Bella Fiume
Postovi: 75
konfa do 9000 kn
Kompjuter je za frendicu, prema tome ništa od overclockinga i ekstremnog gaminga i slično...svejedno mora biti oko 9000 kuna, evo šta sam ja smislio,u konfi fali printer....pa molim savjete i komentare. MBO EPOX 8RDA3+, nForce2 400 SPP+MCP, DDR, zvuk, 2x LAN, FW, S-ATA, socket A 746.36 cpu amd athlon xp-barton 2800+ box (2083 mhz), 512kb c., fsb 333mhz, socket a 1080.68 RAM PC-3500, 256MB, KINGMAX, DDR 433 MHz 457.73 RAM PC-3500, 256MB, KINGMAX, DDR 433 MHz 457.73 hdd 120.0 gb seagate, 8mb cache, 7200.7 plus 786.67 VGA SAPPHIRE ATI RADEON 9600 XT, 128MB DDR, DVI, TV 1280.75 DVD+RW/-RW TEAC DV-W58G-095 829.69 Floppy drive 3.5'', 1,44MB 56 Kuciste Chenbro, Gaming Bomb, silver, w/o PS 299 apajanje ChiefTec Enhance ATX-1136H, 360W, dual fan 292.31 Modem Conexant 56k, interni, softverski 74.33 Monitor 17" Samsung SM757DFX, 96 kHz, 0.20mm, DynaFlat 1433.6 zvučnici genius sp-k16 2*8 w, 3d, silver 115.24 Tipkovnica Genius KB-29e, multimedia, calculator, plava, PS/2, HR 107.45 Mis 4D Optical Browser Mouse, PS/2 i USB 74.62 ventilator papst 80mm, 19db, n/2gmle 100.32 UKUPNO 8192.48 |
Datum registracije: Jul 2003
Postovi: 800
Monitor 17" Samsung SM765MB, 85 kHz, 0.20mm, DynaFlatX Tipkovnica + miš Logitech Desktop Premium Zvučnici Genius SP-K16 2*8 W, 3D, silver Kućište Chenbro, Gaming Bomb, silver, w/o PS Modem Conexant 56k, interni, softverski Napajanje AOpen 350W, single fan, 12cm Floppy drive 3.5'', 1,44MB DVD±RW PIONEER DVR-107, bulk Cooler ZALMAN CNPS7000A-Cu, socket A/370/478/754 CPU AMD Athlon XP-Barton 2500+ (1833 MHz), 512kb c., FSB 333MHz, socket A 2*RAM PC-3500, 256MB, KINGMAX, DDR 433 MHz HDD 120.0 GB SEAGATE, Serial ATA Plus, 8MB cache, 7200 VGA SAPPHIRE ATI RADEON 9800 Pro, 128MB DDR, DVI, TV MBO ABIT AN7, nForce2 400 Ultra, DDR, zvuk, S-ATA, FW, socket A 8.948.25KN ![]() ![]()
#3 | |
pUtNiK
Datum registracije: Feb 2004
Lokacija: na forumu
Postovi: 342
Lokacija: Zagreb, Trešnjevka
Postovi: 5,770
Matična-Abit NF7-S da nebi frendici Guru radio probleme. |
#5 | |
pUtNiK
Lokacija: na forumu
Postovi: 342
Re: konfa do 9000 kn
#6 | |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,025
pUtNiK
Lokacija: na forumu
Postovi: 342
isprika,govorim napamet tj.nisam čito thread o piljenju ![]() |
Datum registracije: Dec 2003
Lokacija: Okolica Čakovca, točnije Pretetinec
Postovi: 313
Mislim da nema potrebe uzimat kingmaxa 433...kad ne bu klokanja...neka Samsungova memorija na 333mhz...bu cist dosta...ili na 400...pa uz malo agresivnije latencije... ![]() |
Postovi: 5,770
Ak uzimaš kingmaxau nitelu je mislim najjeftiniji. @Chozen super avatar ![]() |
Postovi: 75
cijene memorija su tu negdje, pa onda mislim da je bolje uzeti kingmax...a možda jedan dan se odluči overclockat pa za svaki slučaj.... ![]() evo malo promijenjena konfa...mislim da je sasvim solidno...iako za njene potrebe je i previše ali očito se ima love... Monitor 19" Samsung SM957MB, 96 kHz, 0.20mm. DynaFlatX 2015 Tipkovnica + miš Logitech Desktop Premium 281.71 Printer HP DeskJet 3650, Ink-Jet, 1200 dpi, 364kb, USB 659.55 Zvučnici Genius SP-K16 2*8 W, 3D, silver 115.24 Napajanje ChiefTec Enhance ATX-1136H, 360W, dual fan 292.31 Modem Conexant 56k, interni, softverski 74.33 Kućište Chenbro, Gaming Bomb, silver, w/o PS 299 Floppy drive 3.5'', 1,44MB 56 2 x RAM PC-3500, 256MB, KINGMAX, DDR 433 MHz 915.46 cpu amd athlon xp-barton 2500+ box (1833 mhz), 512kb c., fsb 333mhz, socket a 699.27 HDD 120.0 GB SEAGATE, 8MB cache, 7200.7 Plus 786.67 VGA SAPPHIRE ATI RADEON 9600 XT, 128MB DDR, DVI, TV 1280.75 DVD±RW PIONEER DVR-107, bulk 836.99 mbo epox 8rda3+, nforce2 400 spp+mcp, ddr, zvuk, 2x lan, fw, s-ata, socket a 746.36 ventilator papst 80mm, 19db, n/2gmle 100.32 Ukupno 9158.96 |
#11 | |
Postovi: 313
![]() ![]() @renzo: pa kaj će joj 19' monitor...mislim da je 17' dosta...bar je meni dosta... ![]() |
Postovi: 75
@chozen: od viška ne boli glava ![]() |
#13 | |
Postovi: 313
![]() ![]() EDIT: Možda bi bilo bolje da uzme 17' monitor i Radeonku 9800Pro... ![]() |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,025
Il nek uzme 955, onda bi stala možda i 5900XT GS od Gainwarda. Ovo bi bilabolja solucija. |
no fear
Lokacija: ZAGREB
Postovi: 894
Ja sam uvijek za veći monitor!!! Možda prije 3-4 mj. curi sam slago neku konfiguraciju i uzeo sam 19" Samsung SM957MB Kod tog monitora na rubovima ekrana kao da je slika mutnija i nikako je nisam mogao namjestiti. Čitao sam na nekoj stranici test monitora i javio se isti problem samo nisu bili sigurni dal' je to samo na tom primjerku. Inace ja imam 957DF i sve OK vec 2,5 g. |
#16 |
Night shift
Datum registracije: Jul 2002
Postovi: 884
Samsung SM957MB i nije baš nešto. Otprilike kvaliteta solidnog 17" samo s većom dijagonalom. Za 200-300kn više može se dobiti jako dobar Samsung 959NF ili LG F900P. Realno ne znam što će joj to osim ako se ne bavi CAD/CAM i sl. ili ima manji TV pa želi gledat filmove na monitoru.
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again." --uoɥʇʎd ʎʇuoɯ-- |
#17 | |
Datum registracije: Jan 2002
Lokacija: ?
Postovi: 2,274
Imam ja 957MB-a i nemam nikakvih problema već jedno 2,5 mjeseca. Stvar je od primjerka do primjerka. |
#18 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,025
Ja sam s 959NF super zadovoljan i ne bi ga mijenjao ni za što. Kakav LCD kad imaš mrcinu od CRT-a. Osim kad ideš na LAN-party. ![]() |
#19 | |
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
A Chenbro + ChiefTec uzmi modded / bundle, jer te ispadne jeftinije. ![]() |
#20 |
no fear
Lokacija: ZAGREB
Postovi: 894
Kad kupuješ comp. za ženske najvežnije ti je da kupiš lijepu tipkovnicu, miš, zvučnike i monitor (da to sve dobro izgleda, da iskombiniraš boje). I frendica bu super zadovoljna! To ti je kao kod automobila; ženama je važno da li u autu ima ogledalce za šminkanje, a kolko je KS ispod haube to tak nije važno. Zato pazi na boje ![]() |
