Staro 08.07.2008., 13:11   #661
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
A što su tek napravili starijim grafama,3850 za 69 eura..
http://www.fudzilla.com/index.php?op...=8314&Itemid=1
kakvo vrijeme za kupnju nove VGA...ili prijelaz sa X1900 serije..ccc..
ima u linksu sapphirka za 20xy kn..4870,IMHO malo preskupo...ali eto,Sapphire...i ima dual slot cooling..kao sa 3870x2 modela..
Staro 08.07.2008., 13:19   #662
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,280
1850kn u Vemila
Staro 08.07.2008., 13:20   #663
žile
žile's Avatar
Postovi: 3,074
Skupe su,da.
Prije si napravim quad CF ako ulovim još jednu za 1300kn
žile je offline   Reply With Quote
Staro 08.07.2008., 13:30   #664
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Da li ima kakvog smisla stavljati vf700alcu na 4850? stoji mi u ladici od stare grafe pa sam mislio mozda bi ga se moglo iskoristiti ali grafa se uzasno zagrijava...da li je tko to probao?
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 08.07.2008., 13:31   #665
Razer
Razer's Avatar
Postovi: 11,642
Svakako probaj pa javi
Staro 08.07.2008., 13:38   #666
thedream
thedream's Avatar
Postovi: 5,458
Autor žile Pregled postova
Skupe su,da.
koji si điber,sad bi i moju za 1300 otuđio..ispod 1500,1600 zaboraviiii
Staro 08.07.2008., 15:52   #667
LuxZg
Postovi: 512
@micek - čujem da jedva hladi 4850 kako treba, pa mislim bolje da se držiš stock coolera.
Btw, za sad SVE 4870 dolaze sa istim ovakvim dual-slot coolerom (sličan kao i 3870 i 3870 X2). I pošto i Diamondova Black Edition sa otključanim BIOS-om i OC-om out-of-the-box dolazi sa istim tim coolerom očito radi posao kako treba. Jedino kaj može bit malo bučniji kad se zavrti do kraja, al sve je ok dok se ne razleti nekaj
Po meni jedino efektivno i jeftino rješenje nudi AC S1 i to je to. S njim ekipa ima oko 50C load, sa overclockom i do 900MHz oko 55C, dakle super! Ili ako ne klokaš onda možda može i pasiva (al samo ak imaš dobru ventilaciju kućišta).
Btw sve gledam cijene kao da će u roku sat vremena popadat Al kako bilo do kraja tjedna se moram odlučit i u shopping! Možda si i bez pada cijene priuštim 4870, ak uštedim PDV nekako :O
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 08.07.2008., 16:00   #668
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor LuxZg Pregled postova
malo bučniji
Samo se ti nadaj
Staro 08.07.2008., 17:10   #669
LuxZg
Postovi: 512
Autor Jelc Pregled postova
Samo se ti nadaj
Hehehe Ma nadam se, ne da mi se opet S1 postavljat.. al je tu ak bu ovaj prebučan
Staro 08.07.2008., 17:19   #670
Jelc
Super Moderators
Postovi: 17,485
Meni ne smeta buka ali još ni jedan ATI-jev dualac nije bio tih na većim okretajima.
Tako da ti je najpametnije odmah skinut tvornički, očistit, stavit Ceramique i S1
Staro 08.07.2008., 19:02   #671
Boogie
Lokacija: Sarajevo-Mostar-Bugojno
Postovi: 227
Evo gledam stigli kod nas Radeoni 4870.
Club3D CGAX-4872DD RadeonHD4870 512M DDR5 TV+2xDVI 750/3600
Cijena: 463 KM + PDV (17%) x4 = kune
Kakve su cijene u hr?
Boogie je offline   Reply With Quote
Staro 08.07.2008., 19:05   #672
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
cijene u bosni bez PDV su kao u HR s PDV-om.
danij3l je offline   Reply With Quote
Staro 08.07.2008., 19:08   #673
R@zzoR
Yippie-Ka-Yay
R@zzoR's Avatar
Postovi: 560
Autor Boogie Pregled postova
Zadnji put kada sam gledao bilo je ~1800kn u Ve-mila. A uostalom piše ti par postova iznad.
R@zzoR je offline   Reply With Quote
Staro 08.07.2008., 19:48   #674
Ubleha
Ubleha's Avatar
Lokacija: BiH
Postovi: 1,485
Nas deru ko mlade majmune.
Nisam pijan sve dok mogu da ležim na podu i da se nizašta nedržim.
Ubleha je offline   Reply With Quote
Staro 08.07.2008., 20:29   #675
Kimi
Kimi's Avatar
Postovi: 652
Autor R@zzoR Pregled postova
Core na 800MHz impresivno. Izgleda da se u ATI-ju nisu zafrkavali sa podatkom da su RV770 kartice tvornički zaključane, ovo će stvarno dati dobar udarac envidiji. ATI koristi Intelovo oružje.
EDIT: Zna li netko maximum ovih kartica(prvenstveno HD4850)?
Moja na S1 ide na 700/1100 s tim da to nije plafon,idem sad još malo testirati;a sutra ću kloknuti i E7200 da stavim 3d06 score
Kimi je offline   Reply With Quote
Staro 09.07.2008., 12:47   #676
trixx
Postovi: 177
evo ak vec nije bilo....
testovi iz tweaktowna http://www.tweaktown.com/reviews/148...ire/index.html
u testu se mogu vidjet 4870,4850,260,280,3870x2...
trixx je offline   Reply With Quote
Staro 09.07.2008., 12:50   #677
žile
žile's Avatar
Postovi: 3,074
Šta je rezultat ovako niskim frameovima 3870X2 u crysisu?Loši driveri ili?
Staro 09.07.2008., 13:19   #678
panisher20
panisher20's Avatar
Postovi: 939
panisher20 je offline   Reply With Quote
Staro 09.07.2008., 13:28   #679
Postovi: 33,922
Uglavnom, košta koliko i 4870 koja je bolja od nje.
OT: Stranice su im totalna banana. Pritisni Refresh u browseru nekoliko puta i svaki put prati cijenu. Svaki put će biti drugčija. Dobivam cijene od 1.850-2.060kn. Koja je od njih prava?
Staro 09.07.2008., 15:04   #680
ShAd0w_dAnCeR
ShAd0w_dAnCeR's Avatar
Lokacija: BJ/ZG
Postovi: 539
el ide accelero s1 rev2 na hd4870?
ShAd0w_dAnCeR je offline   Reply With Quote
Staro 09.07.2008., 16:49   #681
žile
žile's Avatar
Postovi: 3,074
Ide.
Staro 09.07.2008., 21:05   #682
R@zzoR
Yippie-Ka-Yay
R@zzoR's Avatar
Postovi: 560
Mali problemčić imam, oc-am malo svoju HD4850(700/1125) i upalim igru i driveri se ruše svaku malo. Trebam li nešto isključit kod driver ili su ovi catalysti stvarno sranje kakvog nema??? Postoje li zasad koji bolji?? Imam instaliran onaj atijev hotfix za ove nove radeonke.
Staro 09.07.2008., 21:19   #683
Jelc
Super Moderators
Postovi: 17,485
Koju igru?
Staro 09.07.2008., 21:46   #684
R@zzoR
Yippie-Ka-Yay
R@zzoR's Avatar
Postovi: 560
Koju igru?
Bilo koju, igrao grid i double agent sa oc-anom grafom i na svakoj se rušili driveri za grafu
Staro 09.07.2008., 22:01   #685
Jelc
Super Moderators
Postovi: 17,485
Ja sam se ovih dana bogme naigro i nije se ništa rušilo, netko mi je spomenuo (Pinsla mislim) da je kad je igrao GRID tu-i-tamo znalo usporit...
Staro 09.07.2008., 23:01   #686
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Jel na 4800 seriju ide stari Accelero S1?
Gledam po stranici AC-a, ali ima samo za rev 2
Pa eto ako netko zna, bio bi zahvalan
Di sam stao?
Staro 09.07.2008., 23:30   #687
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ide, ide...jedino sto treba rijesiti hladjenje regulatora napona, ali to vrijedi i za Rev. 2.
Staro 11.07.2008., 10:30   #688
sams
sams's Avatar
Postovi: 29
Hd 4870
Molio bi lijepo sve koji imaju tu grafu da podijele samnom i ostalima dojmove i recenzije i usporedbe sa ostalim grafama , da pomognu malo pri odabiru i kazu misljenje... Znam da ima tema 4800 ali ja bi volio cuti vise o samoj radeonki..
Ja sam vidio i cuo da je grafa pun pogodak i konkurencija Nvidijinoj 260tki i vrlo blizu 280tki..
Zadnje izmijenjeno od: Jelc. 11.07.2008. u 11:01.
sams je offline   Reply With Quote
Staro 11.07.2008., 12:18   #689
Jelc
Super Moderators
Postovi: 17,485
I nakon svega čini se da će ATI uskoro završiti samo kao AMD-ov odjel za razvoj čipseta.
Zaista tužno
Nekaj sam tražio i naletio na ovo (15.12.2007)
Sve si nekaj mislim da su se dežurni ljubitelji Endivije i više nego malo za*ebali
Zaista tužno
Staro 11.07.2008., 12:26   #690
Mar
Suit up!
Mar's Avatar
Postovi: 5,962
Zaista tužno
Ta banana u prvom planu je Nevidija, a druga ATI?
- Barney Stinson
