#1531 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
a ne necu se zaliti otici cu im na vrata sa sjekirom pokucati ![]()
#1532 |
1oo1 NooB
Postovi: 1,306
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#1533 |
Postovi: 623
Nice ovaj AMIS. Meni taman isteko ugovor sa T-Comom ![]() Ali neću prebacivati jer imam Max-Tv ![]() |
#1534 |
Uptime 99.99%
Postovi: 2,678
Evo novosti iz Amisa, vratio se packet loss. PING pcekspert.com (69.93.122.162) 56(84) bytes of data. 64 bytes from a2.7a.5d45.static.theplanet.com (69.93.122.162): icmp_seq=2 ttl=46 time=177 ms 27 packets transmitted, 6 received, 77% packet loss, time 26008ms rtt min/avg/max/mdev = 162.703/170.893/177.161/5.643 ms PING youtube.com (208.65.153.253) 56(84) bytes of data. 64 bytes from youtube.com (208.65.153.253): icmp_seq=14 ttl=230 time=190 ms 64 bytes from youtube.com (208.65.153.253): icmp_seq=16 ttl=230 time=189 ms 64 bytes from youtube.com (208.65.153.253): icmp_seq=27 ttl=230 time=189 ms --- youtube.com ping statistics --- 28 packets transmitted, 3 received, 89% packet loss, time 27009ms rtt min/avg/max/mdev = 189.503/189.950/190.449/0.526 ms Iz amerike do amisa PING hosting.amis.hr (194.146.109.202) 56(84) bytes of data. 64 bytes from hosting.amis.hr (194.146.109.202): icmp_seq=1 ttl=53 time=154 ms 64 bytes from hosting.amis.hr (194.146.109.202): icmp_seq=4 ttl=53 time=162 ms 64 bytes from hosting.amis.hr (194.146.109.202): icmp_seq=5 ttl=53 time=162 ms 64 bytes from hosting.amis.hr (194.146.109.202): icmp_seq=12 ttl=53 time=162 ms --- hosting.amis.hr ping statistics --- 13 packets transmitted, 4 received, 69% packet loss, time 12001ms rtt min/avg/max/mdev = 154.473/160.183/162.132/3.309 ms, pipe 2 |
#1535 |
upgrading...
Lokacija: Zagreb->G.Dubrava
Postovi: 438
yep, ma nes u zadnje vrijeme mi se cesto veza blocka i problemi, zadnjih par dana <table class="datatable" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td width="170">Uptime:</td><td colspan="3">3 days, 13:59:51</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Modulation:</td><td colspan="3">G.992.1 Annex B</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td><td colspan="3">449 / 2.457</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Data Transferred (Sent/Received) [GB/GB]:</td><td colspan="3">3,44 / 18,76</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Output Power (Up/Down) [dBm]:</td><td colspan="3">12,5 / 19,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Line Attenuation (Up/Down) [dB]:</td><td colspan="3">12,0 / 19,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">SN Margin (Up/Down) [dB]:</td><td colspan="3">31,0 / 30,5</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Vendor ID (Local/Remote):</td><td colspan="3">TMMB / BDCM</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Framing (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Signal (Local/Remote):</td><td colspan="3">2 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Power (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Link (Remote):</td><td colspan="3">0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Error Seconds (Local/Remote):</td><td colspan="3">102 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">FEC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">CRC Errors (Up/Down):</td><td colspan="3">44 / 87</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">HEC Errors (Up/Down):</td><td colspan="3">24 / 27</td></tr></tbody></table> |
#1536 |
Hejter
Postovi: 6,521
Evo stiglo danas uz racun ono vec spominjano ovdje - to da ostaje djabe pozivi u fiksnu , ali toliko lijepo napisano da umres od smijeha ... sad i mene ljute sto to salju i mazu oci ali dobro , i dalje sam daleko od nezadovoljstva ... ![]() |
#1538 |
Postovi: 44
pa google na slovenskom je normalna stvar kod mene ![]() sva sreca pa sam na juznoslavistici na filozofskom pa mi nesmeta )) |
#1539 |
1oo1 NooB
Postovi: 1,306
#1540 |
Lokacija: Vz - Zg
Postovi: 2,930
jel netko zna kak slozit uspostavu veze s nekog drugog mjesta a ne direktno preko ovog smeca od modema sto oni dilaju? posto se radi o najobicnijem pppoe protokolu nije velka mudrost osim sto to smece ne pusta van ako neki drugi uredaj pokusava samostalno uspostavit konekciju (komp, router, nesto trece). hlp plz p.s. imam amis 2 dana i vec nisam zadovoljan
#1541 |
Datum registracije: Jun 2004
Postovi: 1,567
Zadnje izmijenjeno od: dDario. 21.05.2008. u 17:44. |
#1544 |
upgrading...
Postovi: 438
#1545 |
bycod
Postovi: 6,699
#1546 |
Postovi: 15
Ja sam im poslao mail sa prigovorom i samo su odgovorili da "misle" na svoje korisnike i da su nam već "poklonili" besplatno telefoniranje i da imaju još nekoliko akcija u planu za ovu godinu, ali ništa o tome kada i što. ![]() |
#1547 | |||
Killer of your Dreams
Lokacija: Final Digit of the Rainbow
Postovi: 107
Pucanje
Meni nikad skoro ne pukne prije isteka 24 sata. Ali ja gotovo da cucim kraj centrale, gusenja su mi 3/2dB, tebi si MINIMALNO 10/10dB. Jbg, some locations sucks. Citiraj:
Inace, samo postavite u google postavkama da vam je default jezik hrvatski i da se pretrazuju hr stranice umjesto svih. Onda ce vam sve bit normalno, necete ni znat za probleme sa slo googleom, provjereno, iz vlastitog iskustva. Citiraj:
Pa uopce se ne radi o routeru nit je on vece smece od dlinka (bolji je od njega i po kvaliteti i po mogucnostima, pogotovo za port mapping), nego ti kao power user nemas pravo pristupa promjeni moda. Dakle, potrebno je promjeniti mod iz routing u bridge da bi mogao nakacit alternativni router ili mreznu karticu direkt da bi to sto nakacis (bilo router bilo komp) moglo pozivat pppoe konekciju. velike mudrosti, sam si trebo nazvat korisnicku, oni ti to srede, bar ne cekas kao kod t-coma pola sata xD Zadnje izmijenjeno od: Rebellion. 07.06.2008. u 00:16. |
#1548 |
Sruk
Datum registracije: Sep 2004
Postovi: 1,163
e jel ima neko problema da mu se modem nakon gubitka veze mora ugasit pa upalit opet da bi se doslo do veze? meni se to zna dogadat i u zadnje vrijeme dost cesto... kaj se tice ovog s losom paricom....pa nemora uvijek bit da je losa parica uzrok problema, evo u mom slucaju u pocetku sam bio pun problema dost cest gubitak veze, i s vremenom i puno zvanja podrske, stvari su se normalizirale, a siguran sam da nisu minjeali paricu.... ugl, kaj me zanima... mislim da ti problemi da se nece automatski spojit nastaju zbog routera, sad me zanima jel to tocno, al vjerojatno je i jel bi se moglo njih trazit novi, il neki upgrade firmwarea il da ja mozda kupim novi/bolji router pa da mi oni daju da mogu prek njega na AMIS? zanima me jel imo ko kakva iskustva s tim, jel to prolazi il kaj? jer ovo, ja njih nazovem, oni kazu ok, pa cackaju nest, ne rjesava problem, ak je problem u tom tompsonu. edt: sad vidim da je ovo moj jubilarni post....1000 pa bravo ja |
#1549 | |
Lokacija: Vz - Zg
Postovi: 2,930
sad imam problem da puca veza, s tim da se sama veza ne prekine, ostane isti ip i sve, jedino svi programi sto su spojeni na net se svako tolko (5min - pol sata) ponovo pospajaju. To se desava samo dok je upaljeno vise torrent programa u isto vrijeme bez obzira o opterecenju downloada ili ako bas neki od njih povuce jako veliku kolicinu podataka kroz par sekundi pukne isto tako. Nakon sto ih se pogasi jos nekih 5min traje dok sve ne dode k sebi. ili se moze resetirat veza, al nema to smisla (torrenti su limitirani brojem konekcija na 100 svaki, pa nebi smjelo do toga bit, jedno 400-500 ih modem valjda treba moc izdrzat?!) p.s. kak provjerit SNR dok je modem u bridge modu? Edit: odgovor ma moje pitanje odma iznad: nabavim drugi modem, hehe pronadeno rjesenje cini se... snr je izmedu 5.9 i 6.1 u downlinku dok se nista ne radi, nisam uspio isprobat jel se mjenja ili ne, al u principu vjerujem da je to problem... nist idemo s 6mbps na 4 i to je to, to bi moralo dici za ~3dB sto bi trebalo rjesit problem + spajanje splittera i kraj price.
Zadnje izmijenjeno od: antrax. 12.06.2008. u 15:19. |
#1550 | ||
Postovi: 107
stabilnost veze se moze popraviti bez mijenjanja parice, jer ako ti je pusten signal od 6dB, veza će ti puno manje pucat nego na 12dB. Novi firmware neces dobit na zahtjev, nego tek kad ga svi budu dobivali. Novi modem pak mozes dobit ako se zakljuci da je problem bash u modemu, al mislim da tu nije rijec oko toga. Za lose parice je najbolji profil obicni ADSL na 6dB ili ADSL2+ na 6dB, ovisno o parici. Citiraj:
drugo - ili postavi propustanje portova (game and application sharing) ili ugasi firewall! trece - uvijek mozes (u bridge modu samo dok nisi spojen na net) spojiti se na konfigurator i pogledati na broadband connection koliki ti je SNR, znaci odspoji se sa neta kad hoces vidjet SNR - on govori o ADSL vezi, ne internet vezi xD cetvrto - PODHITNO iskljuci UPnP ako imas vise od 200 konekcija na torrentima, a imas ovakva sranja! peto - ne koristi NI SLUCAJNO isti port za vise aktivnih torrent klijenata, i za svaki propusti port!!! šesto - najbolje ne koristi vise aktivnih torrent klijenata, uTorrent preporucujem! sedmo - SNR ti je katastrofa, meni je 30/30 dB up/down, trazi da ti stave 6dB profil, bilo ADSL ili ADSL2+ sedmo - ne mozes kod amisa stavit splitter, ne pricaj gluposti da ti se ljudi ne smiju, kod ULL-a (2u1 npr) ti telefon ide preko ADSL veze, ne preko zasebnog frenkvencijskog podrucja, dakle, zaboravi splitter xD osmo - nemoj gasit modem kad ti se dogodi navedeno, nego prvo se otvori u browseru 192.168.1.254 i pogledaj jesi uopce spojen na net, ako jesi, odspoji se pa se ponovno spoji, ali to se ionako ne bi trebao dogadjati nakon sto resetiras modem i pravilno ga konfiguriras ![]() Zadnje izmijenjeno od: Rebellion. 13.06.2008. u 12:29. |
#1551 | |
Lokacija: Vz - Zg
Postovi: 2,930
1. isprobano odma - iskustvo iz t-m, prvo gasi pali, pa tek onda gledaj jel nesto dalje uzrokuje problem ![]() 2. obavljeno propustanje portova, a gasenje firewalla ne dolazi u obzir ipak. bar kakva takva sigurnost treba bit. + nije do toga jer je na drugoj lokaciji i na drugom operateru s istim postavkama ista konfiguracija vise manje uredno funkcionirala (unatoc kasdi )3. hvala puno, iznimno koristan savjet! mislio sam da nije moguce uopce! 4. upnp ne radi nikakvu razliku bio upaljen ili ne, nazalost 5. naravno da se ne koriste isti portovi, pa to bi bilo suludo, hehe 6. dobra ideja, al trenutno nemamo ~1500 kn viska da slozimo torrent stroj pa svako vuce sta mu treba 7. kako mislis ne mozes stavit splitter?! stavio ga neki dan i ne bi vjerovao veza je bila osjetno stabilnija s njim nego bez njega (modem je i dalje imao voice lampicu upaljenu i vjerujem da je na njega bilo moguce spojit telefon, sto ne znam jer telefon ne koristimo uopce ), splitter ima filter te pomaze kod smetnji.ono sto sam pronasao da su kao zgodne stranice bile su: http://www.kitz.co.uk/adsl/lowSNR.htm http://www.adslnation.co.uk/support/filters.php sve u svemu u ponedjeljak navecer kad dodem u zgb opet isprobam ovo s modemom pa cemo vidjet. (njegov firewall cu iskljucit ak je ukljucen sto nebi smio bit, bar su me u szk tak uvjeravali i sve ostalo na njemu sto ima, naravno, on je tu da pruza konekciju i nista vise)
#1552 |
Administrator
Lokacija: Sesvete
Postovi: 15,963
Nisam pratio svih 50-ak stranice, pa možda malo uletavam no svejedno - Amis IPTV kreće od 1.9 - ima tko kakve informacije o kanalima, cijeni itd? Kanali me najviše zanimaju, ističe mi taman ugovor s maxTV-om pa da vidimo. Koliko vidim, manje više ste zadovoljni s internetom, nema nekih velikih sranja? |
#1553 | |
Hejter
Postovi: 6,521
#1554 |
upgrading...
Postovi: 438
wow, to bi bilo taman, dosta mi je vise ove sugave televizije od 6 programa, samo se nadam da nece imati boljke ko maxtv, ono spori meniji i sl.... ![]() |
#1555 | |
Uptime 99.99%
Postovi: 2,678
Evo ovaj tjedan su rijesili i newse pa vise nije tako ubitacno sporo. |
#1556 | ||
Administrator
Lokacija: Sesvete
Postovi: 15,963
![]() Citiraj:
#1557 |
Postovi: 2,649
Ja sam odlučio otići od njih i prijeći na iskon-carnet duo, možda me ipak zaustave ako uvedu iptv.... Možda. Ugovor mi istječe u 10 mjesecu i prije toga neću raskidati pa još uvijek stignem vidjeti da li će stvarno uvesti televiziju. Obećavali su mi to još prošle godine za 5. mjesec ove ![]() Obećanje ludom radovanje ![]() Da znam da će i iskon s carnetom dofurat iptv do mene ove godine, ne bi ni razmišljao o ostanku na amisu.
#1558 | |
upgrading...
Postovi: 438
#1560 | |
Postovi: 111
Ograničavaju... tj. slobodno ti skidaš, dok te ne otkače ili dok ti se ne obrati MUP.... samo tamo je sve super i ruže cvatu i ptičice pjavaju i još ti Iskon pošalje mladu studenticu (Carnet dio) da te intimno izmasira... NE.. ![]()
Ovo je potpis...
