Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 11.09.2008., 11:09   #1
Flikoman
Lokacija: Zabok/ZG
Postovi: 899
Microsoftov novi miš
Microsoft Releases new Mouse using a BlueTrack Sensor
The Microsoft Explorer Mouse and Explorer Mini Mouse were announced today and feature a unique technology that is making its debut in these devices. It’s called BlueTrack, and this new sensor can work on just about any surface.
In fact, BlueTrack is much more accurate on shiny surfaces than any other tech out there right now. If you don’t like using a mouse pad and find your desk has too much of a sheen for your mouse to accurately register, this technology should help you tremendously.
Microsoft developed this new tech, which sets it apart from the standard Agilent Technologies licensed laser sensors that fit in most other computer mice. This one might stick with Microsoft, and if they decide to license it, well, that would make them a bundle, especially if these two launches work out well. The Explorer Mouse will sell for $99.99 and the Explorer Mini Mouse will sell for $79.99 once they are released this November.
http://www.slashgear.com/wp-content/...01-480x355.jpg
http://www.microsoft.com/presspass/p...ueTrackPR.mspx
Code:
Kopirano sa www.neowin.net
Flikoman je offline   Reply With Quote
Staro 11.09.2008., 12:27   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Koristim isključivo micorosft periferiju i ovaj miš izgleda odlično. Nije gejmerski kao moj sidewinder ali je šmenci
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 12.09.2008., 10:12   #3
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
jos jedan lijepi mishek za DESNJAKE!!!
mozda nekad pocnu razmisljati da ljevaka ima vise nego kaj si oni misle!!! hebote, nema ni jednog misha razvijenog za ljevake. eventualno ovi univerzalni, no kod njih ionak nemozes jednu stranu koristiti pa kao i da nije upotrebljiv kako spada.
jadni mi ljevaki...
°Citius Altius Fortius°
Gradjanin je offline   Reply With Quote
Staro 12.09.2008., 10:43   #4
Sadgasm
Postovi: 177
hm,pa nije li bar micanje predmeta i klikanje lako s bilo kojom rukom ? Nije to pisanje slova .Inace sam i ja ljevak ,al koristim mis s desnom.
Sadgasm je offline   Reply With Quote
Staro 12.09.2008., 14:01   #5
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,164
Autor Sadgasm Pregled postova
Slazem se, ista stvar kod mene. MS-u nikako ne mogu oprostiti da je svoj najbolji Microsoft Trackball optical, bez ikakvog objasnjenja maknuo sa trzista
Staro 12.09.2008., 14:26   #6
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
U cemu je problem? I ja pisem lijevom rukom, ali mis nikako ne mogu zamisliti u lijevoj ruci. Stalno ga gonim desnom.
Staro 12.09.2008., 23:56   #7
Skorn
Skorn's Avatar
Postovi: 604
http://www.trustedreviews.com/periph...s-BlueTrack/p1
SIDEWINDER X8 FTW!
i ono najbolje; semi wireless opcija, usb kabel može se uključiti i isključiti po potrebi
ZOMG kupujem, riješavam se Death Addera \0/
http://gizmodo.com/5047897/sidewinde...-by-darth-nerd
btw sere mi se od ovog Gizmodo-a, kao da za njega pišu prištavi nedojebani FERovci koji povremeno trabunjaju u člancima 'AS IF' naravi i za KLiK ili FHM
~ Reductio ad Absurdum ~
igre za PS ONE / PS2 koje me zanimaju
Skorn je offline   Reply With Quote
Staro 13.09.2008., 00:05   #8
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
i ono najbolje; semi wireless opcija, usb može se uključiti i iskljčiti po potrebi
nije li taj kabel samo +/- napon iz USB-a koji ide od baze pa do miša, za punjenje 'u hodu' dok radiš,
a ne full usb konekcija za smanjivanje wireless lag-a kada zatreba pri igranju?
While the G7 gives you two hot-swap batteries in case you run out mid-genocide,
the X8 has a play-and-charge cable that you unwrap from the small hockey puck.
The winding cord management system offers easy charging — simply unwrap the cord
from around the storage box and snap it onto the underside of the mouse.
brzo sam preletio text ali nigdje ne vidim da spominju to da može postati 'žični miš bez lag-a'
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 13.09.2008., 00:09   #9
Skorn
Skorn's Avatar
Postovi: 604
hm meni se to nekako podrazumijeva, kabel osigurava konstantnu recepciju signala, bez interupcija. zar ne?
Staro 13.09.2008., 00:21   #10
TomRi
TomRi's Avatar
Postovi: 2,073
nije stvar u prijemu signala, on je u 99.99% vremena izvrstan, već je stvar u lag-u,
miš je iako spojen na kabel za punjenje i dalje wireless, dakle ima lag
(pretvaranje signala senzora pokreta u wireless i dekodiranje opet nazad nikada neće biti brže od čistog prijenosa žicom od mjesta A do mjesta B...).
(btw neki trust miševi imaju tako rješeno punjenje već godinama(vjerujem i ostali), ništa novoga dakle)
Water cooled PC
Moj najveci MOD
Staro 13.09.2008., 00:29   #11
Skorn
Skorn's Avatar
Postovi: 604
hm većina miševa koji su bežični imaju bluetooth ili IRDA receiver upakiran u USB stick, ali ako ovdje nema fizičkog prekida veze između miša i usb slota na matičnoj putem kabela ne razumijem gdje je tu lag? ili misliš da će se prilikom punjenja usb kabel ponašati isključivo kao vodič struje a ne i signala? to mi nema smisla, jer svi usb miševi koji dakle nisu wireless i nemaju bateriju primaju i struju za rad i odašilju signal putem jednog kabela, ne vidim zašto to ne bi bio slučaj i sa ovim mišem. istini za volju sada sam malo razmislio i vidio da stvarno nigdje ne spominju opciju igranja sa žicom. već samo punjenja miša istom. a da sam išao na FER kada je trebalo možda bih i znao nešto više o tome
ah treba dočekati Veljaču i već će se pokazati, btw ja si sigurno kupujem jednoga, osim ako Logitech ili nedaobogzla Razer već do onda ne smisle još bolje i praktičnije rješenje. u što sumnjam.
Staro 13.09.2008., 00:35   #12
TomRi
TomRi's Avatar
Postovi: 2,073
Autor Skorn Pregled postova
gle, usb kabel ima + 5V, 0V, shield, data+, data-.
dakle 4 žice, i shield, pa izolacija.
http://www.imagesforme.com/show.php/...ablewiring.jpg
a ovaj očito od baze do miša ima samo + i -.
nisu nigdje naveli da postaje 'wired' već samo da se puni preko njega.
normalno da od njegove baze do pc-a ide običan punokrvni usb kabel. kako bi radio inače?
a lag se događa u konverziji signala između miša i baze, a ne između baze i pc-a
Water cooled PC
Moj najveci MOD
Staro 13.09.2008., 00:37   #13
Skorn
Skorn's Avatar
Postovi: 604
dovraga, znao sam da je predobro da bi bilo istinito
možda jednom shvate i naprave wireless gaming miš kako spada, sa žicom
Staro 13.09.2008., 00:42   #14
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Meni stvarno nisi jasan...
Prvo pljujes sve ljude koji pohadaju doticni faks, pa onda govoris da ti je zao sto nisi jedan od njih... Zanimljivo... Najgore je kad zalis za necim sto nisi napravio. Al tak je to u zivotu.
Spoiler alert!
Staro 13.09.2008., 00:43   #15
TomRi
TomRi's Avatar
Postovi: 2,073
btw ja si sigurno kupujem jednoga.
samo se nemoj zaletiti kao sa freezerom:
http://forum.pcekspert.com/showthread.php?p=1115573
idem u reic...u njemacku sutra ionako pa si kupim jednoga
Autor demetrius Pregled postova
ti kupuješ a nisi testove vidio''??
malo kasnije...
mogu samo reci da me je cooler pomalo iznenadio svojom velicinom, ocekivao sam gromadu a ono manji od TRuE (bez venta)
i evo ga na tržnici
http://forum.pcekspert.com/showthread.php?t=118632
Water cooled PC
Moj najveci MOD
Staro 13.09.2008., 00:51   #16
Skorn
Skorn's Avatar
Postovi: 604
nisam ti jasan?
razmisli još jednom da li je bilo namjerno. i ...
buy a sense of humor?
i ponoviti ču još jednom što sam rekao pri zadnjem strijeljanju diztrojeru:
'NE ŽALIM ZA NIČIME!'
Autor TomRi Pregled postova
ah duga priča, nije hladnjak podbacio, nego moj financijski plan koji nije dozvolio nabavku novog procesora trenutno. a čemu onda takav hladnjak?
Staro 14.09.2008., 00:46   #17
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Još jedna stvar koju treba obljepiti izolirom da ne smeta navečer svojom nježnom plavom diodom. pft.
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 14.09.2008., 18:05   #18
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
nisam ti jasan?
mda. Napises satro zajebanciju sa uvredama, i naravno nikakve indikacije da to i jest zajebancija... Namjerno je bilo sigurno. A sad dal je sala ili ne... Dapace, mislim da to i ostali koji su procitali tvoj post mogu potvrditi.
RBAY
Spoiler alert!
Staro 14.09.2008., 20:28   #19
Skorn
Skorn's Avatar
Postovi: 604
samo n00b brucos bi zauzeo takav naivno-defenzivan stav prema svojoj akademskoj ustanovi
to sto razumijes samo binarne, analogne i digitalne pojmove vjerovatno koci tvom pojmu humora da evoluira iznad slapstick komedija, preporucam citanje malo filozofije, pocni sa Platonom, a kada dodjes do Spinoze slijedi ispit!
kthxbye & nhf
ps
e da
http://www.youtube.com/watch?v=juyrt...eature=related
Zadnje izmijenjeno od: Skorn. 14.09.2008. u 21:28.
Staro 16.09.2008., 20:25   #20
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Mir deco.
Staro 17.09.2008., 13:24   #21
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
pa sve vam lijepo pise:
The SideWinder X8 Mouse is a top-performing wireless gaming mouse, with a combination of BlueTrack Technology tracking that provides the best speeds and feeds available, 2.4GHz wireless technology built for lag-free play, and an easy recharging system that keeps gamers in action.
• 2.4GHz wireless. The device is built for lag-free play with virtually no latency.
jos neke nejasnoche?
Staro 22.11.2008., 11:49   #22
bartolbiz
bartolbiz's Avatar
Lokacija: Zgb
Postovi: 31
ukratko... još jedan Mircosoftov skupi miš koji će željet većina a imat samo šminkeri koji pale komp samo da bi pogledali kaj ima na "fejsbuku"...
makes me sick...
Besplatne flash igrice
bartolbiz je offline   Reply With Quote
Staro 22.11.2008., 12:10   #23
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
Autor bartolbiz Pregled postova
makes me sick...
da, dok chr00 ekipa fura rejzere koji svijetle u mraku...
Staro 06.12.2008., 02:25   #24
Angelus
A mighty pirate!
Angelus's Avatar
Postovi: 429
Mah,koliko miš jest dobar,Microsoft svejedno ne volim i nastojim mu dati što manje para moguće.
U mojim očima,postoji samo jedna tvrtka koja proizvodi kvalitetnu,dobru i pristupačnu periferiju,a to je Logi!
A da ne govorimo o njihovom odnosu sa kupcima koji je genijalan!Sjetite se samo koliko su G15 tipkala zamjenili maltene na "lijepe oči".
Rijetko tko u mojim očima blista tako,zasad jedino Logitech i Sapphire!
Angelus je offline   Reply With Quote
Staro 06.12.2008., 05:16   #25
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
cek firma ti blista u ocima zato sto im je krepala gomila skupih tipkala i onda su ih zamjenili dok su jos bili pod garancijom? sta onda mora neka firma napraviti da bi ti se zgadila?
logi je ok ali kvaliteta izrade nekih proizvoda im bas i nije na razini, posebno imam primjedbi na kvalitetu plastike manjih dijelova, kucista uredjaja su, bez obzirao o cem se radilo, obicno ok ali ako je na njima neka pizdarija to obavezno naprave od neke krte plastike koja samo ceka da pukne. I misevi se vole izlizati nabrzinu...nema mi nista gore
Staro 06.12.2008., 11:22   #26
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Autor greg SE Pregled postova
MX1000 kao top mish kad se pojavio kao primjer
Logi znak se vise ne vidi a i baterija im nije bash neka. Nabavljati novu je skoro pa ista stvar kao i kupiti novog misha
Ovaj Microsoftov ce biti sigurno dobar ali cijena kod nas ? Ispod 700 ne vjerujem, mozda njegova pojava potakne da cijene konkurencije padne. Mozda ...
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 06.12.2008., 22:54   #27
Postovi: 8,236
problem sa logijem je taj što su u zadnje vrijeme uz haj end periferiju počeli proizvoditi i smeće.
@Gradjanin Samo 9% ljevaka, znači mali broj korisnika, znači slaba isplativost.
Staro 26.06.2009., 15:42   #28
nicegirl
Lokacija: kod Klc
Postovi: 29
jako lijep miš
nicegirl je offline   Reply With Quote
Staro 26.06.2009., 16:21   #29
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
kthxbye & nhf
ps
e da
A šta ga kasnim... Ajde, bar je nepotreban post nicegirl pomogao meni ćoravom da vidim dotični quote.
Nadam se samo da je tvoje nabrajanje čitava dva (brojem: 2) filozofa u kontekstu humora samo još jedan od dokaza tvojeg smisla za humor...
I da sam brucoš, što nisam, svejedno mi nije jasno čemu vrijeđanje dotičnih "n00bova" sa evaluativno najboljim faksom u rvackoj danas?
Ja ću shvatiti ovo zadnje pitanje retoričkim, ti kako želiš. Odgovor je jasan, i sadržan u pravilima ovog foruma.
Moja isprika ide modovima i adminima što sam oftopičario.
Spoiler alert!
Staro 26.06.2009., 19:20   #30
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Meni je miš oduran.
