#212 | |
Postovi: 270
#213 |
Postovi: 7,568
Kaj ti nije jasno? Napiši točno, jer s ovim WTF neš došel do odgovora. Dual-BIOS ti je čudan ili kaj? Dual-BIOS Gigabytove ploče imaju već duži niz godina, a bome i ostali proizvođači imaju slična rješenja, ako se orginalni BIOS slomi. Zadnje izmijenjeno od: McG. 14.06.2009. u 00:56. |
#215 | |
Postovi: 270
![]() EDIT: novosti na AMD polju... stigoše B3 Phenomi http://techreport.com/articles.x/14424 Zadnje izmijenjeno od: Bilobrkster. 27.03.2008. u 23:22. |
#216 |
Postovi: 7,568
Asus M3N-H/HDMI ploča s GeForce 8300 IGPom
Asus is first to announce a GeForce 8300 ATX mainboard. The ASUS M3N-H/HDMI based on the GeForce 8300 should have a higher clock speed for it's integrated graphics core and is able to run slightly faster than the AMD 780G.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 17:36. Razlog: Reupload slika.:) |
#217 |
Postovi: 270
Evo novi B3 Phenom 9850 može i do 3GHz http://www.anandtech.com/cpuchipsets...spx?i=3272&p=3 |
#218 |
Postovi: 7,568
Abit A-N78HD GeForce 8200 AM2+ ploča
Abit announced their latest motherboard for AMD Socket AM2+/AM2 processors, the abit A-N78HD. Based on nVidia’s powerful GeForce 8200 chipset this highly integrated multimedia platform motherboard makes high definition multimedia enjoyment more convenient and easier than ever. The integrated GeForce 8 graphics supports DirectX 10 and Shader Model 4.0. With the all-in-one design you just need a processor and memory and you are ready to indulge in high definition multimedia right out of the box.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 17:36. |
#219 |
Postovi: 7,568
Gigabyte MA78G-DS3H ploča
Based on the AMD 780G chipset, the Gigabyte GA-MA78G-DS3H offers outstanding future CPU headroom with support for AM2 Athlon processors as well as the latest AM2+ Phenom processors with ultra low latency, high bandwidth Hyper Transport 3.0 (5200MT/s) technology. At the heart of the Gigabyte GA-MA78G-DS3H lies the ATi Radeon HD 3200 graphics core, featuring support for DirectX 10, Shader Model 4.0 and OpenGL2.0. With unmatched IGP overclocking ability the GA-MA78G-DS3H is able to boost the GPU frequency up to 950MHz.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 17:37. |
#220 |
Postovi: 7,568
Low-power i 45nm Phenomi, te 95W-ne verzije aktualnih Phenoma
AMD is planning to launch two 45nm Phenom X4 CPUs (Deneb) in 2008 with core frequencies of between 2.5-2.8GHz and 2.4-2.7GHz, with both adopting 6MB L3 Cache and having a TDP rating of 95W. AMD will announce the final order date for its 125W Phenom X4 9750 by the end of the second quarter and the CPU will be replaced by a 95W version – which is available this quarter – while the 95W Phenom X4 9850 will appear before January of 2009. The company is also planning to launch an updated version of its upcoming Phenom X4 9950 (schedule to launch in June) at the end of the fourth quarter. In addition to the current triple-core CPUs, AMD will launch the Phenom X3 8550 with a core frequency of 2.2GHz in the third quarter (production beginning in the second quarter) and the company will launch more triple-core CPUs in the fourth quarter.Izvor: DigiTimes Zadnje izmijenjeno od: McG. 30.09.2010. u 17:37. |
#221 |
Postovi: 7,568
Gigabyte 790GX + SB750 AM2+ ploča
The 790GX integrates a graphics core HD3300. This is slightly better than the HD3200 on the 780G boards. The board also incorporates side port memory which uses the ELPIDA memory for onboard buffer. Other than a heatpipe design, the board uses a newer south bridge SB750. The board also uses a 4+1 phase power design. It is said that AMD 790G IGP can do CrossFire (Dual 8x) and Hybrid CrossFire at the same time. There is no confirmation about this yet but we don't think doing a Hybrid CrossFire at the same time with CrossFire will bring much improvement in performance.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 17:37. Razlog: Reupload slika.:) |
#222 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Dobro izgleda ![]() Vidim i da je Nevidia izbacila hrpu integruša...baš me zanima kak to hoda...
Zadnje izmijenjeno od: McG. 05.12.2008. u 03:29. |
#223 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#224 |
Postovi: 12,425
ajd dobro da su se više makli sa SB600 ![]() nego baš me zanima kak će se sve to grijat jer kombinacija 790FX + SB600 je blago rečeno vruća
#225 | |
Postovi: 7,568
DFI LP DK 790GX-M2RS AM2+ ploča
Zadnje izmijenjeno od: McG. 14.06.2009. u 00:51. Razlog: Reupload slika.:) |
#226 |
Super Moderators
Postovi: 17,485
#228 | |
Lokacija: Zabok
Postovi: 3,361
#229 |
Lokacija: NaN
Postovi: 3,438
Ipak možda ništa od Kume. http://www.tweaktown.com/news/9651/a...k10/index.html EDIT: http://babelfish.yahoo.com/translate...rUrl=Translate Zadnje izmijenjeno od: Matth€w. 11.06.2008. u 00:52. |
#231 |
Postovi: 177
Procesor AMD Phenom X3 8650 , socket AM2, BOX , 1.5 Gb cache cemu je namijenjen taj procesor,ima 1.5 gb cache |
#232 | |
Postovi: 1,450
#233 |
Postovi: 7,568
Low-power X3 i X4 Phenomi i 45nm Phenomi
AMD will unveil low-power triple-core, low-power quad-core, faster quad-core, and 45nm quad-core Phenoms in the second half of this year. In chronological order, AMD will first roll out 1.9GHz Phenom X3 8250e and 2.1GHz Phenom 8450e processors in mid to late August. Both CPUs will have three cores and 65W thermal envelopes, and they'll be joined by a quad-core, low-power Phenom X4 9350e later in the third quarter. The following quarter, AMD will reportedly strike again with a Phenom X4 9950 clocked at 2.6GHz.Izvor: The Tech Report Zadnje izmijenjeno od: McG. 30.09.2010. u 17:38. |
#234 |
Postovi: 1,816
Evo jedan review ovih low power Phenoma: Phenom X4 9150e (1.8GHz) and the Phenom X4 9350e (2.0Ghz) http://translate.google.com/translat...F8&sl=es&tl=en Te jedan brzinski test AMD Phenoma X4 9950 (3.57GHz@stock cooler) http://translate.google.com/translat...F8&sl=el&tl=en
Stupid is as stupid does |
#235 |
Lokacija: Zabok
Postovi: 3,361
Low power Phemoni ![]() Ima recenzija na HotHW za koju ne treba translator: http://www.hothardware.com/Articles/..._Debut/?page=1 |
#236 |
Lokacija: NaN
Postovi: 3,438
Breaking news from Index.hr ![]() http://www.index.hr/vijesti/clanak/c...la/393267.aspx Btw. u prvoj verziji članka su napisali buffer umjesto množitelja. ![]() ![]() I oni bi u IT vode... |
#237 |
Postovi: 7,568
#239 |
Postovi: 7,568
45nm Phenom baziran na Deneb jezgri clockan na 3.4GHz
CPU-Z screenshots of the chip in action reveal a 2.2GHz default clock speed, four chunks of 512KB L2 cache, 6MB of shared L3 cache—4MB more than on current Phenom X4s—and a 1.224V core voltage.Izvor: The Tech Report i ITOCP Zadnje izmijenjeno od: McG. 30.09.2010. u 17:38. |
#240 |
Postovi: 2,636
Nice ![]() Što se mene tiče ovo je the next best thing (ono kaj bi mogao kupiti ak bude novaca). Ak bude prilike tamo u zimi bi bilo lijepo upgredati sistem s jednom 790gx pločom i jednim denebom ![]() Da se razumijemo, ne zbog super pi-a i bijesnog clocka nego zbog dobrih performansi koje očekujem i jeftinije cijene od konkurencije. jedno pitanje: na ss-u u cpuz-u piše deneb - kaj nije deneb trebao biti verzija phenoma bez l3 cache-a? njemu se veselim jer će sigurno biti pristupačniji cijenom od verzija sa 6mb l3 cachea, a performanse nebi trebale biti puno slabije. osim ako nisu čuda napravili s tim l3 cacheom u odnosu na 65nm Phenome ![]()
