#121 | |
Postovi: 870
#122 |
Postovi: 347
OT Moram pothitno kupit klimu... jer mi se po ovoj vručini neda snimit sve to skupa, a stoji sve spremno za instalaciju već 4-5 dana ![]() I onda svaki put ispočetka dođem ovdje i čitam temu kako vam svima sve super radi ![]() |
#123 | |
Datum registracije: Mar 2008
Postovi: 120
nije mi proradio physx ali zato crysis piči ko lud ![]() |
#124 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,537
#127 | |
Postovi: 245
Grid mi se ruši. Crysis nema promjena. ![]() U PhysX properties pod settings stoji označeno: GeForce PhysX. WTF?!?! |
#130 |
Postovi: 3,074
Vjerojatno korišten krivi .inf file. |
#131 |
IT Consultant
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
novi programic pa tko voli nek izvoli: NV PhysX Tweaker 1.0. A small tweak utility to en/disable GeForce PhysX and switch to CPU PhysX. Matuus, our in-house Guru3D NVHardpage programmer stumbled into the same issue I had as well. The NVIDIA PhysX driver once install will activate itself on the GPU, and can not be disabled.This little NV PhysX Tweaker tool will allow you to actually choose to enable or disable the PhysX driver over the GPU and if preferred, the CPU. Very simple, yet very handy. If you have UAC enabled, you must run this software as Administrator. http://downloads.guru3d.com/download...f4a44dc7cdc1b1
"All we have to decide is what to do with the time that is given us" J.R.R. Tolkien |
#133 | |
Pod naletima kopita zla
Lokacija: SMB / ZGB
Postovi: 7,735
mislio sam koristiti google..ali ti si mi učinio uslugu ![]() @Lacy..pretpostavljam da radi uredno na serverima 2k8 jer ovu subotu idu gore ![]() |
#134 |
Pink Floyd fan
Postovi: 5,537
Naravno ![]()
#136 |
Lokacija: Švedska
Postovi: 57
dilema
koliko vidim prema ovome - trebalo bi ići i na G80 (probam pa javim) http://www.itx.ba/index.php?option=c...6723&Itemid=39 a evo što se događa s physx-om na ATI-ju (da se osvrnem na ono što su postali Matth€w i Jerry) http://www.itx.ba/index.php?option=c...=6755&Itemid=1 nego, jeste li vi za crveni (grafe) ili crni (komad) PCB ![]() http://www.guru3d.com/article/radeon...-performance/8 |
#137 | |
Lokacija: Zagabria
Postovi: 492
#139 |
Xulos :)
Postovi: 7,556
a kod mene stalno sranja s tim driverima... kad ih snimim ovo pise :The file nvd3dum.dll,nvwgf2um.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL) i nece ih instalirat sad imam 177.39 i GRID mi se zna srusit i dobijem BSOD koji kaze : dxgkrnl.sys ( dxgkrnl!VIDMM_PROCESS_HEAP::~VIDMM_PROCESS_HEAP+62 ) sta je to :S wtf ?
#142 | |
Lokacija: near VZ
Postovi: 124
#144 |
IT Consultant
Postovi: 323
#146 |
Pink Floyd fan
Postovi: 5,537
For lazy persons...
#148 |
Pink Floyd fan
Postovi: 5,537
Vjerojatno te zanima kao i autora whats taking it so long ?? physx+G80.
#149 |
Postovi: 2,717
dela to na XPu?
MC |
#150 |
Lokacija: CROATIA
Postovi: 31
physx radi na mojoj 8600m gs na g86 čipu sa novim driverima slike da physx radi na g86 čipu Iz pravila: [56k warning] upozorenje je potrebno staviti i kod postanja linkova koji vode na stranice sa "težim" slikama ili videom.... http://forum.pcekspert.com/faq.php?f...snovna_pravila Budući da si mudro objesio BMP od samo 4 MB barem si mogao staviti upozorenje ![]() Zadnje izmijenjeno od: Jelc. 28.07.2008. u 10:18. |
