27.08.2008., 02:06 | #1 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,482
Nvidia GeForce 177.92 beta driveri
A new set of nVidia ForceWare Drivers has been released Today.These are in the form of 177.92 Betas. Supports GeForce 6-series, 7-series, 8-series, 9-series, and 200-series GPUs, including the newly released GeForce 9800 GTX+, 9800 GT, and 9500 GT GPUs. Adds support for NVIDIA PhysX acceleration on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory (this driver package installs NVIDIA PhysX System Software v8.08.18). Experience GPU PhysX acceleration in several full games and demos today by downloading the GeForce Power Pack. Adds support for 2-way and 3-way NVIDIA SLI technology with GeForce GTX 200-series GPUs on Intel® D5400XS motherboards. Supports single GPU and NVIDIA SLI™ technology on DirectX 9, DirectX 10, and OpenGL, including 3-way and Quad SLI technology. Supports CUDA™. Supports NVIDIA GeForce 3D Stereo Technology. Supports Folding@home distributing computing application. Download the high performance client for NVIDIA GPUs here http://folding.stanford.edu/English/DownloadWinOther and join the NVIDIA team: #131015. Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software. Includes several 3D application performance improvements. The following are examples of improvements measured with v177.92 WHQL versus v175.19 WHQL driver: Single GPU increases up to 11% in 3DMark Vantage (performance preset) Single GPU increases up to 11% in Assassin's Creed DX10 Single GPU increases up to 15% in Bioshock DX10 Single GPU increases up to 15% in Call of Duty 4 Single GPU increases up to 8% in Enemy Territory: Quake Wars 2-way SLI increases up to 7% in Bioshock DX10 2-way SLI increases up to 10% in Company of Heroes: Opposing Fronts DX10 2-way SLI increases up to 12% in Enemy Territory: Quake Wars 2-way SLI increases up to 10% in World in Conflict DX10 Includes numerous 3D application compatibility fixes. Please read the release notes for more information on product support, features, driver fixes and known compatibility issues. Users without US English operating systems can select their language and download the International driver here: http://www.nvidia.com/Download/index.aspx Release Notes - 177.92 http://www.nvidia.com/docs/IO/58600/...ease_Notes.pdf I za tudume Control Panel User's Guide http://us.download.nvidia.com/Window...tart_Guide.pdf
27.08.2008., 11:25 | #2 |
Lokacija: rijeka
Postovi: 3,736
čito na vr-zonu hmmh,15 postotno poboljšanje,ali su vrovci ismijavali te drivere da su srezali kvalitetu slike da bi dobili bolje performanse,ni jednu od ovih igara ne igram,je ko probao ove drivere?? |
27.08.2008., 14:01 | #5 |
Super Moderators
Postovi: 17,482
27.08.2008., 23:05 | #7 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,339
Al' se i vi palite na Jelcove provokacije. Kad izađu ATI driveri onda je to vijest za naslovnicu a kad izađu od nVidia-e onda Jelc posta da bi mogao pod*ebavati kao ne valja slika i sl.
28.08.2008., 00:08 | #8 |
its slightly turbocharged
Postovi: 5,426
Grom mi izgleda skurio siemensov mrežni modem, pa zbog stavljanja starog Siemensa (USB) morao preči na sa Viste na XP (nema Vista drivera za USB modem ) , stavio 177.79 Betu i sad u CODu koda imam neke memory leakove Odjednom FPS na sekundu padne sa 125 na 50-60 i odma se vrati, dogodi se možda jednom u 10ak minuta. Pomalo annoying
blaa |
28.08.2008., 12:32 | #10 |
volveraš
Postovi: 386
Ja odigral Zuma Deluxe na ovim driverima i ne vidim neki poras perfomansi. Šalu na stranu, stavil sam drivere i dobil crni ekran (vindoze se uredno loudaju u 'pozadini'). Malo sam preštekaval i izgleda da kad sam zvadil s-video kabel za TV van, dobil sam sliku na monitoru. Sa .35 driverima tog problema nisam imel, al možda samo neki konflikt kod instalacije il inicijalizacije monitora/TV-a/HDMI-a. Za testiranje igri baš i nemam vremena osim ak ženi velim da više ne delam i posvetit se čmarku i frapsu.
"I will like to die in my sleep like grandpa and not screaming like his passengers..." |
28.08.2008., 12:59 | #12 |
Pink Floyd fan
Postovi: 5,339
28.08.2008., 13:04 | #13 |
Peachwize=mudra breskva
Lokacija: Ri
Postovi: 210
28.08.2008., 13:07 | #14 |
Pink Floyd fan
Postovi: 5,339
28.08.2008., 13:16 | #16 |
Pink Floyd fan
Postovi: 5,339
Nema na čemu, to "zapinjanje" sam već skužio na nekoj ranijoj verziji. Meni se nije dalo probati taj novi driver iako sam pročitao dobre komentare na guru3d jer jednostavno nemam vremena. Nisam zaigrao ništa danima, tjednima
21.09.2008., 15:35 | #21 |
Lokacija: Švedska
Postovi: 57
problem s driverima za 8800GTX
Ovako :imam dual boot na XP SP3/32bit bez problema idu svi driveri (177.41...177.83...177.98) i physx 8.06.12;8.08.18;8.09.04 - sve radi ok na Visti Ultimate SP1/32bit niti jedan driver nakon 173.65 nece radit u tom smislu sto mi se sve normalno boota, pokaže se desktop i nakon par sekundi monitor ode u standby Maknuo sam tu Vistu i stavio istu samo 64bitnu (isto ima SP1) - friška instalacija (normalno svi driveri za ploču i ostalo što treba), ali niti jedan driver za grafu ne ide (naravno 64bitni) počevši od 177.35,.39,.40,.41,.66,.70,.79,.83,.89,.92,177.98 (ista stvar - dobijem desktop i nakon toga monitor u standbay, pa moram otić u safe-mod,pa rollback driver (standardni od Viste-VGA graphic adapter(niti poznaje da je 8800GTX)) i ponovni pokušaji Ima li bilo tko kakvo rješenje (nemojte samo ono-makni Vistu i ostani na XP jer ti na njemu eto sve šljaka) (komp-odnosno komponente su iz potpisa) |
21.09.2008., 16:16 | #22 |
Postovi: 7,504
Probao ove BETE i jednostavno nisu na razini. OpenGL aplikacije se ruše jer pada nVidin OGL modul. Vratio na 175 i sve radi OK! |
