Staro 02.09.2008., 16:10   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
doPDF 6.1.271
Publisher's Description:
doPDF installs itself as a virtual printer driver so after a successful installation will appear in your Printers and Faxes list. To create PDF files, you just have to print your documents to the doPDF pdf converter. Open a document (with Microsoft Word, WordPad, NotePad or any other software), choose Print and select doPDF. It will ask you where to save the PDF file and when finished, the PDF file will be automatically opened in your default PDF viewer.
Latest Changes:
Fix: When using the Browse window to select a folder to save the pdf to, if the file aready existed two consecutive overwrite prompts were shown (one from Windows, other from doPDF) so now only one shows
http://fileforum.betanews.com/detail/doPDF/1171636577/1
Staro 02.09.2008., 16:58   #2
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ja sam od tih free virtualnih printera koristio PrimoPDF i pokazao se kao dobar, nikakvih problema nije bilo
Sličan, ako ne i isti princip kao taj doPDF.
Staro 02.09.2008., 17:26   #3
Jelc
Super Moderators
Postovi: 17,485
Pa, takav soft je dobro imati uvjek u đžepu na USB sticku
Staro 02.09.2008., 22:22   #4
kalixius
...carpe diem...
kalixius's Avatar
Lokacija: Zagreb - okolica
Postovi: 1,363
Jako zanimljiv programčić no preferiram PrimoPDF(stvar navike).
No imam jedno pitanje oko tih PDF programa.
Šta kažete na Adobe Acrobat 9? Vidio sam da ima mogućnost stvaranja onih formulara za dopunjavanje što je vrlo interesantno ako se radi puno u tome području.
kalixius je offline   Reply With Quote
Staro 03.09.2008., 14:04   #5
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,614
Ja koristim PDF Creator, šta su ovi navedeni možda bolji?
Staro 23.10.2008., 17:17   #6
skare
skare's Avatar
Postovi: 159
Autor FitzTN Pregled postova
solis pdf creator plus! u biti svi proizvodi od solid documentsa su dobri
skare je offline   Reply With Quote
