Staro 13.05.2004., 01:40   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
NEC 2100A/2500A to Dual Layer 2510A firmware hack
Rezultati:
http://www.cdrinfo.com/forum/tm.asp?...y=%F0%90%93%94
Skidanje:
http://tdb.rpc1.org/#ND2510A
Flash tak jasno svako na svoj rizik
Staro 13.05.2004., 17:05   #2
miato
(°_°)
miato's Avatar
Postovi: 3,249
naajs :clap:
kad kupim przu, apgrejdam firmware
jedini sto mi se ne svidja, je sto kazu da neznaju dali se moze vratiti na stari firmware nakon flasha.... pa ono, mogli su provjerit
BTW, kad je realno za ocekivat dual layer medije kod nas?
Staro 13.05.2004., 19:53   #3
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
vau. legendarno. sutra ću probat... samo da nabavim medije.
fenks
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 13.05.2004., 22:51   #4
miato
(°_°)
miato's Avatar
Postovi: 3,249
fenks
jesi ti to mozda reko feniks ?
di ima medija?
Staro 16.05.2004., 11:09   #5
miato
(°_°)
miato's Avatar
Postovi: 3,249
ok, kad niko nece, moram si sam odgovorit na pitanje
ovo kaze afterdawn...
"Taiwanese manufacturers, including Ritek and CMC Magnetics, have announced that they plan to start the production of double-layer DVD±R discs this summer. Several manufacturers have already announced plans to release double-layer drives in May.
Ritek is currently doing trial production of dual-layer discs for quality certification, and expects to begin volume production by the end of June"
dakle, ne isplati se jos upgrejdat sa ovog gigabytea na neca
Staro 17.05.2004., 14:08   #6
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
flashal bum kad bude medija.
Ak neko flasha prije nek veli kak se ponasa.
Za sad sam ga flash-o na necov original firmware v 1.07
http://www.necd.de/softwareoverview2.php/id/557
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
Zadnje izmijenjeno od: BrunoZG. 17.05.2004. u 19:52.
BrunoZG je offline   Reply With Quote
Staro 17.05.2004., 19:39   #7
medo
#erase startup-config
medo's Avatar
Postovi: 3,632
navodno da budu DL mediji koštali oko 10-15 eura
medo je online   Reply With Quote
Staro 17.05.2004., 22:34   #8
miato
(°_°)
miato's Avatar
Postovi: 3,249
cim izadju, da.
al oko bozica nadam se da ce past na razumnijih 20ak kn
Staro 18.05.2004., 12:15   #9
medo
medo's Avatar
Postovi: 3,632
nadam se i ja, ali se bojim da cijene ne budu pale tako brzo...
However, po testovima na siteovima, vidi se da DL mediji na drugom sloju imaju po jedan do dva reda veličine (!) veći PI/PO error rate od vulgaris DVD+-R medija, te da je kompatibilnost još uvijek veliki problem - većina DVD Playera trza ili uopće neće čitati te medije. A još kad se uzme u obzir da će početna brzina snimanja biti 2.4x za + format (skoro sat vremena!)......
Brijem da je dual-layer za sada kita, jer je preskupo i ne radi kako treba, tako da su moje prognoze da će to biti OK tek za godinu dana.
Staro 18.05.2004., 14:45   #10
miato
(°_°)
miato's Avatar
Postovi: 3,249
je, i ja se bojim da nece past kako bi ja to zelio.
a di to ima testova DL medija?
Staro 01.06.2004., 09:11   #11
Rivi
Ovo ispod nisam ja! :)
Rivi's Avatar
Datum registracije: Sep 2002
Postovi: 1,692
A niko još nije poslao službeno mišljenje NEC-a.
Potpisujem!
Rivi je offline   Reply With Quote
Staro 01.06.2004., 14:04   #12
miato
(°_°)
miato's Avatar
Postovi: 3,249
lol....
a sta bi drugo rekli? Ljudi flashajte svoje jeftinije uredjaje, radit ce vam ko ovi skuplji ?
