Staro 15.07.2008., 13:18   #1
Punio4
Punio4's Avatar
Lokacija: Zagreb, Maksimir
Postovi: 437
Molim review konfiguracije, sve iz ADM-a
1 x Procesor Intel Core 2 Duo E8400 , 3GHz, socket 775, 6Mb cache
1 x Gigabyte Radeon HD 4850 512MB DDR3,256bit, DVI-I / D-sub / HDTV
1 x Gigabyte EP35-DS3R, s775 v2.1 ,Intel P35+ICH9R,FSB1333/1066MHz
2 x DDR2 2048Mb ( 2Gb ) PC6400 Kingmax MARS , 800MHz, CL5
1 x Napajanje CORSAIR 450W, VX Series CMPSU-450VXEU, 12cm vent.,ATX2
1 x Coolermaster CM 690, crno, 213x482x524,5mm (š/v/d) , i/o panel
1 x HDD Seagate 640GB, Serial ATA II, 7200 rpm, Barracuda 7200.11
1 x PHILIPS 220WS8FB, 22" LCD, widescreen, 1000:1, 5ms, VGA, DVI-D
1 x DVD upisivač Liteon LH-20A1L, 20x , DVD-Dual, black, Sata, light
7.366,77Kn
Predlažete li neku drugu matičnu ili neki drugi monitor?
Ili možda neku drugu komponentu općenito?
Nije config za mene, već frendu slažem, te je bitno da ostane cijena do max 7500 kn.
Punio4 je offline   Reply With Quote
Staro 15.07.2008., 13:20   #2
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
Drugo kućište jer CM690 više nemaš nigdje osim u MakroMikru u kompletu s napajanjem, a i to je upitno.
EDIT: Nema ga na njihovim stranicama dok nabava pokazuje da ima. Dakle, 0 bodova. Probaj s CM590
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 15.07.2008., 13:23   #3
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Maticna je u redu.... ostalo nista nebi mjenjao...
Jedino kuciste kojega nema... big tower Cufteka
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 15.07.2008., 13:24   #4
Postovi: 34,028
Umjesto Seagate 640Gb uzeti WD 640Gb (6400AAKS). I uzeo bih radije neku LG/Samsung/Pioneer pržilicu.
Gore navedena opservacija za kućište stoji.
Staro 15.07.2008., 13:32   #5
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
Što se pržilica tiče, osobno bih išao samo na LG.
Dok kod monitora LG 226WTQ, koliko vidim, čak je i jeftiniji. Philips je možda malkice u prednosti samo ako ima 0 dead pixel toleranciju ( tko zna kakve si sreće ) Provjeri ako je moguće.
LCD: BENQ PD3200Q
Staro 15.07.2008., 13:39   #6
Punio4
Punio4's Avatar
Postovi: 437
Ok, piknuo sam Pioneer pržu... A jedno pitanje samo oko WD-a.
Po čemu je bolji od seagatea? Vidim da ima i duplo manje cachea, te je malo jeftiniji.
Evo edita:
1.150,46Kn
467,99Kn
HDD WD 640Gb, WD6400AAKS, SATA II, Buffer 16Mb, 3Gb/s, 7.200 rpm
545,20Kn
645,63Kn
1.199,19Kn
487,80Kn
DVD upisivač Pioneer DVR-215DBK, DVD±RW, 20x DVD±R ,12x DL
185,20Kn
LG LCD L226WTQ, 22" wide, 1680 x 1050 wide, DFC : 5000:1,2ms,crn
1.898,61Kn
ANTEC NINE HUNDRED-EU (Gamer case, bez PSU)
840,50Kn
Ukupno: 7.420,58Kn
[EDIT 2]:
Jedno maaalo offtopic pitanje.
Naime stavio sam 4 gige rama, te planiram instalirati 64bit Vistu.
Bio sam kod drugog frenda kojemu je najnormalnije radila, jedino na što je trebao "pripaziti" je da skida 64 bit drivere. Sve ostalo radi.
Imate li još kakav savjet oko 64 bita na kaj treba pripaziti?
Ak treba, bum prebacio raspravu na software.
Zadnje izmijenjeno od: Punio4. 15.07.2008. u 13:51.
Staro 15.07.2008., 14:04   #7
Postovi: 34,028
U zadnje vrijeme ima nešto problema s pouzdanošću Seagate diskova, a WD se pokazao kao odličan hard (imaš i cijelu temu o njemu ovdje).
Nadam se da si svjestan toga da ti neće svi programi raditi pod 64-bitnim OS-om. Lako za drivere. Aplikacije su veći problem tih OS-ova.
Staro 15.07.2008., 14:15   #8
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
Nema problema s aplikacijama. Sve na Visti radi savršeno. Koristim 64 bitnu Vistu Business već jako dugo i nijedan problem s aplikacijama nisam imao, bez obzira koje starosti. Samo provjeriš dal postoje driveri za sve komponente i to je to.
LCD: BENQ PD3200Q
Staro 15.07.2008., 15:16   #9
refugee
Malac
refugee's Avatar
Datum registracije: Jun 2003
Lokacija: Zabreg
Postovi: 290
Jel bi imalo smisla uzet 200-300kn jeftinije kuciste, pa piknut radeon 4870?
Komp 2...
Barton 2500+
Abit NF7 2.0
1GB DDR 400 KingMax
Seagate 200 GB
PNY 6800 GT
NEC 4551 DVD-R/RW DL + Toshiba DVD-ROM
refugee je offline   Reply With Quote
Staro 15.07.2008., 15:37   #10
Punio4
Punio4's Avatar
Postovi: 437
Koliko ja vidim, najjeftinija 4870 (bilo gdje) dođe 1800 kn.
Tako da je 600 kn razlike, što je 50% cijene 4850.
Rađe pričekaš godinu dana pa uzmeš 5850 opet za 1200 a tih 600 kn ostaviš u džepu
Na grafe se ne isplati davati iznad 1500 kn.
Zadnje izmijenjeno od: Punio4. 15.07.2008. u 15:48.
Staro 15.07.2008., 15:37   #11
Thommy
Thommy's Avatar
Postovi: 469
ja bi uzeo jeftinije kuciste npr.
Chieftec Aegis CH-05B-B, crno, 3×5,25", 1×3,5" (6×3,5"interno) 494 kn
... samo mu to nije dovoljna razlika u cijeni da kupi HD4870 iz ADM-a
ali bi za tu razliku u cijeni sigurno uzeo maticnu sa novijim chipsetom npr. ASUS P5Q PRO
inace ti je kuciste skuplje od maticne ploce
Zadnje izmijenjeno od: Thommy. 15.07.2008. u 16:03.
Thommy je offline   Reply With Quote
Staro 15.07.2008., 16:16   #12
Punio4
Punio4's Avatar
Postovi: 437
Sada sam naletio na ovo:
http://www.xbitlabs.com/articles/oth.../22inch_9.html
The LG Flatron L226WTQ differs from its predecessor L226WT in one point only. It has an LCD panel with Response Time Compensation. It is indeed a very fast monitor but this speed is accompanied with visual artifacts that are perfectly noticeable in games as well as at everyday work. The L226WTQ is so far the worst monitor from this aspect. We’ve never had a monitor with an RTC error average of higher than 25%. The color temperature setup hasn’t improved since the previous model: gray is still bluish in comparison with white.
Vadim i neki stari VIDI, Samsung 2232BW je koštao 2500 i odnio Grand Prix nagradu, a našao sam ga po 1900 kn
Komentari? Prijedlozi?
Staro 15.07.2008., 16:23   #13
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
LCD: BENQ PD3200Q
Staro 15.07.2008., 16:34   #14
karlito
sam svoj aka
karlito's Avatar
Postovi: 789
@Punio4, ajde prekriži Samsung i uzmi preporučeni Lg L226WTQ, pa da čujem dojmove, pošto ga i ja mislim kupit....
....imaš ga u ADM-u....full crnog, za 1898kn.....
karlito je offline   Reply With Quote
