Postovi: 129
IntelBurnTest
vidim da nitko ne pise o ovome, bas me zanimaju misljenja... http://www.xtremesystems.org/forums/...d.php?t=197835 Code:
Description: Linpack by Intel(R) is an extremely stressful program that will put even the most powerful X86/X64 CPU in the world at its knees. Load temp under Linpack will be up to 22*C higher than the competing software Prime95. This program will make usage of Linpack easier and more practical. Keep in mind, use this program at your own risk. By using this program, you agree that neither I nor Intel shall be responsible for including, but not limited to: burned up CPU, fried motherboard, spontaneous room temperature increase, hair loss, or mental stress. Benefits of using Linpack: 1. More accurate than Prime95 Small FFTs/Blend. 2. Takes less time to tell if your CPU/RAM is unstable than Prime95 (usually something like 8 minutes Linpack vs 40 hours under Prime95). 3. Use the same stress-testing engine that Intel uses to test their products before they are packed and put on shelves for sale. |
LateralusX
Postovi: 1,788
citam raspravu, zvuci zanimljivo ![]() |
only fool, not a horse
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,280
meni se ugrijao jedno 5°c vise nego prime i kaze da mi nije stabilan... jedino mi ne ulijeva bas povjerenje to sto program koji testira stabilnost procesora nemoze/nezna tocno ocitat takt na kojem radi procesor? kaze 3600mhz umjesto 3200. malo mi smijesno to, najblaze receno. ne dizem voltazu na temelju ovog testa.... |
hehe, evo vam program za ubijanje proca ![]() ![]() nego, ja ga baš kurim na poslu, na E4400. jebote, na 1,3V, 68'C ![]() ![]() ![]() |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Postovi: 129
nije stvar dokazivanja, nego da ako je istina ovo sto pise, ljudi koji clockaju svoj procesor mogu usparati dosta vremena... ovo o silovanju se moze primjeniti na overclocking opcenito, al to je tema za sebe... |
Valar morghulis
Postovi: 280
Kad sam prvi put testirao - temperatura je bila manja nego u Orthosu za 3°C..I kaže da nema errora.. Međutim, čudno mi je bilo kad sam vidio da prema njihovim rječima 10-15 min ovog testa odgovara testiranju Primeom/Ortosom po desetak sati pa sam napravio mali "test". Dodatno sam spustio voltažu na procesoru i testirao ga ponovo. Intel Burn Test je prošao bez problema (cca 15min.) i nakon toga upalim Ortos i nakon 25 min mi izbaci error.. Tako da je imho Orthos/Prime još uvijek bolji način testiranja stabilnosti
"The objective of war is not to die for your country, but to make the other bastard die for his." |
Lokacija: x
Postovi: 1,447
Ja ostajem kod prime95. Dok mi je on pokazao da nema problema obicno ih nije bilo u koristenju. Ovo silovanje neznam kakvih testova je pokusaj proizvodaca tih softvera da se uguraju medju ustaljene programe za testiranje. |
Postovi: 288
Ja bi još malo pričekao s time. Vidio sam da se ekipa na XtremeSytems ozbiljno zagrijala za taj program, odnosno neki ga već koriste kao referentni, a s druge strane ima ekipe koja je rekla da im je IntelBurnTest prošao, a Prime nije. Opet, program je za sada dogurao do verzije 1.6, dok su starije nekim ljudima prolazile, 1.6 im ne prolazi... |
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
ne palim se na visoke temp, da odmah bude jasno, zbog nekih izjava gore. ![]() svaki program je koristan ako pokazuje stabilnost mašine, ALI ne znam kome vjerovati, Prime95 radi preko noći (dakle preko 10-15h u komadu) i sve 5., tj. nema grešaka. a ovaj sruši komp u roku 10 minuta, ne želi proći ni na 3.6, 3.4 niti 3.2GHz! (voltaže nisam išao dizati više od onih isprobanih 24h Prime-om jer mislim da nema potrebe, pošto se nikada se nije rušio u Prime-u, a niti u radu ma koliko on naporan bio kroz prošlih 7 mjeseci koliko je setup takav, pa ne vidim smisao dizat ih niti imam vremena kemijati) možda ovaj prog fakat iscrpi CPU više od Prime-a, i baci error. ali čemu? da bude poznat i jedinstven na net-u? da svi pričaju kako je 'bacio najnovije CPU-e na koljena'? kako piše na stranici otkuda se skida taj ''.exe'' ![]() ![]() to mi je kao da stavim auto u ler i ciglu na gas, ode u blokadu, i onda gledam kada će se raspast mašina kroz sat, dva ili manje? dok u normalnim uvjetima rada neće otići ni za 15 godina... http://www.youtube.com/watch?v=Or5qif80xQo&NR=1 http://www.youtube.com/watch?v=0POwsgyj16g&NR=1 http://www.youtube.com/watch?v=VCc-l...eature=related http://www.youtube.com/watch?v=kxExh...eature=related
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() Zadnje izmijenjeno od: TomRi. 01.09.2008. u 20:58. |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,753
Mah... ![]() Ovo izgleda kao jos jedna sprdacina nadrih programera. Ipak, veseli vidjeti malo humora Intelovaca: http://www.intel.com/cd/software/pro...eng/266857.htm Pogledati "Ease of Use" dio. ![]()
#16 | |
Type R
Postovi: 1,485
#18 | |
Avocado
Postovi: 7,853
U SVAKOJ aplikaciji radi savrseno, od 3dcmarka, PS-a pa nadalje, nikad da bi se restarto kao sto se dogodi cim upogonim jedan od ovih stability testova...
Spoiler alert! |
#19 |
Lokacija: Malaysia
Postovi: 96
Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1 |
#20 |
Lokacija: Malaysia
Postovi: 96
Danas: IntelBurnTest 2.3 - Added latest Linpack binaries and patched for AMD CPUs - Added Xtreme Stress Mode (Right-click the "Start" button)
#21 |
Postovi: 11,642
Hvala na svim updateima stasio ![]() |
#22 |
Lokacija: Malaysia
Postovi: 96
Nema problema. ![]()
#23 |
Lokacija: Malaysia
Postovi: 96
