Zaključane teme
Staro 26.08.2008., 17:39   #1
jest
Lokacija: tu
Postovi: 79
AMD konfiguracija do 10.000 kn
vak, frendica bi komp.. ima neke zelje.. vise manje bi tjerala igrice na njemu...
htjela bi maticnu da moze dvije graficke u crossfire
2 graficke (ATI Radeon)
2 HDDa od 500 GB
2 x 2GB rama
proc 4 jezgre (neki hladnjak za to)
napajenje da sve to komotno odrzava xD
monitor, przilica, kuciste, tipkovnica i mis joj ne trebaju.
hm..
jest je offline
Staro 26.08.2008., 17:49   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Pa sve si već naveo.
Uzmeš 2x4850
2x WD500gb koji su best buy
4gb ocz-a
I phenoma
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline
Staro 26.08.2008., 19:06   #3
BOGDO
klanfa
BOGDO's Avatar
Lokacija: ZG-Dubrava
Postovi: 494
Procesor AMD Phenom X4 9850 Black edition, socket AM2, BOX , 2Mb-1.291,98Kn
ASUS M3A32-MVP DELUXE, AM2+, AMD 790FX/SB600, BUS 1000MHz, DDR2-1.244,40Kn
DDR2 2048Mb ( 2Gb ) PC6400 Kingmax MARS , 800MHz, CL5-224,77Kn x2>>
HDD WD 640Gb, WD6400AAKS, SATA II, Buffer 16Mb, 3Gb/s, 7.200 rpm-520,08Knx2>>
Napajanje CORSAIR 750W, TX Series CMPSU-750TXEU, 12cm vent,ATX2-729,33Kn
DVD upisivač Pioneer DVR-215DBK, DVD±RW, 20x DVD±R ,12x DL-185,20Kn>>
VGA Ati Radeon HD 4870 X2, 2Gb GDDR5 2x256bit, Dual DVI, PCI Ex-3.494,73Kn>>
ANTEC P182 EU (gun metal-crno, bez napajanja, vanjsko upravljanj-999,52Kn>>
Adm za cash 9.435,00Kn
Intel i7 2,66GHz SLBEJ
GigaByte EX58-UD3R F6
3x2Gb Corsair TR3X6G1600C9G
WD6400AAKS
XFX 275 GTX XXX Edition
Corsair TX650W
CM 690
Samsung T220
BOGDO je offline
Staro 26.08.2008., 19:11   #4
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Potpis, jel moze i bolje od tog
Jedino bi ja Intelov Quad, pokazao je malo bolje perf u igrama, ali zelja je zelja
NovA Squadron
kripton je offline
Staro 26.08.2008., 19:22   #5
Postovi: 7,568
Autor kripton Pregled postova
Potpis
Postovi di ti citiraš ljude samo da napišeš potpis (i koju rečenicu, reda-radi), nemaju smisla. Napiši konkretno kaj imaš za reći, a ako nemaš ništ za reći, nemoj postat.
Phenom 9550 ili 9950 + DFI 790FX ploča ili 790GX kad stigne.
Ja bi Triciu Helfer i s njom u paketu štutgartski dvosjed u Black on Black izdanju s dovoljno snage da skine dva-tri sloja asfalata s naših cesta.
Ne morate u svakoj temi spominjati kaj bi vi i da je Intel ovo-ono. Svi znaju da je Intel naj-naj i da je AMD šrot.
Ako je BOGDO bez ikakvih problema složil ono kaj cura traži, onda se i vi ostali udostojite i postajete u skladu s temom.
@BOGDO
Drugi put danas i po koji zna koji put sveukupno ti editiram post, jer ti uporno kopiraš neki kod. Ljudi citiraju te postove i lomi se layout. Ako ti nije problem, napiši post kak spada, jer ovo više nema smisla. Meni se ne da svađati s vama oko najobičnijih postova, a vi se onda vrijeđate na sve moguće sitnice. Meni je najlakše obrisati post, ali nema smisla ako je koristan i dobronamjeran, ali ako se ovak nastavi, brisalo se bude se po redu, bez upozorenja, bez uljudnih postova i bez imalo broge oko toga kome su ti postovi mogli pomoći.
Evo, pa vidi sam na kaj to liči...
McG je offline
Staro 27.08.2008., 12:57   #6
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Quad bi izbjegao pod svaku ruku jer je upotpunosti nepotreban (ako svrsavas na beskorisni 3DMark be my guest)... bar za ovo sto si naveo da ce se raditi na njemu (igranje) stoga bi stavio E8400, te karticu 4870x2 sto je @Bogdo stavio ako bas preferira CF onda dvije 4850...
Uglavnome vise ces izvuci tj koleginica iz clockanoga E8400 na 4.0ghz sa CF nego iz Q6600 na 3.2 ili 3.6ghz (ispravite me ako je krivo)
Ostatak love moze na labela i maskare sa sljokicama potrositi mada sumnjam da ce za to biti dovoljno 3000 kuna
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Zadnje izmijenjeno od: Gjurovski. 27.08.2008. u 16:40.
Gjurovski je offline
Staro 27.08.2008., 15:28   #7
naram-sin
The Last Akkadian
naram-sin's Avatar
Datum registracije: Apr 2008
Postovi: 194
Uglavnom, bilo bi u redu da procitate naslov topica: "AMD komp...", kao i topic uopce.
IMO, najbolje za sada:
1. Phenom x4 9950 ............................... 1444 kn min
2. Corsair 4GB, DDR2, (2x2GB), 1066MHz.... 931 kn min
3. Ati Radeon HD 4870 X2....................... 3495 kn min
4. Chieftec napajanje, 750 W, aktivni PFC... 770 kn min
5. 2*ST31000340AS HDD, Seagate 2*1TB.. 2*1061 kn min
6. kako je rekao i McG, ja bih pricekao neku MBO (DFI po mogucnosti) sa
790FX+SB750 ili 790GX (koje i tako dolaze samo sa SB750, osim ako netko
nije zalihovao SB700 pa ih se bude htio rijesiti, ne znam).
Mislim da ce PSU drzati, a tih je. Hardovi dolaze sa 5 godina garancije, a
moci ce napraviti backup interneta na njih...ako se bas mora/moze ici do 10k kn.
Mada bi ja uz ovo uzeo i 2 * WD640GB AAKS za sistemce (mozda RAID) ili samo njih...
hm, dilema...(ovisno o lovi...).
Doduse, kad se vec moze ici na high-end (amd high end, anyways),
bilo bi dobro provjeriti da ce kuciste pruziti dovoljno mjesta, kako za komponente,
jednako i za strujanje zraka, inace ce trebati razmisliti o nabavi drugog, veceg...kucista, dakako...
Uglavnom, sve ovo: 8762 kn. ostalo za maticnu i ja bih rekao pokoji vent,
da se sve lijepo hladi, i hardovi i proc i grafulja... eto, subjektivan sam glede
AMDa i osjetio sam potrebu odgovoriti na pitanje, kako je i postavljeno...
Zadnje izmijenjeno od: McG. 01.09.2008. u 16:28.
naram-sin je offline
Staro 29.08.2008., 19:43   #8
jest
Lokacija: tu
Postovi: 79
hvala svima, prenjet cu joj vase odgovore
Autor Gjurovski Pregled postova
ja sam zensko
hm..
jest je offline
Staro 29.08.2008., 20:41   #9
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
daj molim te kakva corsair memorija ... ili kingovi ili mushkini ali bolje kingovi ( kazem zato jer neznam dali zna namjestit latencije na cl4 ) ali ako zna onda mushkini li bijeli ili crni
JuiceBox je offline
Staro 01.09.2008., 10:05   #10
naram-sin
The Last Akkadian
naram-sin's Avatar
Postovi: 194
Autor xulos Pregled postova
Mea maxima culpa, inace sam shovinisticka svinja i mislio sam kako neeema
saaaanse da ce se jest-ina frendica igrati sa latencijama niti da je za to
zainteresirana. Ovako, Corsair bez da ikog zaje... sa ikakvim igranjem daje
defaultnih 1066MHz koliko Phenom defaultno podrzava.
Naglasavam: defaultno, overklokeru.
Slazem se za Kingmax, definitivno spada u BB kategoriju, tako i 1066MHz mema,
samo kaj je u trenutku slaganja onog gore, nisam nasao na nabavi, inace preporuka.
Evo i konkretnog prijedloga, umjesto samo nabrajanja: LINK Nabava
jer nema 2GB modula u ponudi trenutno, ili ih ja nisam nasao.
Sretno!
Zadnje izmijenjeno od: McG. 01.09.2008. u 16:29.
Staro 01.09.2008., 14:09   #11
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Gjurovski - bez takvih komentara i uleta.
tor je offline
Staro 01.09.2008., 16:32   #12
Postovi: 7,568
Editirani su postovi u kojima se aludira na bilo kakvo reklamiranje ADM dućana, čisto da ne dođe do nepotrebnih trzavica između forumaša.
McG je offline
Staro 01.09.2008., 17:02   #13
naram-sin
The Last Akkadian
naram-sin's Avatar
Postovi: 194
Heh, trzavice dosle i prosle.
Sve 5. Znaci, ovaj put samo zuti.
Popit cemo jednu za prvi prekrsaj.
Staro 09.09.2008., 20:38   #14
alien_2
alien_2's Avatar
Lokacija: Ogulin
Postovi: 158
Da ne otvaram novi topic bezveze.
Malo brljao, mudrovao i nekaj izmudrovao. Moze misljenje o ovoj mojoj buducoj konfi.
Chieftec gamer tower GX-01B, bez PS, crno
Chieftec power supply 650W Turbo Series
MB Gigabyte MA78G-DS3H, sAM2, AMD 780G
CPU AMD Athlon64 X2 6000+ BOX, dual core, SckAM2
DDR2 2GB PC6400 (800MHz), A-Data x2
HDD Seagate ST3500320AS, 500 GB 32MB, S-ATA300, NCQ-II, 7200.11
DVD+RW/-RW Pioneer DVR-215DBK, SATA, Dual Layer, 20x, black, bulk x2
Powercolor Radeon HD4870 PCIE, PCS, 512MB DDR5
Logitech Speakers X-540 retail, 5.1 set, 70W RMS / 970223-0914
Monitor Samsung SM 2232BW, 22" (ili mozda T200?)
Belkin Superior Series UPS 500VA (lifetime garancija, kad ide sve nek ide i UPS)
Trenutna cijena oko 8.8k sve iz vemila.
alien_2 je offline
Staro 09.09.2008., 20:57   #15
Postovi: 34,046
Prejako napajanje. Uzeti Chiefteca od 450W, za razliku u cijeni uzeti X2 5000 Black Edition + cooler (AC Freezer) te WD 640Gb.
coconut je offline
Staro 09.09.2008., 21:06   #16
alien_2
alien_2's Avatar
Lokacija: Ogulin
Postovi: 158
Autor coconut Pregled postova
Nista ne OCam, tako da kako uzmem tako stoji.
Pa oce 450W biti dovoljno za 4870 i 3-4 venta i ostatak điđa... (bolje da ima viska nego da fali )
Hard mi veci od 500Gb ne treba, jer uvijek kad nekaj skinem itd, kurim na CD/DVD, prva opcija je bio speedy, ali sam vidio da pisu ljudi i o ovom gore navedenom dobro, reko zakaj ne..
Inace komp bi trebao potrajati barem 3-4g (u smislu drzanja pristojnog frameratea u igrama, ne patim na high detalje tako da ono)...
alien_2 je offline
Staro 22.09.2008., 15:35   #17
DjedMraz
Chile
DjedMraz's Avatar
Lokacija: Destination Unknown
Postovi: 370
Da, biti ce dovoljno , al opet ako si nevjerni toma uzmi corsair 550w - razlika ti je 80 kn
DjedMraz je offline
Staro 22.09.2008., 16:50   #18
alien_2
alien_2's Avatar
Lokacija: Ogulin
Postovi: 158
Morat cu uzet chiefteca 750w, jer ce ic SLI/CF ploca i nadam se u skorijoj buducnosti jos jedna HD4870...
alien_2 je offline
Staro 22.09.2008., 18:11   #19
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Nece ti trebati napajanje sa tolikom snagom. Ali ako vec ides na toliku snagu onda uzmi Corsaira, Seasonica ili Silverstona (mislim kad vec ides trositi tolike pare onda kupi nesto od ovo troga).
Milentije je offline
Staro 21.10.2008., 23:20   #20
M.U.P.
M.U.P.'s Avatar
Lokacija: Rijeka - malo iznad :)
Postovi: 372
konfa + monitor do nekih 10k
Prije svega pozdrav grupi!
Frend me zamolio ako bi mu pomogao da slozi neku gaming konfiguraciju koja ce mu trajat neko vrijeme i da bas ne prelazi 10k..
Mislim da je najbolje da kupi sve u linksu, ali nije to neki izricit uvijet, al trgovina mora bit u Rijeci...
Ja nisam u toku sa komponentima dovoljno vremena da se vise ne upustam u savjete pa vas ovdje uvijek spremne i pune znanja molim za pomoc
Konfa neka bude bazirana na AMD-u...
Thx
M.U.P. je offline
Staro 22.10.2008., 00:32   #21
Postovi: 7,568
Prijedlog:__________________________________________
Procesor: Phenom 9950 Black Edition, sck. AM2+ - 1.349 kn
Cooler za procesor: Scythe Katana 2 - 229 kn
Matična: ASRock AOD790GX/128M, sck. AM2+ - 749 kn
Grafička:
  • Sapphire HD 4850 - 1.259 kn
  • Gainward HD 4850 Golden Sample - 1.299 kn
  • Leadtek GTX 260 - 1.939 kn
  • Gainward HD 4870 Golden Sample - 2.059 kn
Memorija:
  • 2x2GB Kingmax DDR800 - 418 kn
  • 2x2GB Crucial DDR800 - 478 kn
Hard disk:
  • 640GB Western Digital, SATA II - 589 kn
  • 750GB Western Digital, SATA II - 779 kn
DVD/RW: Pioneer DVR-216DBK, Black - 189 kn
Napajanje:
  • PCPower & Cooling 500W, 8cm FAN - 599 kn
  • Corsair VX 550W, 12cm FAN - 639 kn
  • Corsair TX 650W, 12cm FAN - 769 kn
Kućište: Lian Li PC-G7B - 766 kn
Monitor: LG L246WH - 2.750 kn
__________________________________________________
Ukupno: 8.897 / 10.117 kn ...sve iz Linksa
Zadnje izmijenjeno od: McG. 22.10.2008. u 00:49.
McG je offline
Staro 22.10.2008., 20:03   #22
M.U.P.
M.U.P.'s Avatar
Postovi: 372
[QUOTE=McG;1170913][INDENT]Prijedlog:__________________________________________
Hard disk:[/COLOR][LIST][*]640GB Western Digital, SATA II - 589 kn [*]750GB Western Digital, SATA II - 779 kn
Puno hvala na savjetima, ovo me malo bode...
Asrock maticna? Znam da je bila prije neka vrlo prihvatljiva, al...
i wd mi nikako ne ide po sigurnosti...
M.U.P. je offline
Staro 22.10.2008., 20:10   #23
Postovi: 7,568
Ta matična je trenutačno najbolje kaj se može kupiti kod nas (a i općenito). Makar imaš i skupljih (ne i boljih) 790GX ili 790FX modela drugih proizvođača, ako baš nećeš ASRock. Disk kupi onaj koji ti najbolje odgovara.
McG je offline
Staro 29.10.2008., 15:39   #24
M.U.P.
M.U.P.'s Avatar
Postovi: 372
Okey, vjerujem ti
Vidim da je i cijena prikladna...
Sto se tice grafa, kolike su razlike izmedju navedenih modela i ima li sto bolje do nekih 3k?
Frend bi htio sto bolju graficku...
M.U.P. je offline
Staro 29.10.2008., 16:15   #25
Postovi: 7,568
Jedan od primjera za razlike između pojedinih kartica, a kaj se tiče boljih kartica do 3.000 kn ima raznih verzija GTX 280 i eventulano HD 4870 X2.
Samo bez obzira kolko god dobru i skupu karticu frend kupi, za svega pol godine one više ne budu najbolje, a i prodajna cijena bude im osjetno pala. Nek sam procjeni kaj mu se najbolje isplati.
McG je offline
Staro 29.10.2008., 19:55   #26
bibonzo
bibonzo's Avatar
Postovi: 49
Evo ovo si ja brijem kupit a dode oko 10000kn sa kucistem znaci izbaci kuciste i nek ti neko doda dobar vent za proc ja ga ne brijem clockat bar neko vrijeme jer je i vise nego dosta.
Gigabyte EP45-DS3R, s775, intel P45+ICH10R, FSB 1600OC 839,97Kn
Procesor Intel Core 2 Quad Q9550 , 4x2.83GHz, socket 775, 12Mb 2.199,67Kn
DDR2 4Gb (2x2Gb) PC8500 Corsair, 1066MHz, TWIN2X4096-8500C5D 899,09Kn
VGA Ati Radeon HD 4870 X2, 2Gb GDDR5 2x256bit, Dual DVI, PCI Ex 3.299,86Kn (jednu ovu za nekih pol jare moze kupit jos jednu i jace napajanje)
HDD WD 640Gb, WD64001AALS, SATA II, Buffer 32Mb, 3Gb/s, 7.200 rp 552,37Kn
Napajanje CORSAIR 750W, TX Series CMPSU-750TXEU, 12cm vent,ATX2 920,62Kn
DVD upisivač Pioneer DVR-216DBK, DVD±RW, 20x DVD±R ,10x DL 190,11Kn
THERMALTAKE Armor VA8000BWS, bez PS, alu-maska, crno, USB, FW, B 1.130,00Kn
To je sve skupa 10030 kn izbaci kuciste i to ti je 8900kn, mislim da je ovo fakat najbolje kaj se nudi i ak ubode jos jednu ovu grafu za crossfire nema joj ravnog jos 2 jare, inace mnogi su kucite ovov popljuvali pa moze i meni neki prijedlog ak ima kaj bolje al da bude big tower.
Sve iz ADM-a.
Nazalost nisam jos dobio kes ali bude pala 100% do kraja sljedeceg tjedna.
Zadnje izmijenjeno od: bibonzo. 29.10.2008. u 20:09.
bibonzo je offline
Staro 29.10.2008., 19:59   #27
Postovi: 7,568
Nažalost to nije najbolje kaj se nudi za te novce, niti čovek traži Intel konfiguraciju.
McG je offline
Staro 29.10.2008., 20:07   #28
bibonzo
bibonzo's Avatar
Postovi: 49
Autor McG Pregled postova
Ah sorry ali ipak brijem da je intel puno bolji i ak mozes rec kaj bi mogo promjenit s tim da mi grafa i procesor ostanu takvi kakvi jesu jer sam se za njih odlucio 100%?
bibonzo je offline
Staro 29.10.2008., 20:10   #29
Postovi: 7,568
Intel možda je bolji od AMD-a, ali to ne znači da baš svi žele kupiti Intel. Kaj se tiče tvojih promjena, nemam niš pametno za reći kad si se za totalno neisplativ i precijenjen procesor odlučil 100%.
Kućište si zamijeni za neko koje vredi te novce tipa CoolerMaster, Antec, Lian-Li, Chieftec, SilverStone i njima slični.
McG je offline
Staro 29.10.2008., 20:14   #30
bibonzo
bibonzo's Avatar
Postovi: 49
Ok hvala.
Sretno sa slaganjem konfe.
bibonzo je offline
Zaključane teme
