Staro 24.04.2008., 01:11   #1
Razer
Razer's Avatar
Postovi: 11,642
Core Temp
Changelog:
Version 0.98 - 23rd April, 2008
  • Fix: Core Temp sometimes crashes when another program tries to access the log file. - Still needs further testing.
  • Add: Show load percentage per core.
  • Add: Adjustable Tj.Max value via *.INI file.
  • Add: Option to start Core Temp with Windows.
  • Add: Support new Intel Mobile processors
  • Change: Maximum logging interval is now 99999ms instead of 9999ms.
  • Change: Log file layout. Shows current temperature, high/low temperature, core load, CPU speed.
Version 0.98.1 - 23rd April, 2008
  • Fix: Incorrect recognition of 45nm Intel CPUs in version 0.98.
Version 0.99 - 2nd May, 2008
  • Fix: Incorrect recognition of 45nm Mobile Intel CPUs.
  • Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).
  • Add: Shared memory - developers now have access to Core Temp data.
  • Add: Register dump to text file function.
  • Add: Preliminary Atom (Silverthorne) support - Untested.
Download
Zadnje izmijenjeno od: Razer. 03.05.2008. u 11:14.
Staro 24.04.2008., 02:26   #2
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Meni malo preveliku temp pokazuje, iako znam da sigurno nije takva. Idle pokazuje 49-50, a u Everest 35-36 celzača (isto tako i u TAT - u).
Matth€w je offline   Reply With Quote
Staro 24.04.2008., 06:05   #3
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
HEhe meni taj TAT nece ni radit iz neznamkojih pobuda
Staro 24.04.2008., 16:49   #4
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
@Matth€w : si siguran da ti je tj.max na 85
inace moj rez
Staro 24.04.2008., 17:36   #5
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
napokon core temp koji mi pokazuje dobru temperaturu
Z-man je offline   Reply With Quote
Staro 24.04.2008., 18:20   #6
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Ne poklapaju mi se temp s Real Tempom. U Core Temp mi je Tj Max 100c, dok je u Real Tempu 95.hmmm
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 24.04.2008., 18:32   #7
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
a kolika ti je razlika temperatura izmedu RL-a i CT-a?
Staro 24.04.2008., 18:36   #8
BladeRunner
Type R
Postovi: 1,485
Autor Bullet1 Pregled postova
Pa koliko i razlika u Tj Max-u. 5C.
Staro 24.04.2008., 18:37   #9
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
onda fino stavi tj.max na 95 i mirna Bosna
"Add: Adjustable Tj.Max value via *.INI file. "
Staro 24.04.2008., 21:09   #10
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
dupli post no potrebno je
Odmah nakon izlaska ove (0.98) verzije, izasla je 0.98.1 verzija
Changelog :
*Fix: Incorrect recognition of 45nm Intel CPUs in version 0.98.*
Download
EDIT: Razer dodaj ovo u prvi post i naslov 0.98.1
Staro 24.04.2008., 21:38   #11
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
meni i dalje razlika u coretemp<->realtempu 5-6C...
Spoiler alert!
Staro 24.04.2008., 21:57   #12
Razer
Razer's Avatar
Postovi: 11,642
RT je ionako pogodniji za 45nm procesore...
Staro 24.04.2008., 22:12   #13
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Autor Razer Pregled postova
ovime sam htio aludirati na to da nitko ne zna sto je tocna temperatura vise...
ali oke...
Spoiler alert!
Staro 24.04.2008., 22:13   #14
Razer
Razer's Avatar
Postovi: 11,642
Isto je aludirao i BladeRunner s istim procesorom i istim programima
Staro 24.04.2008., 22:18   #15
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
oke, ovo se slobodno moze brisati, ali br nije aludirao na to da nitko ne zna koja je temperatura tocna, nego je samo komentirao da ima razliku u temperaturi, kao sto sam naposlijetku i ja... al nema veze...
o ti prepametnosti razer, reci ti meni koja je tocna temperatura tada?
Spoiler alert!
Staro 24.04.2008., 22:41   #16
Uber Gosu
FORD Fix Or Repair Daily
Uber Gosu's Avatar
Postovi: 872
Jedina stvar koju svi programi tocno mjere je distance to Tjmax a koliki je u stvari Tjmax neznaju ni u intelu, cak brijem da nije isti od proca do proca iz iste serije vec da ovisi ko OC sposobnost o visoj sili.
Uber Gosu je offline   Reply With Quote
Staro 24.04.2008., 22:50   #17
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ma do 75 celzijusa svaki moze durati. Ako su 65nm Presleri drzali plin od 100% na 80 celzijusa, drzat ce i Core 2
Staro 24.04.2008., 23:26   #18
BladeRunner
Type R
Postovi: 1,485
Ma temp nemogu bit velike pod BigTyp-om i undervoltanim procom tako da me baš briga. Ako hoće gorit, nek gori, ima garanciju .
Staro 02.05.2008., 23:10   #19
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
v 0.99 beta
- Fix: Incorrect recognition of 45nm Mobile Intel CPUs.
- Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).
- Add: Shared memory - developers now have access to Core Temp data.
- Add: Register dump to text file function.
- Add: Preliminary Atom (Silverthorne) support - Untested.
DeadMan+ je offline   Reply With Quote
Staro 04.05.2008., 16:01   #20
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Jel se može namjestiti Tj.Max na CoreTempu da mi bude 85°C...a ne 100°C
pokazuje mi oko 40-ak (kao i Everest), dok mi SpeedFun pokazuje dosta niže temp...
i sad neznam, tko je tu u pravu i kolika mi je stvarno temp...
evo sličice:
Zadnje izmijenjeno od: Core2Duo22. 04.05.2008. u 16:13.
Core2Duo22 je offline   Reply With Quote
Staro 04.05.2008., 16:10   #21
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
pokusaj sa Real Tempom
Staro 04.05.2008., 16:20   #22
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Kao i obično krivo pokazuje, punih 15 stupnjeva.
žmnpp
buljo je online   Reply With Quote
Staro 04.05.2008., 16:26   #23
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Autor buljo Pregled postova
Misliš na CoreTemp kojemu je Tj.Max 100 ?
al svi pokazuju (everest, TAT...) isto kao i CoreTemp...
volio bih da je SpeedFun u pravu
Staro 04.05.2008., 16:28   #24
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Da, jer mojem procu nije TJ Max 100 nego 85, jer bi bilo suludo da mi je idle 40-45 sa ovom mrcinom od coolera na njemu, koji je ledeni.
žmnpp
Staro 19.05.2008., 15:07   #25
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
novi Core Temp 0.99
Version 0.99 - 18th May, 2008
- Fix: CPU load would sometimes display -1% load.
- Fix: AMD K8 would sometimes spike to 206C, the false reading is now ignored.
- Fix: AMD K8 sometimes constantly reads -49C.
- Fix: Core Temp does not show up automatically on G15 LCD with 2.02 driver.
- Fix: Shared memory structure was not properly filled on multiprocessor systems.
- Fix: System tray setting "Show highest temperature of each CPU" only displays one temperature reading in a multi CPU system.
- Fix: Certain problems with font resizing should now be fixed.
- Fix: G15 LCD would not update after using soft buttons.
- Fix: On temperature display mode change, high and low records were not reset.
- Fix: Changing the reading interval in settings did not actually update, restart of Core Temp was needed to apply the change.
- Fix: Incorrect VID detection on 45nm desktop Intel parts.
- Add: Support for Intel Core 2 Duo E7000 45nm series.
- Add: Option to show a single icon instead of temperature in the system tray.
- Add: Custom font and size for G15 LCD screen or simply use the built in compact font and layout. (via Settings.ini)
- Change: Improved detection of L2 cache on Intel chips for more accurate recognition.
- Change: Rewritten temperature calculation to fix problems with shared memory.
- Change: Default G15 LCD text layout and font changed.
- Change: Doesn't create a log file containing session start and end times if logging is disabled.
- Change: Settings.ini file is automatically created with default settings in case one doesn't already exist.
Staro 06.06.2008., 18:57   #26
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Core Temp Grapher Beta 1.0 (build 1.0.0.2)
Program vezan za CoreTemp koji vam omogucuje pracenje temperatura uz uvid o procesorkom zauzecu kroz dulji vremenski period. Zna nekad bit koristan iako nista posebno.
Jos je u probnoj verziji.
Za pokretanje programa obavezno morate imat ukljucen i CoreTemp 0.99.
Mozete birat i nacin prikaza kao sto je prikazano dole na slici
Download
Zadnje izmijenjeno od: Bullet1. 10.06.2008. u 00:32.
Staro 20.06.2008., 18:15   #27
Lepy
žicless surfer
Lepy's Avatar
Lokacija: Space
Postovi: 177
I meni na E8400 svaki prog. mjeri drugu temp., ali me zanima druga stvar - da li je normalno da je razlika između core1 i core2 temp. cca 3°C ili mi je cooler krivo nasjeo na proc?
by Lepy
Lepy je offline   Reply With Quote
Staro 21.06.2008., 14:33   #28
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,281
skoro uvijek je mala razlika izmedju jezgri. meni je razlika 5°c izmedju prve
dvije i druge dvije jezgre. mislim da nije alarmantno osim ako je ta razlika 7-8
pa na vise...
rodney je offline   Reply With Quote
Staro 21.06.2008., 21:31   #29
HAL 9001
Poboljsana verzija
HAL 9001's Avatar
Postovi: 484
[quote=rodney;1063756]skoro uvijek je mala razlika izmedju jezgri. meni je razlika 5°c izmedju prve
pa na vise...[/quote Meni po real tempu razlika zna biti 9-10 stupnjeva.Sto bi to trebalo znaciti.Imam li razloga za brigu?
HAL 9001 je offline   Reply With Quote
Staro 23.06.2008., 15:40   #30
Thommy
Thommy's Avatar
Postovi: 469
HAL 9001 provjeri dali ti hladnjak dobro sjeda na procesor ... kod mene nema razlike u temparaturama jezgri sa kojim god programom mjerim (everest, realtemp, core temp) jedino kaj mi everest i core temp pokazuju 10 stupnjeva vise od real temp-a (konfa iz mycomp)
Thommy je offline   Reply With Quote
