Lokacija: Zabok/ZG
Postovi: 899
Microsoftov novi miš
Microsoft Releases new Mouse using a BlueTrack Sensor The Microsoft Explorer Mouse and Explorer Mini Mouse were announced today and feature a unique technology that is making its debut in these devices. It’s called BlueTrack, and this new sensor can work on just about any surface. In fact, BlueTrack is much more accurate on shiny surfaces than any other tech out there right now. If you don’t like using a mouse pad and find your desk has too much of a sheen for your mouse to accurately register, this technology should help you tremendously. Microsoft developed this new tech, which sets it apart from the standard Agilent Technologies licensed laser sensors that fit in most other computer mice. This one might stick with Microsoft, and if they decide to license it, well, that would make them a bundle, especially if these two launches work out well. The Explorer Mouse will sell for $99.99 and the Explorer Mini Mouse will sell for $79.99 once they are released this November. http://www.slashgear.com/wp-content/...01-480x355.jpg http://www.microsoft.com/presspass/p...ueTrackPR.mspx Code:
Kopirano sa www.neowin.net |
Rambus 3xtr1m
Postovi: 2,694
Koristim isključivo micorosft periferiju i ovaj miš izgleda odlično. Nije gejmerski kao moj sidewinder ali je šmenci ![]() |
Lokacija: Livingrad
Postovi: 539
jos jedan lijepi mishek za DESNJAKE!!! mozda nekad pocnu razmisljati da ljevaka ima vise nego kaj si oni misle!!! hebote, nema ni jednog misha razvijenog za ljevake. eventualno ovi univerzalni, no kod njih ionak nemozes jednu stranu koristiti pa kao i da nije upotrebljiv kako spada. jadni mi ljevaki... ![]()
#5 | |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,133
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
Postovi: 604
http://www.trustedreviews.com/periph...s-BlueTrack/p1 SIDEWINDER X8 FTW! i ono najbolje; semi wireless opcija, usb kabel može se uključiti i isključiti po potrebi ZOMG kupujem, riješavam se Death Addera \0/ http://gizmodo.com/5047897/sidewinde...-by-darth-nerd btw sere mi se od ovog Gizmodo-a, kao da za njega pišu prištavi nedojebani FERovci koji povremeno trabunjaju u člancima 'AS IF' naravi i za KLiK ili FHM |
#8 | |||
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
a ne full usb konekcija za smanjivanje wireless lag-a kada zatreba pri igranju? Citiraj:
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() |
Postovi: 604
hm meni se to nekako podrazumijeva, kabel osigurava konstantnu recepciju signala, bez interupcija. zar ne? |
#10 | |
Postovi: 2,073
miš je iako spojen na kabel za punjenje i dalje wireless, dakle ima lag (pretvaranje signala senzora pokreta u wireless i dekodiranje opet nazad nikada neće biti brže od čistog prijenosa žicom od mjesta A do mjesta B...). (btw neki trust miševi imaju tako rješeno punjenje već godinama(vjerujem i ostali), ništa novoga dakle)
Postovi: 604
hm većina miševa koji su bežični imaju bluetooth ili IRDA receiver upakiran u USB stick, ali ako ovdje nema fizičkog prekida veze između miša i usb slota na matičnoj putem kabela ne razumijem gdje je tu lag? ili misliš da će se prilikom punjenja usb kabel ponašati isključivo kao vodič struje a ne i signala? to mi nema smisla, jer svi usb miševi koji dakle nisu wireless i nemaju bateriju primaju i struju za rad i odašilju signal putem jednog kabela, ne vidim zašto to ne bi bio slučaj i sa ovim mišem. istini za volju sada sam malo razmislio i vidio da stvarno nigdje ne spominju opciju igranja sa žicom. već samo punjenja miša istom. a da sam išao na FER kada je trebalo možda bih i znao nešto više o tome ![]() ah treba dočekati Veljaču i već će se pokazati, btw ja si sigurno kupujem jednoga, osim ako Logitech ili nedaobogzla Razer već do onda ne smisle još bolje i praktičnije rješenje. u što sumnjam. |
#12 | |
Postovi: 2,073
gle, usb kabel ima + 5V, 0V, shield, data+, data-. dakle 4 žice, i shield, pa izolacija. http://www.imagesforme.com/show.php/...ablewiring.jpg a ovaj očito od baze do miša ima samo + i -. nisu nigdje naveli da postaje 'wired' već samo da se puni preko njega. normalno da od njegove baze do pc-a ide običan punokrvni usb kabel. kako bi radio inače? a lag se događa u konverziji signala između miša i baze, a ne između baze i pc-a
Postovi: 604
dovraga, znao sam da je predobro da bi bilo istinito ![]() možda jednom shvate i naprave wireless gaming miš kako spada, sa žicom ![]() ![]() |
#14 | |
Avocado
Postovi: 7,851
Prvo pljujes sve ljude koji pohadaju doticni faks, pa onda govoris da ti je zao sto nisi jedan od njih... Zanimljivo... Najgore je kad zalis za necim sto nisi napravio. Al tak je to u zivotu.
Spoiler alert! |
#15 | |
Postovi: 2,073
samo se nemoj zaletiti kao sa freezerom: http://forum.pcekspert.com/showthread.php?p=1115573 malo kasnije... Citiraj:
http://forum.pcekspert.com/showthread.php?t=118632
#16 | |
Postovi: 604
nisam ti jasan? razmisli još jednom da li je bilo namjerno. i ... buy a sense of humor? ![]() i ponoviti ču još jednom što sam rekao pri zadnjem strijeljanju diztrojeru: 'NE ŽALIM ZA NIČIME!' Citiraj:
#17 |
..dno
Lokacija: Crikvenica
Postovi: 1,972
Još jedna stvar koju treba obljepiti izolirom da ne smeta navečer svojom nježnom plavom diodom. pft.
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.” |
#18 |
Avocado
Postovi: 7,851
mda. Napises satro zajebanciju sa uvredama, i naravno nikakve indikacije da to i jest zajebancija... Namjerno je bilo sigurno. A sad dal je sala ili ne... Dapace, mislim da to i ostali koji su procitali tvoj post mogu potvrditi. RBAY ![]()
Spoiler alert! |
#19 |
Postovi: 604
samo n00b brucos bi zauzeo takav naivno-defenzivan stav prema svojoj akademskoj ustanovi to sto razumijes samo binarne, analogne i digitalne pojmove vjerovatno koci tvom pojmu humora da evoluira iznad slapstick komedija, preporucam citanje malo filozofije, pocni sa Platonom, a kada dodjes do Spinoze slijedi ispit! kthxbye & nhf ps e da http://www.youtube.com/watch?v=juyrt...eature=related Zadnje izmijenjeno od: Skorn. 14.09.2008. u 20:28. |
#21 |
Lokacija: Livingrad
Postovi: 539
pa sve vam lijepo pise: The SideWinder X8 Mouse is a top-performing wireless gaming mouse, with a combination of BlueTrack Technology tracking that provides the best speeds and feeds available, 2.4GHz wireless technology built for lag-free play, and an easy recharging system that keeps gamers in action. • 2.4GHz wireless. The device is built for lag-free play with virtually no latency. jos neke nejasnoche? ![]()
#22 |
Lokacija: Zgb
Postovi: 31
ukratko... još jedan Mircosoftov skupi miš koji će željet većina a imat samo šminkeri koji pale komp samo da bi pogledali kaj ima na "fejsbuku"... makes me sick...
Besplatne flash igrice |
#23 |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,767
#24 |
A mighty pirate!
Postovi: 429
Mah,koliko miš jest dobar,Microsoft svejedno ne volim i nastojim mu dati što manje para moguće. U mojim očima,postoji samo jedna tvrtka koja proizvodi kvalitetnu,dobru i pristupačnu periferiju,a to je Logi! A da ne govorimo o njihovom odnosu sa kupcima koji je genijalan!Sjetite se samo koliko su G15 tipkala zamjenili maltene na "lijepe oči". Rijetko tko u mojim očima blista tako,zasad jedino Logitech i Sapphire! |
#25 |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
cek firma ti blista u ocima zato sto im je krepala gomila skupih tipkala i onda su ih zamjenili dok su jos bili pod garancijom? sta onda mora neka firma napraviti da bi ti se zgadila? ![]() logi je ok ali kvaliteta izrade nekih proizvoda im bas i nije na razini, posebno imam primjedbi na kvalitetu plastike manjih dijelova, kucista uredjaja su, bez obzirao o cem se radilo, obicno ok ali ako je na njima neka pizdarija to obavezno naprave od neke krte plastike koja samo ceka da pukne. I misevi se vole izlizati nabrzinu...nema mi nista gore ![]() |
#26 |
herr Flick
Postovi: 2,085
MX1000 kao top mish kad se pojavio kao primjer Logi znak se vise ne vidi a i baterija im nije bash neka. Nabavljati novu je skoro pa ista stvar kao i kupiti novog misha Ovaj Microsoftov ce biti sigurno dobar ali cijena kod nas ? Ispod 700 ne vjerujem, mozda njegova pojava potakne da cijene konkurencije padne. Mozda ...
.:S:T:A:L:K:E:R:. ![]() ![]() nema vise zippacha ![]() |
#27 |
Postovi: 8,192
problem sa logijem je taj što su u zadnje vrijeme uz haj end periferiju počeli proizvoditi i smeće. @Gradjanin Samo 9% ljevaka, znači mali broj korisnika, znači slaba isplativost.
Sent from AS/400. |
#28 |
Lokacija: kod Klc
Postovi: 29
jako lijep miš |
#29 | |
Avocado
Postovi: 7,851
Nadam se samo da je tvoje nabrajanje čitava dva (brojem: 2) filozofa u kontekstu humora samo još jedan od dokaza tvojeg smisla za humor... I da sam brucoš, što nisam, svejedno mi nije jasno čemu vrijeđanje dotičnih "n00bova" sa evaluativno najboljim faksom u rvackoj danas? Ja ću shvatiti ovo zadnje pitanje retoričkim, ti kako želiš. Odgovor je jasan, i sadržan u pravilima ovog foruma. Moja isprika ide modovima i adminima što sam oftopičario.
Spoiler alert! |
#30 |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Meni je miš oduran. ![]() |
